Reading: PLC Program for Conditional Control Logic
Inst Tools > Blog > Guest Articles > PLC Program for Conditional Control Logic
Create a PLC program for Conditional Control Logic. Find more PLC programming tutorials, PLC example programs and PLC ladder logic mcqs.
Last updated: November 3, 2023 9:51 am
Guest Articles PLC Tutorials
4 Comments
This is the PLC Program for Conditional Logic Circuit. The below example is based on the ladder logic using a programmable logic controller.
PLC Conditional Control LogicProblem DiagramProblem SolutionPLC Inputs ListPLC Outputs ListPLC Ladder diagram for conditional Control CircuitLadder Logic DescriptionRuntime Test Cases
In Industry or plants, there are lots of gearbox systems used for different machines/motors.
For smooth operation of gearbox motors, they need to be lubricated every time because good maintenance work can extend gearbox life.
But the problem is that operators often make mistakes during machine operation because in every gearbox motor mechanism, we need to start lubrication first and then the main gearbox mechanism should start.
So we have to implement a logic to make sure things are properly controlled from a PLC system.
Problem Diagram
Conditional Ladder Logic PLC
Note: For easy discussions, Local/Remote, or any other permissive interlocks are not considered in this example.
Problem Solution
Here we solve this problem by using a simple conditional logic example, in this example, there is one gearbox motor and we need to provide lubrication before starting it.
So for lubrication, we have a lubrication motor (also called as Oil Pump or Auxiliary Lube Oil Pump) and it will provide lubrication oil to the main motor or gearbox motor.
Also, we will provide an interlock system, so the operator cannot start/operate the Main motor directly without using proper lubrication otherwise the main motor may overheat and it may be damaged after some runs without proper care.
The operator has to switch ON oil pump first and then only he can able to operate the main motor.
By using this logic, we can take care of the gearbox motor for a long time run with proper lubrication.
Operators start/stop oil pump by using START and STOP push buttons of oil pump.
Both Oil Pump and Main Motor have separate individual START & STOP push buttons as shown in above diagram.
PLC Inputs List
  • Oil Pump StART PB : I0.0
  • Oil Pump STOP PB : I0.1
  • Main Motor START PB : I0.2
  • Main Motor STOP PB : I0.3
PLC Outputs List
  • Oil Pump Motor : Q0.0
  • Main Motor : Q0.1
PLC Ladder Logic for conditional Control Circuit
  • In this application, we used Siemens S7-1200 PLC and TIA Portal Software for programming. We can also design this logic with relay circuit.
  • This circuit is also known as conditional control circuit because second sequence is depended on first condition.
  • We will write logic for oil pump in Network 1. Here we will take NO contact of oil pump START PB (I0.0) and also we have to consider one NO contact of oil pump (Q.0) coil for latching START command.
  • Put NC contact of oil pump stop PB (I0.1) in series for unlatching the circuit by pressing oil pump STOP PB (I0.1), so operator can stop the oil pump (Q0.0).
  • Now write the logic for main motor in Network 2. Here we will take NO contact of main motor START PB (I0.2) and also take one more NO contact of the main motor coil for latching the main motor (Q0.1).
  • Put NC contact of main motor stop PB(I0.3) in series for unlatching the circuit by pressing the main motor STOP PB(I0.3), so operator can stop the main motor(Q0.1).
  • Put NO contact of oil pump (Q0.0) in series after the main motor START PB(I0.2) for interlocking. So that operator has to start oil pump (Q0.0) and then only he can START the main motor (Q0.1).
Runtime Test Cases
PLC Conditional Logic
Note: The above PLC Logic provided for basic idea about application of PLC Program for Conditional Control Logic. The Logic is limited and not complete application.
Author: Bhavesh
  • Field Instruments Interview Questions
  • PLC Water filling and Discharging Process
  • Sequential Motor Control using PLC
  • PLC Interview Questions and Answers
  • Overview of SCADA System
100 Electrical Circuit Breaker Quiz
PLC Controlled Conveyor and Weighing with Labeling Automation
Importance of Grounding Electronic Equipment
Pump and Mixer Operations Example: PLC Timer-Based Control
Difference Between PNP and NPN Sensors
Download Allen Bradley RSLogix PLC Software
4 Comments
  • D.N.Sharma says:
    May 22, 2018 at 7:04 pm
    Dear Sir,
    This is not foolproof logic.This is just a interlock with lot of loop holes.
  • Rahul Varma says:
    May 28, 2018 at 11:30 am
    Hi Sharma, I think the Author just explaining a simple example of conditional logic, not designing complete application/logic. Can You please share the loop holes, Thanks.
  • Bhavesh says:
    May 29, 2018 at 11:29 am
    Dear Sir,
    Sorry for inconvenience
    This is example for concept explanation of conditional circuit.
    It is not complete system.
  • Manish Wadia says:
    July 27, 2023 at 7:40 pm
    Simple but effective circuit for easy understanding… Thanxs to you. Bhavesh sir, please share more plc. Logic
How to Retrieve PLC Project From Memory Card?
Wiring in a PLC Control Panel
One Shot Rising and One Shot Falling Instructions in PLC
WHILE DO Statement in SCL Language
#4 PLC Best Practices – Use PLC Flags as Integrity Checks
Safety Considerations in PLC System Design
Instrumentation During the Detail Design Phase
Relay Internal Parts
Relay Operation, Types, Symbols & Characteristics
4-20mA Current Loop Components
Why Use a Current Loop?
PLC Program for Temperature Control using Thermostat
ON and OFF a Group of Outputs by One Push button PLC Logic
What is a Line Choke or Reactor in a VFD
What is a Line Choke or Reactor in a VFD?
PLC Program for Tank Heating Control using Heater
PLC Programming for Tank Heating Control using Heater
Bipolar Junction Transistors Questions & Answers
Measurement and Instrumentation Objective Questions – Part 1
Basic Power Electronics Interview Questions
Superheated Steam Temperature Control System
Memory Devices Objective Questions – Part 5
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Interview Questions for Instrument Engineers
Rectifiers & Converters MCQ
Rectifiers & Converters MCQ – Multiple Choice Questions
0 to 10 mA Current Loop
What is Live Zero in 4-20 mA Current Loop ?
