Reading: PLC Memory Organization – Data Files and Program Files
Inst Tools > Blog > PLC Tutorials > PLC Memory Organization – Data Files and Program Files
Memory in a PLC is divided majorly into two types – data files and program files. Learn PLC memory organization and structure.
Last updated: September 4, 2023 11:06 am
When you are working in a PLC system, you know that the most basic thing to take care of is memory. What program you write, and how much memory has been consumed; is a very important factors in determining PLC performance. For this, it is necessary to understand how memory structure is organized and defined in a PLC.
PLC Memory OrganizationData FilesProgram Files
PLC Memory Organization - Data Files and Program Files
Without knowledge of memory organization, it would be difficult to predict how much exact program you have to write. In this post, we will see memory organization in PLC. Memory in a PLC is divided majorly into two types – data files and program files.
Data Files
The data file is the location of memory which stores information like memory words, status words, input variables, output variables, communication variables, timers, counters, and other in-built library functions provided by the PLC manufacturer.
Let us have a look at each example one by one.
  1. Memory words – Memory words are Boolean variables, integer variables, double integer variables, and floating variables. Suppose a PLC has allocated 100 memory variables for usage. Out of these, only 5 variables are used. The first variable is bit type, storing either 0 or 1. The second variable is an integer, signed or unsigned. The third variable is also an integer. The fourth variable is a double integer, signed or unsigned. If a variable is a double integer or float, it consumes two memory variables. So, the fifth memory variable will be a double integer.
  2. Status words – Status words store information about PLC. It comes in two types – status bits and status integers.
  3. Input variables – They store data regarding digital inputs and analog inputs of the PLC.
  4. Output variables – They store data regarding digital outputs and analog outputs of the PLC.
  5. Communication variables – They store data regarding communication protocols used in PLC. They can be Modbus, Ethernet, Can-Open, etc.
Apart from these, other in-built libraries if used to come in data files memory. They are timers, counters, pulse blocks, etc.
Program Files
As the name defines, program files store data regarding logic written, subroutines, and interrupts. This is the main consuming part of memory in PLC. If the PLC code written is more, then program file consumption will be large and if the code written is less, then program file consumption will be less. All the logic, be it a ladder, functional block diagram, structured text, sequential flow chart, or instruction list, comes in program files memory.
Also, user-defined function blocks and user-defined data types come in program files.
Memory organization in PLC is stored in either internal storage or internal and external SD cards. When there arises a situation where the internal memory storage is getting full and you need more data for the writing PLC program, then you need to insert an external SD card for extending program memory.
In that case, both the data files and program files are extended. Many PLCs have an online animation window, which shows current memory usage. It can be viewed either online or offline. This helps in better memory planning.
  • Sequential PLC Programming
  • S7-1500 S7-1200 S7-400 S7-300
  • HMI Screen Design Applications
  • Static and Temp Variables in PLC
  • Power Supply Sizing for Systems
3 Phase Motor Control using PLC Ladder Logic
Best 100 PLC Projects for Final Year Engineering Students
What is Hot Standby in PLC?
Allen Bradley RSLogix 500 PLC Programming
What is Thin Client in SCADA? – Purpose, Advantages
Do’s and Don’ts in PLC
Types of Allen Bradley PLC
How to Solve Electrical Ground Loop Problems?
Structured Text PLC Example for Motor Interlocking and Control
Introduction to PLC – Advantages of PLC
#11 PLC Best Practices – Instrument for Plausibility Checks
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
Multiple Pumps Control using PLC
Ferrule Example
Ferrules and Cross Ferruling
Omron PLC washing machine automation
Omron PLC Logic for Washing Machine Automation
PLC Questions & Answers
Programmable Logic Controller Questions and Answers
Introduction to Schneider PLC
Different Types of Schneider PLC
How to Filter Digital and Analog Inputs in a PLC
How to Filter Digital and Analog Inputs in a PLC?
How to Test a Battery using Multimeter
How to Test a Battery using a Multimeter?
Strain Gauge Pressure Sensor Principle
Rotameter
What is a Variable Area Flow Meter?
Find the Fault in the Temperature Loop
FMCW Radar level transmitter Working Principle
FMCW Radar Level Transmitter Working Principle
Industrial Gases
Questions and Answers on Gas
Two SOV Connections
Two Solenoid Valves Working Principle
Identify which lamp in the following ladder-logic diagram
Identify High Flow Alarm and Low Flow Alarm?
