Reading: Pneumatic Moment-balance Differential Pressure Transmitter
Inst Tools > Blog > Practical Questions > Pneumatic Moment-balance Differential Pressure Transmitter
Explain the principle of Pneumatic Moment-balance Differential Pressure Transmitter using the circuit diagram.
Last updated: October 3, 2020 10:04 am
Practical Questions
3 Min Read
The following diagram is that of a pneumatic moment-balance differential pressure transmitter, similar to the Foxboro model 13A. The term “moment” refers to the physics principle of a force acting on a lever to produce a torque.
“Moment-balance” is more appropriate than “force-balance” in this case because the device pits moment against moment, rather than force against force directly:
Pneumatic Differential Pressure Transmitter
Describe this instrument’s response to an increasing differential pressure (increasing pressure on the “High” side, and steady pressure on the “Low” side; or decreasing pressure on the “Low” side with steady pressure on the “High” side), step by step.
Answer:
As the differential pressure increases (“high” side pressure increases relative to “low” side pressure):
  • The diaphragm “capsule” is forced to the right.
  • The Force bar rotates counter-clockwise about the sealing diaphragm, which acts as a fulcrum for the force bar.
  • Flapper approaches nozzle.
  • Nozzle backpressure increases.
  • Increased nozzle backpressure presses up on relay diaphragm.
  • Inside the relay, the ball-shaped supply valve opens and the cone-shaped vent valve closes.
  • Relay output pressure increases (more than the nozzle backpressure increase, due to amplification).
  • This output pressure is sent to the bellows, which presses to the left at the range bar’s lower end.
  • The range bar rotates clockwise about the “range wheel” (movable fulcrum nut).
  • The top of range bar moves to the right, pulling against the force bar to move the flapper away from the nozzle.
  • The system reaches equilibrium, where the force exerted by the bellows against the range bar balances force exerted by the diaphragm capsule against the force bar.
End result: output pressure equals some proportion (multiple or fraction) of differential pressure across the diaphragm capsule.
More Questions
1. Describe the purpose of the sealing diaphragm shown roughly mid-way along the length of the force bar.
2. Identify how this instrument will respond to obstructions (blockages) in the following locations:
→ Orifice
→ Nozzle
→ Vent (located on relay body)
Interest to add any further points? Share your answers with us through the below comments section.
  • Pressure Gauge Dial
  • Level Gauge Design
  • Diaphragm Pressure Sensor
  • Pneumatic Relay Questions
  • Instrument Calibration Question
Credits: Tony R. Kuphaldt
Loop Powered Pressure Transmitter
Identify Level Control Loop Tuning Problems
Pressure Level Transmitter Problems
Programmable Logic Controller (PLC) Questions and Answers – 7
What Affect the Pressure Measurement Accuracy of a Manometer?
Calculate Incident Power in Radar Level Measurement
Calculate the Transmitter Values
Calculate the 0%, 50%, and 100% Calibration Points
Instrument Salesperson Question
Differential Pressure Measurement across Baghouse
Problem with Sump Tank Level Transmitter
A Question on Density Gauge
Solenoid Valves Questions & Answers – 2
Signal Strength of Guided-wave Radar Level Instrument
thermocouple Transmitter Formula
Calculate Process Temperature using a Thermocouple
DP Transmitter Problem
Transmitter Questions
Practical Process Control System Questions & Answers – 4
Suppose the lamp refuses to light up
Indentify Faults in Simple Lamp Circuit including Failed Wires
Calculate Density and Specific Gravity
Draw the Symbols for Liquid Level Measuring Instruments
Type E thermocouple
Type E thermocouple Calculations
baffle-and-nozzle assembly
Pneumatic Sensing Elements
PLC Star-Delta starter with interlock
Schneider PLC Example Program for Star-Delta System
Difference Between Static and Temp Memory in Siemens TIA Portal
What is a Flange Gasket ?
Piezo Electric Transducers Objective Questions
Magnetostrictive Level Transmitter Working Principle
How To Choose A Surge Protector?
PLC program Permissive Circuit
PLC Electric Motor Interlocks
