Reading: Sketch a Ladder Diagram for PLC to Energize the Lamp
Inst Tools > Blog > Practical Questions > Sketch a Ladder Diagram for PLC to Energize the Lamp
Sketch a Ladder Diagram program for this PLC to energize the lamp if the following input conditions are met.
Last updated: February 20, 2021 10:23 pm
Practical Questions
1 Min Read
Programmable Logic Controller Questions and Answers
Suppose we have a PLC connected to three pushbutton switches as shown in this illustration:
PLC Questions - 1
Sketch a Ladder Diagram program for this PLC to energize the lamp if the following input conditions are met:
  • Switch A pressed
  • Switch B pressed
  • Switch C unpressed
Answer
PLC Logic answers
Share Your Answer / Comments
PLC Lessons
Credits : by Tony R. Kuphaldt
For More PLC Questions : CLICK HERE
  • Top 100 PLC Questions
  • Motor and Push-button Logic
  • Troubleshoot Allen Bradley PLC Logic
  • Types of Allen Bradley PLC
  • PLC Memory Mapping and I/O addressing
Identify Problem with Oily Water Filter Instrumentation
Something is Wrong with Strain Gauge Bridge Circuit
Calculate the appropriate millivoltage values of a Thermocouple
Solenoid Valves Practical Problems
Analytical Process Control Question
Resistance Temperature Detector (RTD) Questions – 2
Draw Wiring of a Pressure Switch to control two lamps
Practical Process Control System Questions & Answers – 11
Steam Eductor Question
Draw the appropriate Pressure Switch Symbol ?
Vertical Tube Liquid Level Equilibrium
Problem on Tachogenerator
Flow Transmitter Readings mismatch with DCS
Questions on Pneumatic Control Loop
A Question on Density Gauge
two chemical streams are mixed together
liquid flow control system
Practical Process Control System Questions & Answers – 7
PLC program pushbutton switches
Question on Remote Seal with Capillary Tubing Transmitter
steam heat exchanger
Practical Process Control System Questions & Answers – 9
Trends of PV and SP on a process chart
Inspecting the Trends of PV and SP on a Process Chart Recorder
Simple Pressure Repeater
Direct & reverse actions control valve
Direct Acting Control Valves & Reverse Acting Control Valves
Electric Circuits Objective Questions – Set 9
To check the characteristic of vibration probe
Pictorial Fluid Power Diagram
Hydraulic and Pneumatic P&ID Diagrams and Schematics
Infrared Flue Gas Analyser
What is Infrared Flue Gas Analyzer? – Working Principle
harmonics-effect-on-induction-motor
Harmonics effect on Induction Motor
Absorption Instrumentation Questions & Answers
Relay ladder diagram example
How to Draw a Schematic Diagram ?
