Reading: Programmable Logic Controller (PLC) Questions and Answers – 8
Inst Tools > Blog > Practical Questions > Programmable Logic Controller (PLC) Questions and Answers – 8
Last updated: June 6, 2018 10:06 am
Practical Questions
1 Min Read
Suppose we have an Allen-Bradley MicroLogix 1000 controller connected to three pushbutton switches as shown in this illustration:
Allen-Bradley MicroLogix PLC Wiring
Determine the necessary switch actuation statuses (i.e. pressed versus unpressed) to turn the lamp on given the following program running in the PLC:
AB PLC Logic
Answer :
Necessary switch statuses:
  • Switch A = pressed
  • Switch B = pressed
  • Switch C = released
Share Your Answer / Comments
Credits :  Tony R. Kuphaldt – under CC BY 1.0
For More PLC Questions : CLICK HERE
Float-type Level Switch for Sensing Low Oil Level
Practical Process Control System Questions & Answers – 9
Simulate Different Values for Pressure Instrument Under Test
Practical Level Sensors Questions and Answers
DP Transmitter Error Calculations
Practical Process Control System Questions & Answers – 2
Practical Process Control System Questions & Answers – 3
Practical Process Control System Questions & Answers – 4
Draw Limit Switch Symbol ?
Calculate the Voltage across Voltmeters of Thermocouple
Programmable Logic Controller (PLC) Questions and Answers – 16
Compressor Emergency Shutdown Root Cause Analysis
Calculate Hydraulic Pressure of a Drum
Calculate Hydraulic Pressure of a Process Vessel
two chemical streams are mixed together
Trends of PV and SP on a process chart
Inspecting the Trends of PV and SP on a Process Chart Recorder
Air Compressor Control Circuit has a Problem
Air Compressor Control Circuit Problem
PLC Program three-phase electric motor
Identify the Problem in the PLC Program
Question on Analytical Controller
DP transmitter Errors
DP Transmitter Calibration Errors
compressor emergency shutdown system
Solenoid Valves Questions & Answers – 2
A Question on Density Gauge
Tungsten Grinders
How to Choose the Best Tungsten Grinders for Welders?
Thyristor Firing Circuit Quiz
Career Opportunities and Scope in Industrial Automation
Ultrasonic Tank Gauging
Why Using VoIP Systems
Why Using VoIP Systems Can Save You and Your Business Money?
ultrasound
Ultrasonic Gas Leak Detectors (UGLD)
Thermocouple Calculations
Free Download Thermocouple Calculator
