Reading: PLC SCL Program for Marking Machine
Inst Tools > Blog > PLC Tutorials > PLC SCL Program for Marking Machine
Learn how to program a marking machine using SCL (Structured Control) language. Understand the components and logic behind this process.
Last updated: December 16, 2024 10:02 am
6 Min Read
In this post, we will write a sample logic for a marking machine using SCL (Structured Control Language) language.
Marking MachineProgram InterlocksInputs and OutputsPLC SCL Program
Marking Machine
Let us first understand the case scenario. Refer to the below image. There are the following components used – start push button, stop push button, conveyor, bottle sensor, cylinder, cylinder up sensor, and cylinder down sensor.
The conveyor is a DOL starter. When the user presses the start button, the conveyor starts to run at a fixed speed (because there is no VFD). The conveyor is carrying bottles on it. When a bottle is sensed near the bottle sensor point, the conveyor stops.
The bottle comes just below the cylinder. When the cylinder up position is active, then the cylinder comes down till the down sensor is sensed. When the down sensor is sensed, after a time delay, the cylinder moves up until the up sensor is sensed. When the up sensor is sensed, the cylinder output stops. After a time delay, the conveyor starts again and the cycle continues.
Program Interlocks
Following are the interlocks for running the conveyor – the up sensor must be sensed, the conveyor must be healthy and not tripped, and the bottle sensor must not be sensed.
If any of the above conditions fails, then the conveyor will not run.
Following is the only interlock for operating the cylinder – the conveyor should be in stop condition.
Inputs and Outputs
Following are the PLC IO’s according to our requirement:
  1. Digital inputs – start PB, stop PB, conveyor run feedback, bottle sensor, up sensor, and down sensor.
  2. Digital outputs – conveyor and cylinder.
Marking Machine
PLC SCL Program
Let us write the logic now. We are using Rockwell PLC (Studio 5000) for practicing this. Refer to the below image. We will now study the logic line by line and see how it is in line with our requirements.
First, we will write the logic for interlocking the conveyor. As you can see, if the system is not running or there is no up sensor or the conveyor is tripped or the bottle is sensed, then the conveyor will not run.
Secondly, we will write the logic for interlocking the cylinder. As you can see, if the system is not running or the conveyor is on, then the cylinder will not operate.
Next, we start and stop the system according to the push buttons pressed. On pressing start, we latch the system running bit, and on pressing stop, we unlatch the system running bit.
Then, we start the conveyor. If there is no conveyor interlock, then the conveyor will turn on, else it will remain off.
Now, we have to stop the conveyor from sensing a bottle. So, as the bottle is sensed, we turn on a bit named bottle sensed and stop the conveyor written earlier. You can see in the first image the distance between bottle sensor and cylinder. This is because the conveyor will not stop immediately; it will take 2-3 seconds. So, the cylinder is placed in the position where the bottle will reach exactly after stopping the run command of the conveyor.
Now, we operate the cylinder in the down direction after a delay of 5 seconds. So, if there is no cylinder interlock present and the bottle is sensed and the down sensor is not active, then we take the cylinder down.
When the down sensor is sensed, then we turn on a bit named down sensed for turning off the cylinder down action.
Now, we operate the cylinder in the up direction after a delay of 5 seconds. So, if there is no cylinder interlock present and the bottle is sensed and the down sensor is sensed and no up sensor is sensed, then we take the cylinder up.
When the up sensor is sensed, then we turn on a bit named up sensed for turning off the cylinder up action.
With this action, after a delay of 5 seconds, we reset all the logic and restart the conveyor once again to mark the bottles by cylinder action.
In this way, we saw how to write a PLC program for a marking machine using SCL.
  • PLC Program for Sequential Motor Control
  • Sequential PLC Program Pneumatic Valve
  • PLC Program for Water Level Control Logic
  • Structured Text PLC for Sequential Process
  • Write a PLC Program for Selector Machine
PLC Counter Instructions
Elevator PLC Ladder Logic
Steps in PLC System Design
Toggle Switch & Sensor: Conveyor and Puncher PLC Program
Basic PLC Ladder Programming Example
Pulse Generation using Timer in Siemens PLC
DeMorgan’s Theorems using Ladder Diagram
What is Profinet and How to Configure in Siemens PLC?
What is Human Machine Interface (HMI) ?
1 to 8 Demultiplexer PLC ladder diagram
PLC Analog I/O and Network I/O
Cybersecurity in PLC
How to Update the Firmware Version of your PLC
How to Update the Firmware Version of your PLC? – TIA Portal
PLC Program using START & STOP Buttons
PLC Program using START and STOP Buttons
Code Simulation of Safety Circuit
Feedback Monitoring in Safety PLC
Real-time and historical SCADA Trends
What are Trends in SCADA?
How to Create DFB in Schneider PLC? – Derived Function Block
Most Asked Questions on SCADA
Most Asked Questions on SCADA with Answers
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Field Instrument 4-20mA Calculation
How to do 4-20mA Conversions Easily
How to Select a Flow Meter
Types of Heat Exchangers
Overview of Resistor
The Information About Resistor Color Code You Should Know
What is a Servo Valve?
What is a Servo Valve? – Principle and Advantages
field-mounted thermocouple
Thermocouple Extension Wires
Sample Schematic Template for Systems Architecture Diagram
