Reading: Oil and Air Pressure Actuated Lifts Questions
Inst Tools > Blog > Practical Questions > Oil and Air Pressure Actuated Lifts Questions
Two pressure-actuated lifts are used to raise a heavy weight off the ground. One lift uses oil under pressure while the other uses air.
Last updated: February 4, 2022 11:24 pm
Practical Questions
1 Min Read
Two pressure-actuated “lifts” are used to raise a heavy weight off the ground. One lift uses oil under pressure (from a hydraulic pump) while the other lift uses air under pressure (from an air compressor).
Each lift is equipped with a shut-off valve on the line feeding fluid to the cylinder, so that the piston’s motion may be halted:
What will happen if the weight were to fall off the lift platform after it had been raised up from ground level, in each case? Assume that the shut-off valve is closed (no fluid flow from the pump or compressor into the cylinder) when this happens.
Answer:
Hydraulic Actuated Lift
If the weight falls off the oil-actuated lift, the piston will hold its original position.
If the weight falls off the air-actuated lift, the piston will rise substantially (perhaps even ejecting from the cylinder!) due to expansion of the air.
  • Level Sensors Questions
  • Which Instrument is at Fault?
  • Level Measurement Lab Exercise
  • Instrument Salesperson Question
  • Steam Water Level Measurement
Credits: Tony R. Kuphaldt
Calculate the Height of Glycerine
Signal Strength of Guided-wave Radar Level Instrument
Identify Level Control Loop Tuning Problems
Programmable Logic Controller (PLC) Questions and Answers – 16
Find Thermocouple Ouput Voltage
Identify the Purpose of Flow Ratio Controller
Solenoid Valves Questions & Answers – 4
Investigate High Level Alarm of Distillation Process
Determine the Status of Lamps and Relays in the Circuit ?
Hydrostatic Pressure Measurement Questions
What Affect the Pressure Measurement Accuracy of a Manometer?
How to Connect Proximity Switch (Source Type) to Make LED ON ?
Calculate the appropriate millivoltage values of a Thermocouple
DP Transmitter Error Calculations
steadily pour a liquid into vertical tube
Vertical Tube Liquid Level Equilibrium
Which instrument is at fault in this system
Which Instrument is at Fault in this System?
Instrument Switch Status
Define Normal Status of a Process Switch ?
Solenoid Valves Questions & Answers – 3
Connect the Differential Pressure Gauge at the Filter
How Do You Connect the Differential Pressure Gauge at the Filter?
Remote Seal Pressure Transmitter Temperature
Importance of Temperature in Remote Seal Pressure Transmitter
Sump Tank Level Transmitter
Problem with Sump Tank Level Transmitter
pH Monitoring System Triggers an Alarm
Solar-Based Engineering Projects
Top 100 Solar-Based Engineering Projects
Power Systems MCQ Series 12
Video Borescope
5 Questions to Ask Before Choosing Your Industrial Borescope
PN Junction Quiz
PLC Program using One Shot Rising Instructions
One Shot Rising and One Shot Falling Instructions in PLC
Process Control & Instrumentation Objective Questions – Set 6
Control Valves Flow Direction
Control Valve Flow Direction
