Reading: PLC based Door Open and Closing System
Inst Tools > Blog > PLC Tutorials > PLC based Door Open and Closing System
Last updated: March 4, 2021 3:49 pm
2 Min Read
We have come across automatic door opening system in shopping malls; working of such automatic system using PLC based Door Open and Closing System.
PLC based Door Open and ClosingList of Inputs and OutputsPLC ProgramLogic DescriptionRUNG000RUNG001RUNG0002RUNG 0003Conclusion:
Inputs and Outputs for PLC based Door System
PLC Program
PLC Ladder Logic Door Open and Closing System
Logic Description
RUNG000
Latching rung to operate the system through Master Start and Stop PB.
RUNG001
When object detecting sensor detects people over there in a range,Will turn ON Opening door motor until open limit switch turned ON.
RUNG0002
In the absence of people in the range, Timer is used to give 10s to turn ON closing door motor
RUNG 0003
Closing motor turned ON until closed limit switch ON.
Note: For Interlocking, normally closed switch of open door motor and closed door motor is used in Rung 0002 and Rung 0003.
Conclusion:
The above explained automatic door opening system is for example only. It may vary from real time.
Author : Hema Sundaresan
Online Free Test on PLC
PLC Maintenance Points
PLC Sub Routines Program
Two tanks control using PLC
PLC Irrigation System
Sequential PLC Programming for the Pneumatic Valves
PLC Tag Naming Conventions
Alarm Acknowledge using PLC
Programmable Logic Controller Maintenance Check Points
What is Distributed IO? – Decentralized Peripherals in PLC
Why Use Normally-Closed Contact for Stop Buttons?
Will PLCs become obsolete?
Download Free HMI software – CODESYS
PLC Programming for Train Detection and Gate Operation
PID Simulator Download
Functional Block Diagram PLC Example for Traffic Light System
Offline UPS
UPS Working Principle and Types – Offline and Online UPS Systems
PLC Interlock Example
PLC Interlock Logic with First Input Priority
Mitsubishi PLC Programming Tutorials
Use of Comments in SCL Language
Allen Bradley PLC Example with Sub routines
How to use Sub Routines with Allen Bradley PLC
PLC Program to Drain Same Products from Two Tanks
PLC IO Examples
Quiz: Identifying I/O Examples in PLC Systems
car parking example logic
Up Down Counter Instruction in PLC
Control Valve Split Range Example - 2
Distributed Control Systems (DCS)
What is DCS? (Distributed Control System)
Home Heating
What Type of Heating is Best for Your Home?
Reactor Top lid lapped
Urea Reactor Top Bolted Plug developed Leaks
AI AO DI DO Signals
What are AI, AO, DI, and DO? – Definition, Examples, Purpose
Advantages of Industrial Automation
Advantages and Disadvantages of Industrial Automation
Industrial Process Plant Project Execution Cycle
Detail Design Engineering Competency Aspects
Belt Sway Switch Principle
Belt Sway Switch Working Principle
