Reading: Quick Exhaust and Air Operated Valves in Instrumentation Circuit
Inst Tools > Blog > Control Valves > Quick Exhaust and Air Operated Valves in Instrumentation Circuit
Understanding the application of Quick exhaust and Air operated valves in instrumentation circuits with sample cases.
Last updated: August 15, 2023 6:52 am
Control Valves
Quick Exhaust Valve (QEV)Pilot / Air Operated Valve
Before looking into the application of Quick Exhaust Valve (QEV) and Air operated valves in instrumentations. Let’s go through the definitions of the same.
The quick exhaust valve is a three-way valve that works primarily on the differential pressure between inlet and outlet ports.
Quick Exhaust Valve (QEV) finds application wherever there is a necessity for faster stroking time or air from the cylinder need to be exhausted quickly.
The pilot Valve is the same as the solenoid valve, however, instead of an electric signal, an air pressure signal shall be used to direct the spool to either keep it closed or open.
Pilot Valve P&ID
In process and automation industries, QEV and Pilot valves are used widely in Actuator and pneumatic cylinders for quick exhaust and stroking applications. Let us go through the below scenarios and understand where the application demands the use of QEV or Pilot valve
Suppose if we are having SOV, QEV, and PV of below sizes and flow capacity, let’s see how we can efficiently use the available ones with the below sample cases
ComponentPort SizeFlow Capability – Cv (m3/hr)Average Cost (INR)
SOV1/4″ NPT0.536000
QEV1/4″ NPT1.14000
PV1/4″ NPT1.55500
Case 1:
Taking 6 Inch Valve which is actuated by a pneumatic actuator with a cylinder volume of 10.37 liters.
Valve Size (Inch)ACT cylinder Volume (Ltr)Stroking time (sec) – OpeningStroking time (sec) – ClosingRequired Flow capacity (m3/hr) – OpeningRequired Flow capacity (m3/hr) – Closing
610.3730300.2190.183
Here the actuator requires air flow capacity of 0.219 and 0.183 in opening and closing of the valve respectively, which is lower than the SOV flow capacity of 0.53.
So the stroking of the actuator can be performed by SOV easily and usage of QEV and PV is not required.
SOV control circuit
Case 2:
610.373060.2190.765
In this case, the required flow capacity in the closing of the valve is higher than the SOV’s Cv of 0.53.
However the above-mentioned QEV has a flow of 1.1, which shall meet this requirement.
Note: Even a pilot valve can be used for this circuit, however, the flow capacity is higher only during the closing of the valve, so using QEV will be an cost-efficient option
Quick Exhaust Valve (QEV) Control circuit
Case 3:
610.37661.3701.150
Since the required flow capacity of the actuator is higher in both opening and closing positions. A Pilot valve with a flow capacity of 1.5 can be employed here to stroke the valve.
Note: Instead of Pilot Valve, an SOV of ½” port size can also be used, however, its the cost would be very high, and going with a pilot valve and ¼” port size SOV in the pilot line would be the cost-effective option.
Pilot Valve (PV) control circuit
Author: Jamal Shagul Ameedh JM
  • On-Off Valve Problems
  • Control Valve Design Factors
  • Solenoid and Motorized Valves
  • Control Valve Maintenance
  • Butterfly Valves and Ball Valves
Butterfly Valves – Concentric, Double-offset, and Triple-offset
What is Swing Check Valve ?
How to Solve On-Off Valve Problems?
Introduction to Types of Valves
Self-Actuated Valves, Pneumatic & Hydraulic Actuators
Valve Characteristics – Quick Opening, Linear & Equal Percentage
Free Control Valve Software Download
What is a Electric Motor Actuator ?
Solenoid Valves Types, Principle & Animation
Electric Motor Actuator Parts
Control Valve Flow Direction
What happens when Fluid Flow Reversed through Control Valve?
Ball Valve Material Selection
How to Remove Control Valve Stem Packing Procedure
The Replacement Procedure for Control Valve Stem Packing
Emergency ShutDown Valve Working Principle
ESDV : How it Works ?
DIN Valve Connectors
DIN Valve Connectors – Definition, Types
Choke Valve Hydro Test Setup
Choke Valve Hydro Testing Procedure
Applications of Digital Control Valves
Digital Control Valves – Introduction, Principle, Setup, Applications
Top 80+ Valve Questions and Answers
Solenoid Actuated Valves
noise-abatement trim
Control Valve Noise Problems
Top 250 Electronic Circuits Objective Questions and Answers
Draw a Ladder Logic to control a bulb using push buttons in PLC
Concept of Latching in PLC
Shaper Machine Hydraulic Circuit Design
Hydraulic Shaper Machine – Components, Circuit, Principle
Basic Logic Gate Symbols
Engineering Logic Diagrams
Instrumentation Design Details
Ground Plate
Grounding of Telecommunication Systems
RFID Technology in Industrial Automation
Instrumentation Engineering Materials Test
