Reading: Polarization Index (PI) Test and DA Test
Inst Tools > Blog > Electrical Basics > Polarization Index (PI) Test and DA Test
Polarization Index (PI) and DA Tests are used to check the insulation resistance value of insulating materials used for electrical system.
Last updated: October 17, 2023 2:06 pm
Electrical Basics
Without use of insulating material it is impossible to use electrical supply. The insulators are used to separate the conducting and non-conducting parts. The operational reliability of the insulating material is vital for making the electrical system reliable. About 98 % faults are phase to earth faults and it happens because of insulation failures.
Polarization Index (PI) TestHow PI Test is Performed?What should be the PI Value?Dielectric Absorption Ratio (DA or DAR) TestHow DAR Test is performed?Advantage of PI and DA Test
Therefore, it is very important to check the insulation resistance value of the insulating materials used for electrical system.
The very simple method to check the insulating material resistance is through measurement of the insulation resistance. The insulation resistance is checked by megger or insulation tester.
The voltage is applied between the live part and the ground part to check the insulation resistance. The insulation resistance of the insulator can be expressed with following mathematical expression.
R = V/I
Where,
R = Insulation Resistance
V = Voltage applied
I = Current passing through insulating material
Sometimes, only checking insulation resistance value using the megger is inadequate, and it does not give the healthiness of the system.
To check the insulating quality, the more advanced tests are carried out to determine the remaining useful life of the insulating material.
The followings tests are performed to check the healthiness of the insulator.
  1. Polarization Index Test
  2. Dielectric Absorption Ratio (DAR) or DA Test
The polarization Index is nothing but the ratio of insulation resistance after 10 minutes and after 1 minute.
In PI test, ratio of insulation resistance at different times after starting of test is recorded.
The DC voltage is applied between conductors and insulating part, and the insulation resistance value is recorded after 1 minute, then test is continued and the insulation resistance value after 10 minutes is recorded.
The PI value of the insulator must be above 2. The more PI value shows good insulation of the insulating material.
Similar to PI test, it is the ratio test carried out to judge the quality of the insulation.
Dielectric Absorption Ratio (DA or DAR) Test is the ratio of insulation resistance after 60 seconds and 30 seconds.
DAR indicates how quickly the capacitive current becomes zero. The capacitive current in a healthy insulation system must decay within one minute.
In DAR test, ratio of insulation resistance at different times after starting of test is recorded.
The voltage is applied between conducting and insulating part, and the insulation resistance value is recorded after 30 seconds, then test is continued and the insulation resistance value after 60 seconds.
The insulation resistance decrease with increase in temperature. Thus the measured insulation resistance value may be differ for different temperature.
However, PI and DAR is the IR ratio measurement, therefore the measurement is independent of temperature.
Author: Satyadeo Vyas
  • Types of Electrical Wiring
  • Types of Circuit Breakers
  • Motor VFD Drive features
  • Proper Sizing of Conductors
  • What are DOL and RDOL starters?
How to Test a Motor using Megger?
Motor Control Circuit Wiring
Testing and Inspection of Bonding and Grounding Systems
Why is IGBT used in VFD?
What is an Oil Separator in HVAC?
What is an Armoured Cable? Classification of Cables
What is a Lightning Arrester? How does it work?
What is a Time Delay Relay? Principle, Advantages, Disadvantages
Introduction to Protective Systems
Electrical Cabinet Air Conditioner
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
Motor Disconnector Switch
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Fence grounding specifications
All About Electric Fence Gates
How to Identify Phase, Earth, and Neutral Wires_
How to Identify Phase, Earth, and Neutral Wires?
Alternating Current
Difference between AC and DC
VFD Braking
DC Injection Braking in VFD
Difference between KW and KVA
Variable Air Volume Controller in HVAC
What is Variable Air Volume Controller in HVAC?
What is an Automated Guided Vehicle
What is an Automated Guided Vehicle?
Circulating Pump
What is a Circulating Pump?
Phase angle
AC Generation Analysis : Effective Values, Phase Angle and Frequency
Infrared Flue Gas Analyser
What is Infrared Flue Gas Analyzer? – Working Principle
What is a Rotary Actuator
Difference Between Linear Actuator and Rotary Actuator
Top 300 Electrical Circuits Objective Questions and Answers
Relay Wiring
Instrumentation Design Engineer
Role of an Instrumentation Design Engineer for Beginners
