Reading: Properties of Liquefied Petroleum Gas (LPG)
Inst Tools > Blog > Common > Properties of Liquefied Petroleum Gas (LPG)
Liquefied petroleum gas or liquid petroleum gas (LPG or LP gas), a mixture of propane and butane, is a flammable mixture of hydrocarbon gases.
Last updated: October 17, 2023 3:13 pm
Anurag Mathur
Common
Liquefied petroleum gas or liquid petroleum gas (LPG or LP gas), a mixture of propane and butane, is a flammable mixture of hydrocarbon gases used as a fuel in heating appliances, cooking equipment, and vehicles.
It is also increasingly used as an aerosol propellant and a refrigerant, replacing chlorofluorocarbons in an effort to reduce damage to the ozone layer. When specifically used as a vehicle fuel it is often referred to as auto gas.
Varieties of LPG bought and sold include mixes that are primarily propane (C3H8), primarily butane (C4H10) and, most commonly, mixes including both propane and butane. In winter, the mixes contain more propane, while in summer, they contain more butane.
The properties of LPG gas are discussed below.
Chemical Identity
  • Chemical Name: LIQUEFIED PETROLEUM GAS
  • Chemical Classification: Hydrocarbon Mixture
  • Synonyms: LPG, Propane, Butane, Propylene
  • Trade Name: LPG, Purofax, Bottled Gas.
  • Formula: C3H8, C4H10 (Mixture)
  • Regulated Shipping Name: Petroleum Gases, Liquefied.
  • Max. Vapour pressure @650C 16.87kg/cm2
  • Volatility: evaporation at 20C for 95% by vol. At 760mm hg  Pressure
The density of liquid (0.525 to 0.580 at 15°C)
  • Remain over water in drain etc.
  • LPG Fire cannot be extinguished with water
  • Water is used only for cooling
Density of LPG vapour (1.5 to 2.0)
  • Heavier than Air
  • Settles down in low lying area /Ground level
  • Accumulates in depression
  • Under still condition dissipation is low
  • Accumulation can give rise to potential Fire & explosion Hazards
  • Hot plate (Gas stove) shall always be at higher level compared to Cylinder
Co-efficient of volumetric expansion
  • LPG liquid expands 250 times by volume to vapour
  • At liquid full condition, any further expansion of liquid Cylinder pressure  will rise by 14 -15 kg/cm2
  • In case of fire it is essential to cool all adjacent vessels  to avoid BLEVE
  • Expansion is 100 times more than steel
  • Vapour pressure depends on temperature & has no relation to the quantity of LPG
  • Minimum allowable space 5%
Liquefied Petroleum Gas Tanker
Flammability (1.8 % – 9.5 %)
  • Small leakage can cause Fire.
  • Major leakages are with high concentrations initially, but in  contact  with air  LPG dissipates very fast and forms flammable mixture
  • Auto Ignition Temperature  (410 – 580 °C)
Latent heat (10,900 Kcal /Kg)
  • Causes formation of ice during gushing out of LPG
  • If  venting is done in uncontrolled condition,  shall lead to jamming of valves
  • Results in cold burn/ Frost bite if exposed to body
Colour
  • Colourless in both Liquid & Vapour Phase
  • Leakage cannot be detected by naked eye
Odour
  • Very Faint Smell (Odourless)
  • Leakage cannot be detected by smell. For Detection by smell a chemical is added to LPG
  • Ethyl Mercaptan – 20 ppm/odour level 2
Combustion properties
  • Oxidation of LPG vapour with air/oxygen
  • LPG requires @ 50 times its own volume of air for combustion yielding 3 to 4 times its own volumes of carbon dioxide & 10,900 kcal heat
  • Results in  loss of air after combustion
  • Limit of flammability
  • Calorific value – ideal fuel
The behaviour of LPG in a closed container
  • If no ullage, exerts a pressure of 14 to 15kg /cm2 on the container per degree rise of temperature •Vapour pressure depends on temperature & has no relation to the quantity of LPG
  • Adequate vapour must be present
Hazards of LPG
Health hazards
  • Non toxic
  • Asphyxiation
  • Frost bite
Fire hazards
  • Explosion
  • BLEVE
  • UVCE
  • Oil and Gas Questions
  • Gas Flow Meter Calibration
  • Gas Compressor Seal Oil System
  • Hydrogen Sulfide Gas Detector
  • Turbine Questions and Answers
Advancements in Lime Slaking Technology: What’s New And What’s Next
Moving Magnet Type Velocity Transducer
Basic Principles of Solar Technology
What is a Database Server? – Types, Comparison
IPv4 vs IPv6 – What’s the Difference Between IP addresses?
Power Tool Maintenance – When And How To Replace Carbon Brushes
Classification of Weighing Balance and Weight
Pharmaceutical Industry: The Role of Precision Tools
What is an Automotive Radiator?
Types of Tachometers – Mechanical and Electrical Tachometers
Sugar Plant – Automatic Control of Massecuite Feed
What is a Process Alarm? Types of Alarms
Difference Between HDD and SSD
Procedure for Crimping the Connector
Solar Pump
What is a Solar Pump VFD? – Advantages, Principle
Range Finders
Range Finders – Ultrasonic, Light, & Global Positioning Systems
Why does SMPS Need isolation - Switch Mode Power Supply
Why does SMPS Need isolation? – Switch Mode Power Supply
How to Train Your Maintenance Team for Industrial Automation Systems
Bracelet Scanner
How to Use Bracelet Scanner? – Ultrasonic Thickness Gauge
Double-Acting Pneumatic Cylinder Circuit
Pneumatic Cylinder Movement Control with Timer Circuit
ISA symbols for Process Instrumentation
ISA Codes & Symbols for Process Instrumentation
GPS Fleet Tracking Software
What’s the Best GPS Fleet Tracking Software and Systems?
Transformer Energy Losses & Efficiency
A Large Gate Valve Failed Motorized Operation
A Large Gate Valve’s Failed Motorized Operation
Derivative Controller Response
Derivative Controller Principle
desuperheater
Concept of Desuperheater
International Standards - Types and their Details
International Standards – Types and Their Details
Bi-metal Temperature Gauge
Bi-metal Temperature Sensors
Magnatic Level Indicators Working Animation
What is a Mimic Panel
What is a Mimic Panel ?
