Reading: Difference Between Normal Counters and Fast Counters – Learn PLC
Inst Tools > Blog > PLC Tutorials > Difference Between Normal Counters and Fast Counters – Learn PLC
In this article, we will learn the difference between normal counters and fast counters in PLC programming.
Last updated: June 17, 2023 5:09 pm
PLC programming has many types of instructions and operands in it for executing logic. One of the most used instructions is a counter.
What is a Normal Counter?What is a Fast Counter?
A counter is used for counting numbers. Counting is required for many applications; for example, even a small logic like counting the number of bottles passed in a minute requires a counter for it. If such a small application needs a counter in it, then automation technologies have many bigger types of logic in it which use counters for use. So, these are important types of instructions used in PLC programming.
There are two categories of counters available – normal counters and step counters. In this post, we will learn the difference between normal counters and fast counters.
There is no official term called a normal counter in PLC. It is just a definition used to show the two basic types of counters – step up and step down. As the name implies, these instructions are used to count numbers when it is given an input pulse.
Suppose you have a push button and you want to count how many times it has been pressed. If you understand what we are trying to convey, push means it will remain on as long as it is pushed. As soon as you remove it, it goes off.
This means it is a pulse-type input, and the counter understands only such types of input. If the input remains continuously on, then it will not count. It counts only when the input goes from on to off state, and then again repeats the same sequence.
Difference Between Normal Counters and Fast Counters - PLC Basics
Refer to the above image for understanding. CU (count up) input is used to increment the counter whenever input is received. As it is a trigger, the count increments when a pulse-type input is received. PV input is the set value. As long as the set counts are not achieved, then the output of the counter (Q) will remain off. When the set value is reached, then the output turns on.
Now, even if the count input is given, the count will go on incrementing and the output will remain on. To turn it off, reset input is to be given which resets the counter and makes the current value zero. This is the general working of the counter.
The fast counter is the same as a normal counter, but the only difference is that it counts very fast types of inputs. Suppose you have a proximity sensor, which turns on or off for example 1000 times in 30 seconds. Such fast inputs are difficult to detect in a normal counter, as it has a lower scan time. The fast counter will do this job by counting the number of pulses received at its input in a quick manner.
Similar to a normal counter, its output turns on after a set value is achieved, and it requires a reset input to reset the counter and turn off the output. The fast counter can work in frequencies of 5 kHz.
Because Fast Counter function blocks are managed by specific hardware interrupts, maintaining maximum frequency sampling rates may vary depending on your specific application and hardware configuration. Not all PLC inputs can be used as fast counters; it has only some dedicated PLC inputs for assigning a fast count function.
As you can see, the only difference between both these counters is the speed of functioning, as a normal counter cannot accept any fast type of input.
  • How to Read the PLC Datasheet?
  • Memory Bits in Siemens PLC
  • FIFO and LIFO Sequences in PLC
  • PLC Start-up Organization Block
  • Why 24 Volts DC Power Supply?
PLC Programming for Baking with Auto and Manual Modes
PLC Program for Boolean Expression
Example of Controlling the PLC Output using Push Buttons
Flip-Flop PLC Programming: Lights with Adjustable Timers
PID Controllers in Closed Loop Control Systems – PLC Basics
Making Multi Way Switches using PLC
The Concept of Shift Register in Omron PLC with Example
Difference Between PNP and NPN Sensors
Relay Operation, Types, Symbols & Characteristics
PLC Functional Block Diagram for Logic Gates
Types of Digital Outputs in PLC
Mixing Program with Timers and Counters in Omron PLC
Introduction to Functional Block Diagram in Studio 5000
How to troubleshoot the PLC Hardware faults
Instrumentation and Control Project Packages
Site Acceptance Test (SAT) of PLC System
PLC System Site Acceptance Test (SAT)
Top Free PLC Software
PLC Latching circuit Animation
What is Seal-in Circuit ?
3 to 8 Line Decoder Circuit Diagram
3 to 8 Line Decoder PLC Ladder Diagram
PLC Program for Automatic Heating and Mixing of Products
Heating and Mixing of Products using PLC Example Tutorial
Save and BR Memory in Siemens PLC Programming
SAVE and BR Memory Instructions in Siemens PLC Programming
Squirrel Cage Induction Motor Synchronous View
Squirrel Cage Induction Motor Animation
Impulse Steam Trap
Impulse Steam Trap
Ziegler-Nichols closed-loop Tuning - 1
Heuristic PID Tuning Method
Calculate Resistance from Temperature for RTD
RTD Calculator : Calculate Resistance from Temperature
Shunt-Wound DC Generator Principle
Shunt-Wound DC Generators
Potentiometer Animation
Potentiometer Working Principle Animation
Programmable Logic Controller (PLC)
What is Interposing Relay in a PLC System ?
Surface Condenser Condensate Evacuation Pumps
Condensate Pump Frequent Wrecks Threatens Long Plant Outages
