Reading: PLC Program to Simulate Gate Array Logic
Inst Tools > Blog > PLC Tutorials > PLC Program to Simulate Gate Array Logic
Last updated: March 4, 2021 2:53 pm
2 Min Read
Develop a PLC program that will simulate the gate array logic as shown in the below figure.
Gate Array LogicProgram LogicInput-Output ListPLC Program for Gate Array LogicProgram DescriptionPLC Programming SimulationCASE 1:CASE 2:CASE 3:Conclusion:
Gate Array Logic
Simulate the given gate array logic in ladder logic operation.
Simulate Gate Array Logic using PLC
Program Logic
Totally there are 10 digital inputs and one digital output.
Solve each OR block separately, do the two AND Function and finally do the OR operation at the end.
Input-Output List
Input Output List of Gate Array Logic
Program Description
RUNG 0000
A, C AND INVERTED B are into OR operation. D and E are into OR operation.
Those two results will make AND operation with G and inverted F.
The Final result is stored in memory coil B3:0/0.
RUNG 0001
H and I are into OR operation and the result is AND with J.
The final result is stored in memory coil B3:0/1.
RUNG 0002
B3:0/0 and B3:0/1 are into OR operation to enable or disable output Y.
CASE 1:
When anyone rung goes true output Y turns ON.
Simulation of Gate Array in PLC Logic
CASE 2:
CASE 3:
When both rungs goes false output Y is disabled.
Gate Array Logic
Conclusion:
The above-explained logic for gate array logic and is successfully simulated with three case studies.
Author: Hema Sundaresan
Data Handling Instructions in PLC
Ladder Logic Example with Timer
Jog Function in Motor using
PLC Temperature Control
How to Control VFD with PLC
What is RS Linx? Types of Software in Rockwell Automation
ON Delay Timer using PLC
Automatic Empty Bottle detection using PLC Logic
PLC Tag Naming Conventions
Glass Cutting and Polishing Machine: PLC Automation Solution
PLC Mixing Process with Adjustable Timer and Valve Control
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
Power Supply Sizing for Industrial Automation Systems
What is PID Controller?
FIFO Instruction in Allen Bradley PLC Programming
Main differences between Sinking and Sourcing Circuits
PLC Programming for Train Detection and Gate Operation
PLC Memory Organization - Data Files and Program Files
PLC Memory Organization – Data Files and Program Files
What is a Floating License - Automation Software Systems
What is a Floating License? – Automation Software Systems
Allen Bradley PLC Interview Questions & Answers
Allen Bradley PLC Interview Questions and Answers
Lights with Adjustable Timers PLC Programming
Flip-Flop PLC Programming: Lights with Adjustable Timers
DCS Vs PLC
Difference between DCS & PLC Systems
Siemens PLC Math Instructions
Siemens PLC Mathematics Instructions
RSlogix 500 to communicate with Excel
How to Communicate with Excel from RsLinx?
Advanced PLC Programming Training Course
SIS Testing and Repair Deferral
solenoid-valves-types-principle-animation
Solenoid Valves Types, Principle & Animation
Gauge Cock
Pressure Gauge Cocks
Encoder Principle
Encoder Working Principle
Methods of Transistor Biasing
Transistor Emitter Feedback Bias
IoT Project Ideas for Beginners - Internet of Things
100 IoT Project Ideas for Beginners – Internet of Things
