Reading: Nutating Disc Flow Meters Working Principle
Inst Tools > Blog > Animation > Nutating Disc Flow Meters Working Principle
In Nutating disc flow meters, When fluid enters the chamber, it causes the disc to rotate and this is used to measure flow rate.
Last updated: October 31, 2023 4:10 pm
Animation Flow Measurement
3 Min Read
Nutating disc flow meters are one of the most common types of positive displacement flow meters. They operate by having a disc mounted to a central ball.
Nutating Disc Flow MetersHow does the Sensor pick up the Reading?Advantages of Nutating Disc Flow MetersDisadvantages of Nutating Disc Flow Meters
When fluid enters the chamber, it causes the disc to wobble (nutate), transferring the displaced volume to the register.
Something to keep in mind is that due to the nutating discs’ nature, the accuracy of this type of flow meter can be adversely affected by fluctuations in liquid viscosity.
NUTATING DISC FLOW METERS ANIMATION
Liquid enters a precision-machined chamber containing a disc that nutates (wobbles). The position of the disc divides the chamber into compartments containing an exact volume. Liquid pressure drives the disc to wobble and a roller cam causes the nutating disc to make a complete cycle.
This motion is translated into rotary motion by means of a ball and shaft, which is attached to the disc. The movements of the disc are transmitted by a gear train to an indicator/totalizer or pulse transmitter.
There are inherently more leakage paths in this design and it tends to be used where longer flow meter life is required rather than high performance; however, close clearances between the disc and chamber ensure minimum leakage for accurate and repeatable measure of each volume cycle.
Nutating Disc Flow Meters Working Animation
A disc attached to a sphere is mounted inside a spherical chamber. As fluid flows through the chamber, the disc and sphere unit nutates. The nutation causes a pin, mounted on the sphere perpendicular to the disc, to rock.
Each revolution of the pin indicates a fixed volume of liquid has passed. A mechanical or electromagnetic sensor detects the rocking of the pin and the flow is measured.
Nutating Flow Meters
These flow meters may use a Hall sensor to sense the rotation and the same was converted into equivalent flow.
Also Read: How Hall Sensor Works?
  • May be constructed from a variety of materials.
  • High accuracy and repeatability.
  • Accuracy is adversely affected by viscosities below the meter’s designated threshold.
  • Vortex Flow Meter Sensors
  • Flow Meter Installation
  • Chart Recorder Flow Measure
  • What is a Hot Wire Anemometer
  • Flow Meter Calibration
Electromagnetic Flow Meters Working Principle
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
What is a Torbar? – Averaging Pitot Tubes
Pitot Tube Problems and Troubleshooting Steps – Flow Instrument
Fundamentals of DC Motor Animation
Thermal Mass Flow Meter – Principle, Advantages, Applications
  • jmw says:
    February 5, 2020 at 11:49 pm
    The proper designation for the nutating disc meter is as a “Semi-Positive Displacement meter and it is not a true PD meter due to the creation of open flow paths between inlet and outlet during the two transitions which allow a significant amount of unregistered flow.
    The same is true of the rotary or oscillating piston meter though it has become increasingly common to refer to them as such. These two meters are the limit geometric forms of the conic meters. By the beginning of the 20th century when most meters were for utility metering, there were three classes identified, inferential or rotary vane meters (Single jet and multi jet) displacement meters , nutating disc and rotary piston, and Positive displacement meters, reciprocating piston, sliding vane, birotors etc etc..
    Incidentally the last animation uses ports found in the earliest application of the principal, not as a flow meter but as a hydraulic engine patented in 1821 (http://www.dakeynediscengine.com/the-disc-engine.html …… which uses this same animation).The patents by Lewis nash in the 1880s delivered this as a flow meter almost fully finished, requiring only the change to a brass hub to be successful. The protgeometry was considerably different by then.
Pressure based Flow Meters
Magnetic Float Level Switch Working Animation
How a 4-20mA Transmitter Works?
Why Flow is Directly Proportional to the Square Root of DP?
Scintillation Counter Principle
PID Controller Gains Effect on Manipulated Variable
What is an Orifice Meter?
What is a Square Root Extractor? – DP Flow Measurement
Coriolis flow meter sensor coils
Coriolis Flow Meter Construction
magnetic flow meter parts
What is a Magnetic Flow Meter?
Turbine Flow meter calibration
Piston Flow Meters Working Animation
Piston Flow Meters Working Principle with Animation
Difference between Fixed Area and Variable Area FlowMeters
Difference between Fixed Area & Variable Area FlowMeters
Velocity-based Flowmeter
What is a Velocity-based Flow Meter?
Custody Transfer Meter Checks
Checklist for Custody Transfer Meters: Mass Flowmeter
Sinking and Sourcing Devices Operation
Mitsubishi FX series programming basics
How to Write and Read a Program for Mitsubishi FX3U PLC?
Calculate Power in Series RC Circuit
IEC Area Classification System
Distribution transformer
Types of Transformers
PLC Ladder Logic Questions and Answers
Top 100 Microcontrollers Project Ideas
Motor Control Center Purpose
Motor Control Center – Purpose, Classification, and Advantages
Gas Solid Chromatography Questions & Answers
