Reading: How to Do Linear Programming in Excel?
Inst Tools > Blog > Common > How to Do Linear Programming in Excel?
Linear programming is a type of mathematical modeling involving linear functions. Learn how to use Excel to do linear programming.
Last updated: February 24, 2023 1:02 pm
Common
7 Min Read
Spreadsheets are a few people’s ideas of fun. Indeed, of all the major productivity software, spreadsheets like those in Microsoft Excel are among the least loved and most dreaded.
What is Linear Programming?Microsoft ExcelUsing Excel for Linear Programming
Many people will do everything in their power to avoid Excel unless absolutely necessary, and the number of people who have proficient skills working in Microsoft Excel is decidedly lower than those who are proficient in Word, PowerPoint, or other productivity software. However, there is much more that you can do with Excel than simply bookkeeping, so it is often worth the effort to learn how to maximize your Excel skills.
In this article, we’ll take a look at how to use Excel to do linear programming. Wait, you say, you mean that Excel can do linear programming? Yes, it can! And it’s easier than you might think.
Before we get started, let’s talk a little bit about what linear programming is and how to do linear programming in Excel.
So, what is linear programming? Linear programming is a type of mathematical modeling involving linear functions.
In linear programming, you subject a function to different types of constraints in order to minimize or maximize the function.
For example, imagine that you work for a delivery service and need to deliver fifty packages while simultaneously traveling the shortest distance and saving the most fuel.
When you use linear programming, you use decision variables, an objective function, constraints, and non-negative restrictions to calculate the desired outcome. By using linear programming, you can calculate the exact route that will yield the most efficient travel plan.
When you engage in linear programming, there are five basic steps that allow you to make the calculation:
  1. Identify the decision variables – what variables affect the outcome?
  2. Formulate the objective function. Determine what needs to be calculated and whether the function must be minimized or maximized to achieve the result.
  3. Identify the constraints.
  4. Ensure decision variables are greater than or equal to 0.
  5. Solve the linear programming problem – this is the hard part!
While Microsoft Excel isn’t able to identify variables and formulate the function for you, it can help you to solve the linear programming problem more easily.
Let’s look at how.
Microsoft Excel
Microsoft Excel is best known as a spreadsheet program for record-keeping, but beneath the boring office work surface, Excel is much more than a digital ledger. The company actually describes its product as a “powerful data visualization and analysis tool.”
Microsoft Excel empowers users to use Excel as a one-stop shop for working with all manner of data and processing it into usable information.
Indeed, Excel goes beyond just a spreadsheet to offer graphing options, pivot tables, calculation and computation abilities, and a macro programming language. There are more than 480 functions currently available in Microsoft Excel.
Given the power of Excel, it’s no wonder that Excel can help with linear programming. Let’s examine how to do linear programming in Excel in detail.
Microsoft Excel has a native linear programming solution that can help you to solve linear programming problems with minimal effort. In order to take advantage of this tool, there are a few steps to follow.
Note: Before you begin to do linear programming in Excel, you will need to have identified your problem, constraints, and objective function. If you need Excel homework assignment help with any step of the programming process, including the identification of these aspects, you may find it beneficial to contact online experts who are trained to assist with thorny Excel issues and turn problems into solutions. There are many online services that can help with Excel homework problems.
Once you know what you need to do, the next steps are fairly straightforward for doing linear programming in Excel effectively:
  1. Begin by entering the problem constraints and the objective functions into a fresh Excel worksheet. Make a new row for each constraint, with the coefficients in the columns corresponding to the decision variables. Be sure to enter the objective function in its own row as well, with the coefficients in the columns corresponding to the decision variables.
  2. After you have finished inputting the problem, use the “Data” tab in Excel to select “Solver” from the “Analysis” group. This will give you access to the linear programming tool.
  3. Once you have navigated to “Solver,” in the “Parameters” dialog box, choose whether to minimize or maximize the objective function and then select the cells that contain the objective function coefficients.
  4. Your next step will be to set the constraints by selecting the cells containing the coefficients for each constraint and placing the constraints in the “value” field.
  5. Following this, you will set the decision variables by selecting the “By Changing Variable Cells” field and selecting decision variable value cells.
  6. Complete your programming by selecting the method used to solve it, such as Simplex LP. Excel will then calculate the optimal solution and values of the decision variables.
  7. Depending on the outcome and your needs, you can set additional options for solving the problem, such as constraints on decision variables, altering the tolerance for the solution, or limiting the time it takes to complete a solution.
For many linear programming problems, you don’t need to go through all of these steps on your own to do linear programming in Microsoft Excel. Many online sites offer model spreadsheets with preformatted linear programming models built in.
When using a template, all you have to do is fill in the boxes and solve! It’s that simple: You can have a linear programming problem solved in minutes, provided you know the constraints and functions you need.
Level Measurement and Control using Arduino C
An Overview of Metrology Tools for CNC Machining
Combustion Control – Series and Parallel Air-Fuel Ratio Control
Belt Conveyor Weighing System – Weigh Bridge – Speed Sensor
Capping Machine – 5 Aspects of Control Systems and Automation
Most General Reasons for the Electrical Motor Failures
What is an Instrument Skid? – Example of Metering Skid
Various Codes used in CNC Programming
Top 3 Online Bachelor’s Programs in Electronics Engineering
Components of Water Treatment Plant
Why is Instrumentation used in Industries?
International Standards – Types and Their Details
Difference Between Skin Effect and Proximity Effect
Electrical Torsion Meter Principle
Hazard Identification and Risk Assessment
importance-of-device-diagnostics
Importance of Device Diagnostics
Vision Camera System
Vision Camera Systems in Industrial Automation
What is a Spare Part
What is a Spare Part? Classification, Cost, Critical Inventory
Electrification in Mining Industry
GPS Fleet Tracking Software
What’s the Best GPS Fleet Tracking Software and Systems?
5 Valve manifold
5 Valve Manifold Operation
Technology is Shaping the Future of Education
How Technology is Shaping the Future of Education?
Bernoulli's Principle
Bernoulli’s Principle and Equation – Flow Measurement
Diagram of Oscillator Circuit
Barkhausen Criterion
Flow Measurement Questions
MCQ on Flow Measurement
PLC Program Example - Signal Lamp Task
PLC Program Examples
Inductive Time Constant
Pictorial Fluid Power Diagram
Hydraulic and Pneumatic P&ID Diagrams and Schematics
Zigzag Transformers Theory
PLC Water Project
Smart Spray System using Wecon PLC
