Reading: Paint Mixing System
Inst Tools > Blog > Practical Questions > Paint Mixing System
Paint Mixing System
Last updated: March 11, 2020 9:36 am
Practical Questions
2 Min Read
This paint mixing system mixes (clear) base and (colored) pigment to achieve the desired coloring, according to the ratio setpoint:
Paint Mixing System
Paint Mixing System
1. Determine what will happen to the paint’s color over time if the pigment flowmeter turbine seizes so that it does not turn even when there is adequate flow through the pipe. Also, explain why the paint’s color will be affected as you predict.
Answer:
The paint will become more and more colored over time, as the control system turns up the flow of pigment. This will happen because the ratio control system sees no pigment flow anymore, and thus turns the pigment flow on fully to try to reach setpoint.
2. Determine what will happen to the paint’s color over time if the base flowmeter turbine seizes so that it does not turn even when there is adequate flow through the pipe. Also, explain why the paint’s color will be affected as you predict.
3. For those who have studied flow measurement, explain how a turbine flowmeter functions.
4. Explain what would happen in this process if the base control valve failed fully shut.
5. Explain what would happen in this process if the base control valve failed wide-open.
6. Explain what would happen in this process if the pigment control valve failed fully shut.
7. Explain what would happen in this process if the pigment control valve failed wide-open.
8. Explain what would happen in this process if the pigment flow controller (FC) was switched from remote setpoint to local setpoint.
Join the Discussion! Share your answers with us through below comments section.
  • Pressure and Level Control Loops
  • What is Anti Surge System?
  • Pneumatic Control Loop
  • Liquid Mixing Application
  • Pressure Control Loop
Electronic Force Balance Pressure Transmitter
Determine the functions of Pressure Switches ?
Determine the Instrument Calibration Error
Practical Process Control System Questions & Answers – 7
Identify Instrumentation Terms in Water Supply System
How to Decrease Span of Pressure Gauge?
  • Ahmed seif ahmed says:
    April 15, 2022 at 5:47 am
    Answer 2
    The paint will become no colored over time, as the control system fully turn off the flow of pigment. This will happen because the ratio control system sees no base flow anymore, and thus turn off the pigment flow fully to try to reach zero setpoint.
    Answers 3
    Turbine flow meters use the rotation of a rotor within a flow tube to translate the flow of liquid into a readable rate.
    The rotation of a pinwheel sensed magnetically. With magnetic sensors, the rotation of the turbine generates a “pulse” which is picked up by a sensor.
    Answer 4
    will become no colored paint over time, as base control Valve fail close and fully shut the control system sense no base flow and  turns off flow of pigment. This will happen because the ratio control system sees no base flow anymore, and thus turns the pigment flow off fully to try to reach zero setpoint.
    Answer 5
    will become maximum production and maximum colored paint over time, as base control Valve fail wide open and fully open the control system sense max base flow and  turns  flow of pigment on . This will happen because the ratio control system sees maximum base flow , and thus turns the pigment flow on  to try to reach to setpoint.
    Answer 6
    The paint will become no color over time, as the pigment control valve fully shut and turn the flow of pigment off . This will happen because the ratio control in good healthy but no responding from pigment control Valve and always fully shut
    Answer 7
    paint will become more and more colored over time, as pigment  control valve fully open make  the flow of pigment to maximum. This will happen because the ratio control system in good health but can’t control the pigment control valve, and thus the pigment flow will fully all time.
    Answer 8
    paint will become sometimes more and sometimes less colored over time,when switch from remote to local, the pigment  control valve will have always constant flow rate enev if base flowrate increased or decreased, due to local setpoint .
Electric-driven Air Compressor Troubleshooting
Solenoid Valves Questions & Answers – 4
Simulate Different Values for Pressure Instrument Under Test
Problem with Sump Tank Level Transmitter
Programmable Logic Controller (PLC) Questions and Answers – 14
Inspecting the Trends of PV and SP on a Process Chart Recorder
Importance of Temperature in Remote Seal Pressure Transmitter
Overhead Product Pressure Control Loop
Loop Powered Pressure Transmitter
What Effect on Hydrostatic Level Transmitter if Liquid Density Changes?
Foxboro pneumatic instruments
Pneumatic Force Balance Instrument
High and Low Ports on Pneumatic DP Transmitter
Identify High and Low Ports on Pneumatic DP Transmitter
Simple Pressure Repeater
Float-type Level Switch for Sensing Low Oil Level
thermocouple Transmitter Formula
Calculate Process Temperature using a Thermocouple
Three Phase Rectifiers Questions and Answers
Field Instrument package
What is a Thermostat
Thermostat – Types, Working Principle, Advantages, Applications
International Standards - Types and their Details
International Standards – Types and Their Details
Transparent Level Gauge
Level Indicators Working Principle
Differential Pressure Switch Working Principle
How to Select a pH and ORP Meter
How to Select a pH or ORP Meter
Induction Machine Circuit Quiz
