Reading: PLC connected to Three Pushbutton Switches
Inst Tools > Blog > Practical Questions > PLC connected to Three Pushbutton Switches
Suppose we have a PLC connected to three pushbutton switches. Sketch a Ladder Diagram program for program example.
Last updated: February 12, 2021 9:53 pm
Practical Questions
1 Min Read
Suppose we have a PLC connected to three pushbutton switches as shown in this illustration:
PLC Circuit Answers
Sketch a Ladder Diagram program for this PLC to energize the lamp if the following input conditions are met:
  • Either switch A or switch B pressed
  • Switch C unpressed
Answer:
PLC Circuit ladder Answers
Share Your Answer / Comments
Pushbutton Example
Credits : by Tony R. Kuphaldt
  • Problem in the PLC Program
  • Troubleshooting PLC Inputs
  • Storage Area PLC Logic
  • PLC Sequential Operation
  • Do’s and Don’ts in PLC
Why Strain Gauge Resistance Changes as it Stretches and Shrinks?
Fisher model 546 I/P transducer
DP Transmitter Error Calculations
How Measurement Span of Pressure Gauge Could be Changed?
Calculate the 0%, 50%, and 100% Calibration Points
Overhead Product Pressure Control Loop
  • Santosh says:
    April 13, 2020 at 8:29 am
    The ladder u have shown .in answer is wrong …
PLC Programming Question & Answer
Oil and Air Pressure Actuated Lifts Questions
Double Block and Bleed Valves Opening or Closing Sequence
Process Control Loop Testing
Calculate Amount of Weight Indicated by the Scale
Motor Trip Logic using PLC Programming
Solenoid Valves Practical Problems
PSV lift pressure
Calculate PSV Lift Pressure
DP Transmitter Wet Leg Compensating Impulse Line
Questions on DP Transmitter Wet Leg Compensating Impulse Line
reactor vessel
Pneumatic Moment-balance Differential Pressure Transmitter
Galileo thermometer Principle
Galileo Thermometer
Float-type Level Switch for Sensing Low Oil Level
hydrostatic interface measurement calculation
Hydrostatic Pressure Measurement Questions
Problem on Solar Hot Air Collector and Variable Speed Fan
Weigh Feeder Drive
Failing Weigh Feeders and Mechanical Variable Speed Drives (VSD)
How to identify location of Fire Detectors
Ion Spectroscopy Questions & Answers
Nuclear Plant Sensors and Detectors Quiz
Electrical Symbols
Electrical Symbols
Resistive Transducers Objective Questions
Safety in Automation Systems
