Reading: Loop Controller HART Signal Noise
Inst Tools > Blog > Control Systems > Loop Controller HART Signal Noise
Last updated: July 29, 2020 6:47 pm
Control Systems
3 Min Read
In this system a loop controller receives a process variable signal from a 2-wire (loop-powered) transmitter, and sends its own 4-20 mA control signal to operate a control valve.
A data acquisition unit (DAQ) performs the auxiliary function of monitoring the process variable signal (voltage dropped across the loop resistor) and reporting it over a digital network where it is recorded on the hard drive of a personal computer. If it helps, you may think of a DAQ as being nothing more than a multi-channel voltmeter, sensing voltage between each of its input terminals (In 1, In 2) and its “common” (Com) terminal:
2-wire loop-powered transmitter
Unfortunately, the DAQ not only registers the DC signal value, but also any HART pulses present in the transmitter circuit whenever a technician connects a HART communicator to the transmitter to do any maintenance work. The operators are annoyed by the misleading “noise” on the DAQ-recorded signal whenever a technician does routine work on that transmitter, and so they come to you asking for a solution.
Devise a simple modification to this circuit that will eliminiate (or at least minimize) the “HART noise” seen by the DAQ without impeding its ability to record normal process variable signal values.
Solution:
A simple resistor-capacitor low-pass filter connected between the resistor and the DAQ channel will suffice:
The values of R and C should be chosen to create a cutoff frequency lower than the lowest frequency expected with HART (1200 Hz), but not so low that relevant changes in the process variable would be excessively damped.
Beware of any solutions that would shunt HART signals around the 250 ohm loop resistance, such as a capacitor connected in parallel with DAQ input! This would solve the HART interference problem, but at the cost of impeding all HART communication!
Share your opinion on this topic with us through comments.
Credits: Tony R. Kuphaldt
  • Configure HART Transmitter
  • HART Communication Problems
  • 4-20 mA Transmitter Voltage drop
  • Sensor Trim in HART
  • DCS System Layout
  • 250 ohms Resistor for HART
Centralized vs Decentralized Automation Systems
Integral Controller Principle
What are the Interlocks for Steam Turbine?
Remote Functions in Industrial Control Systems (ICS)
Power Factor Controller (PFC) – Commissioning
DeltaV System Configuration Changes and Download
Manufacturing Execution System (MES) in Industrial Automation
How to Solve Electrical Ground Loop Problems?
How to Create a Project in LabVIEW?
What is Wellhead Control Panel?
Problem in Water Level Control System
DCS System Cabinet
Yokogawa DCS System Maintenance Procedures
Patch Panel
Single Loop Control
Cascade Control Principle
Identify Instruments in Piping and instrumentation Diagram
Basics of Loop Checks
feedforward control theory
Proportioning Feedforward action
Python in Industrial Automation
Python in Industrial Automation and Control Systems
Ziegler-Nichols closed-loop Tuning - 1
Heuristic PID Tuning Method
Filtering and Dynamic Compensation Objective Questions
Career Opportunities in Instrumentation Engineering
Job and Career Opportunities in Instrumentation Engineering
Pressure Measurement Objective Questions
Electric Circuits Objective Questions – Set 8
Studio 5000 Programming Three Motors with Fixed Priorities
Studio 5000: Programming Three Motors with Fixed Priorities
BJT Amplifiers Interview Questions & Answers
Power Systems MCQ Series 14
