Reading: Memory Structure of Siemens PLC
Inst Tools > Blog > PLC Tutorials > Memory Structure of Siemens PLC
Last updated: March 4, 2021 12:12 pm
The memory structure of Siemens PLC
Memory Types in Siemens PLCLoad MemoryInternal Load Memory:External Load Memory:Working Memory:System Memory:Retentive Memory:
First of all, let’s take a short look at all the types of Memories in general
  • RAM: Random Access memory that is used in computers and most of the electronic devices why it’s called that? Because it’s not required to allocate a physical location of memory when performing an operation or data transitions which accelerate the process and saves time.
RAM Memory
But in case of electricity cut off all the stored data in the RAM are lost.
  • ROM: Read Only Memory, it’s non-volatile memory where the stored are readable but can’t be modified.
  • EPROM: Erasable Read Only Memory it’s the same as ROM but the stored data can be edited, removed, and store new changes by exposing it to ultraviolet light.
EEPROM Memory Chips
But the Way of UV exposure is a very difficult and complicated method.
  • EEPROM: Electrically Erasable Programmable Read-Only Memory
It looks like the EPROM but the way of editing, removing, and store new changes for the data is done electrically not by UV light, But the number of erasing and editing it is limited by a certain number of times.
  • Flash EPROM: it looks like the EEPROM but it can be erased or edited by the unlimited time of numbers.
In general, the S7 PLC memory is composed of 4 parts
S7 PLC memory
Load Memory
Stores any data downloaded from the PC to the PLC, this means that any PLC program downloaded to the PLC is stored in the Load Memory.
There are two types of Load Memory
  • Internal Load Memory.
  • External Load Memory.
it was used in the old versions of S7 PLCs in which the memory was a RAM and hence in case of power loss all the stored data in the load memory were lost, for this reason, it was mandatory to have a backup battery in order to prevent data loss.
in the new versions of S7 PLCs, the load memory is external and can be purchased separately and it’s called MMC (Micro Memory Card), but in this case the CPU can’t run without the MMC installed.
Simatic Micro Memory Card
Working Memory:
It’s part of memory where it can store the executive part of the PLC program, it looks like the RAM in the Computer, and in this case, the load memory is the hard disk.
System Memory:
It’s part of the memory where it can store the addressing part of the PLC program like Inputs, Outputs, Timers, Counters, and Bit memory.
Retentive Memory:
It’s part of the memory where it can store data permanently, for instance, if you want to keep the data in specific bit memory stored permanently where in the case of electricity cut off this bit memory is not impacted.
Author: Karim Ali Anwar
  • Pulse Generation in Siemens PLC
  • Temperature Alarms monitor in PLC
  • Upload Siemens PLC Programs
  • InTouch Scada Scripting
  • Programmable Logic Controller
Proper Earthing Practices Used for PLC Control Panel
Distributed IO Sharing Between PLC Systems – Technical Insights
Automatic Railway Crossing Gate Control PLC Program
How to Create New Project Using Simatic Manager
What is CODESYS? Why Do You Need to Learn it?
Site Commissioning Steps for PLC Programmers
Use of Isolators and Barriers in Electrical Panel
PLC System Site Acceptance Test (SAT)
Flood Warning System using Programmable Logic Controller
Reading Clock data in PLC
Real-Time Clock in Omron PLC? – CX Programmer
0 to 10 mA Current Loop
What is Live Zero in 4-20 mA Current Loop?
How to Run Multiple Motors with a Single VFD
How to Run Multiple Motors with a Single VFD?
Types of Switches
Electrical Switches Principle & Types
Applications of SCADA
PLC Program for Star Delta Starter using Functional Block Diagram
How to program a running hours meter in PLC
Allen Bradley Studio 5000: Motor Running Hours PLC Program
Process Control Fundamentals
Turbine Meter in Gas Metering System
Read Gas Composition from Gas Metering System using RS485 Protocol
Electric Circuits Objective Questions – Set 16
Electric Circuits Objective Questions – Set 10
Cybersecurity Projects for Engineering Students
Fieldbus Interview Questions
Interview Questions on Fieldbus Communication
Calibration of Measuring Instruments
Calibration of Measuring Instruments – Significance, Costs & Risks
How a PLC communicates with Transmitters
How PLC Reads the Data from Field Transmitters
