Reading: Questions on Resistive Tape Level Sensor
Inst Tools > Blog > Practical Questions > Questions on Resistive Tape Level Sensor
A resistive tape level sensor is a two-wire element immersed in a liquid, which changes resistance as liquid level increases.
Last updated: February 11, 2021 11:50 am
Practical Questions
2 Min Read
The principle is the same as placing your rubber-boot-covered foot in a pool of water: the deeper your foot is submerged, the further up your foot and ankle you feel the water’s pressure push the rubber boot against your skin.
A resistive tape stretches the entire height of the vessel, and contact is made between two resistive wires by the head pressure against the submerged length of the tape.
The greater the liquid level, the further the length that the two wires are in contact with each other, resulting in less resistance overall.
Examine the following resistive tape level measurement system and calculate the following, assuming
  • a maximum tape resistance of 10 kΩ (i.e. resistance with zero immersion),
  • a minimum resistance of 2 kΩ (i.e. resistance with total immersion),
  • a linear relationship between tape immersion and tape resistance, and
  • a total tape length of 15 feet:
Tape resistance (Rtape) = ________
Immersion depth = ________
Share your answers & explanation with us through the below comments section.
  • Tank Stilling Well
  • Level Transmitter Errors
  • Sump Tank Level Transmitter
  • Magnetostrictive Level Sensor
  • Guided Wave Radar Level Sensor
Credits: Tony R. Kuphaldt
Programmable Logic Controller (PLC) Questions and Answers – 5
How to Decrease Span of Pressure Gauge?
PLC Switch Actuation Status
Thermocouple Terminal block Questions
Displacer Type Density Transmitter Question
How Overload Heaters used to Automatically Shut the Motor OFF ?
Float-type Level Switch for Sensing Low Oil Level
Identify Two Pressure Switches Logic
Identify the Problem in the PLC Program
Practical Process Control System Questions & Answers – 6
Stripper Overhead Temperature Control System
Problem on Weigh feeder
PLC Practice Questions
Compressor Emergency Shutdown Root Cause Analysis
Pneumatic Moment-balance Differential Pressure Transmitter
Simple Pressure Transmitter Circuit
Pressure Transmitter using Potentiometer and Diaphragm
Foxboro pneumatic instruments
Pneumatic Force Balance Instrument
Heat Exchanger Differential Pressure Transmitter
pressure transmitter calibration setup
Why Pressure Vessel Connected to Tubing System?
Questions on Pneumatic Control Loop
Pressure Switch Questions
Practical Control Systems Questions & Answers
Practical Process Control System Questions & Answers – 1
Instrument Technician Interview Questions
Instrument Technician Interview Questions and Answers
How does the IIoT work - Industrial Internet of Things
How does the IIoT work? – Industrial Internet of Things
level control system
Practical Process Control System Questions & Answers – 11
Variable Air Volume Controller in HVAC
What is Variable Air Volume Controller in HVAC?
Automatic Liquid Mixing Application
liquid flow control loop
Liquid Flow Control Loop Controller Action
Pressure Regulators vs Pressure Control Valves
Pressure Control Valves vs Pressure Regulators
Newton’s Law of Cooling - 3
Lag time
