Reading: PLC Count values higher than 999
Inst Tools > Blog > PLC Tutorials > PLC Count values higher than 999
S counters has max allowed number to count is 999. Write a PLC program to count more than 999 counts for one counter.
Last updated: March 4, 2021 10:57 am
2 Min Read
As known about the S counters that the max allowed number to count is 999.
Inputs & outputsPLC Count values higher than 999
Note: the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Inputs & outputs
I0.0: count up
I0.1: preset value
Network 01
 There is a counter C0 and there is a count up contact I0.0, whenever a positive edge detected from the count up bit the counter value MW0 is increased by one.
A preset value is loaded the PV of the counter to ease the simulation process, where when the preset contact I0.1 is pressed for one time the counter value is loaded by 997.
Whenever the counter reaches 999 counts 2 things happen.
The reset memory bit M10.0 is energized and resets the counter to zero.
Then a value of 1 is added to the MW2 so that to count the number of each time the counter reaches the maximum counts 999.
Network 02
 Multiply MW2 by 999 so that every time the counter reaches the maximum a 999 counts is added to MW4.
For example if the counter reached the maximum counts twice then the counts value in MW4 is 1998.
Network 03
Add the MW4 to the current counts value of the counter gives the real counter counts calculated so far.
Author: Karim Ali Anwar
  • Cars Garage Counter
  • Automatic Packing of Bottles
  • Counter with Preset Value
  • PLC CPU Execute Program
  • Motor Stop Interlock
What is the DDE Protocol?
How to Blink Lights in Ladder Logic?
PLC Example on Switch Program with Timers
Basics of Ladder Diagram in PLC Programming
#4 PLC Best Practices – Use PLC Flags as Integrity Checks
Schneider Electric: Car Parking System with Calculations in PLC
PLC Logic GATE Program
Modbus Communication between Delta PLC with VFD
Programmable Logic Controller (PLC) Scan Time – Types, Theory
Allen Bradley Powerflex VFD
Siemens Drum block for Sequencer Operation
How to Read the PLC Datasheet? – Important Notes About PLC
Basic Arithmetic Programming in Mitsubishi PLC
Start the Counting from a Preset Value in PLC
What is Loop Checking
What is Loop Checking?
Industrial Automation and Control Systems (IACS)
Safety PLC Programming steps
Safety Door Interlock PLC Program
FBD Logic
Save and BR Memory in Siemens PLC Programming
SAVE and BR Memory Instructions in Siemens PLC Programming
OB10 Time of Day Interrupt
Tia Portal – OB10 Time of Day Interrupt Organization Block
Industrial Control Systems Security
DC Generator
DC Generator
Basic Components of HVAC System
Address Overlapping in Tia Portal
How to Check Address Overlapping in Tia Portal?
Common Causes of Imperfect Bends
Instrument Tube Fitting Installation – Part 3
Vibration Analysis
Top 100 Vibration Analysis Questions and Answers
OPC Communication Interview Questions Answers
OPC Communication Interview Questions and Answers
SCADA Standards
SCADA for Substation Automation
