Reading: Top 50 Limit Switch Questions and Answers
Inst Tools > Blog > Electrical MCQ > Top 50 Limit Switch Questions and Answers
Prepare for your exams with the top 50 limit switch questions and answers to learn about different types, functions, and applications.
Last updated: July 25, 2024 4:45 am
Electrical MCQ Instrumentation MCQ
18 Min Read
Limit Switch Questions and AnswersWhat is the primary function of a limit switch?What is the role of the actuator in a mechanical limit switch?Which component of a mechanical limit switch houses the internal parts?What is the purpose of the return spring in a mechanical limit switch?What are the contacts in a mechanical limit switch responsible for?Which part of a mechanical limit switch is directly moved by the object being detected?How do the terminals function in a mechanical limit switch?What material is commonly used for the contacts in a mechanical limit switch?What role does the lever play in a lever-type mechanical limit switch?Why is the enclosure rating important for the housing of a mechanical limit switch?How does the plunger function in a plunger-type mechanical limit switch?What ensures the mechanical limit switch returns to its original position?How do the mounting holes in a mechanical limit switch housing function?What is the purpose of the cam in some mechanical limit switches?Why are roller actuators used in mechanical limit switches?What is the role of the contact block in a mechanical limit switch?What type of environment poses a challenge for mechanical limit switches?Why are limit switches important in safety applications?What is the primary disadvantage of mechanical limit switches?Which industry heavily relies on limit switches for safety and automation?What kind of actuator might a mechanical limit switch use?Which component protects a limit switch from environmental hazards?In which application are limit switches crucial for ensuring operator safety?What is the benefit of adjustable limit switches?What is the significance of the IP rating for a limit switch?Common Questions About Limit Switch SpecificationsWhat does the term “rated operational current” specify in a limit switch?Which factor primarily affects the mechanical lifespan of a limit switch?What does the “actuation force” specification refer to in a limit switch?How is the “contact resistance” specification important for a limit switch?What does the “pretravel” specification indicate in a limit switch?Why is the “differential travel” specification crucial in limit switches?What does “overtravel” specify in a limit switch?What does “reset point” refer to in the limit switches?What does the term “snap action” imply in limit switch specifications?How is “switching frequency” defined in limit switch specifications?What is indicated by the “operating temperature range” of a limit switch?What does “mechanical endurance” specify in a limit switch?Why is “contact material” important in limit switch specifications?What does “contact configuration” describe in a limit switch?How does the “insulation resistance” specification affect a limit switch?What does the term “dielectric strength” refer to in limit switch specs?Why is the “maximum switching speed” specification important for a limit switch?What does the “response time” specification indicate in a limit switch?How does the “resetting force” specification affect limit switch performance?What is meant by “operating position” in limit switch specifications?What does the “shock resistance” specification ensure for a limit switch?What does “contact rating” specify in a limit switch?Which factor does the “mounting type” specification address in a limit switch?What material is typically used for the contacts in a limit switch?Which component of a limit switch determines its actuation force?
The following limit switch video provides the explanations for the first 25 questions.
Basics of Limit Switch - Electrical and Electronics Engineering Questions
Question 1
A. To detect the presence or absence of an object without contact
B. To control motor speed in the industries
C. To limit the power supply for an equipment
D. To detect the presence or absence of an object with contact
Show the Answer
Question 2
A. To detect magnetic fields
B. To measure temperature
C. To physically move to activate contacts
D. To generate electrical signals
Show the Answer
Question 3
A. Terminals
B. Housing
C. Contacts
D. Actuator
Show the Answer
Housing
Question 4
A. To keep the contacts open
B. To enhance electrical conductivity
C. To measure pressure
D. To reset the actuator after activation
Show the Answer
Question 5
A. Detecting physical movement
B. Generating magnetic fields
C. Opening or closing the electrical circuit
D. Providing tactile feedback
Show the Answer
Question 6
A. Housing
B. Contacts
C. Actuator
D. Terminals
Show the Answer
Actuator
Question 7
A. They reset the actuator
B. They provide connection points for wiring
C. They sense magnetic fields
D. They generate light beams
Show the Answer
Question 8
A. Rubber
B. Plastic
C. Wood
D. Copper
Show the Answer
Copper
Question 9
A. It measures current
B. It amplifies the motion of the actuator
C. It detects magnetic fields
D. It generates electrical signals
Show the Answer
Question 10
A. It determines the switch’s electrical load
B. It indicates the color of the switch
C. It specifies protection against dust and water
D. It shows the switch’s weight
Show the Answer
Question 11
A. It senses changes in capacitance
B. It emits light to detect objects
C. It measures temperature
D. It moves up and down to activate the contacts
Show the Answer
Question 12
A. Terminal
B. Return spring
C. Contact block
D. Actuator
Show the Answer
Return spring
Question 13
A. They secure the switch in place
B. They act as ventilation points
C. They provide electrical connections
D. They allow for actuator adjustment
Show the Answer
Question 14
A. To measure current flow
B. To act as a sensor for magnetic fields
C. To detect temperature changes
D. To convert rotational motion to linear motion
Show the Answer
Question 15
A. To increase the electrical load capacity
B. To detect changes in light intensity
C. To reduce friction and wear during actuation
D. To measure pressure differences
Show the Answer
Question 16
A. It generates the magnetic field
B. It encloses the return spring
C. It houses the actuator
D. It provides the electrical connection points
Show the Answer
Question 17
A. High-pressure
B. Dusty
C. Dark
D. Electromagnetically noisy
Show the Answer
Dusty
Question 18
A. They work in any environment
B. They can detect motion
C. They can prevent machine overtravel
D. They can prevent motor over heating
Show the Answer
Question 19
A. Complex wiring
B. Limited range
C. Susceptible to wear and tear
D. High cost
Show the Answer
Question 20
A. Textile
B. Automotive
C. Semiconductor
D. Food and beverage
Show the Answer
Automotive
Question 21
A. Electric pulse
B. Light beam
C. Roller lever
D. Magnetic field
Show the Answer
Roller lever
Question 22
A. Actuator
B. Wiring
C. Housing
D. Contacts
Show the Answer
Housing
Question 23
A. Office lighting systems
B. Industrial machinery
C. Personal computers
D. Home appliances
Show the Answer
Question 24
A. Fixed activation points
B. Permanent installation
C. Fixed detection range
D. Flexibility in setting activation points
Show the Answer
Question 25
A. It shows the switch’s power rating
B. It denotes the switch’s enclosure protection
C. It indicates the switch’s color
D. It specifies the switch’s mechanical lifespan
Show the Answer
This video provides detailed explanations about the limit switch specifications for the following questions and answers.
Common Questions About Limit Switch Specifications in Automation
Question 26
A. The maximum current the switch can handle
B. The minimum current for reliable operation
C. The maximum voltage the switch can handle
D. The current required to activate the switch
Show the Answer
Question 27
A. Actuator type
B. Contact material
C. Operating environment
D. Voltage rating
Show the Answer
Question 28
A. The force exerted by the contacts
B. The electrical force applied by the switch
C. The force needed to operate the actuator
D. The mechanical strength of the housing
Show the Answer
Question 29
A. It impacts the switch’s electrical performance
B. It influences the switch’s actuation speed
C. It determines the switch’s size
D. It affects the switch’s sensitivity
Show the Answer
Question 30
A. The time it takes for the switch to reset
B. The force required to activate the switch
C. The distance the actuator must move before contacts close
D. The switch’s lifespan
Show the Answer
Question 31
A. It controls the switch’s lifespan
B. It maintains contact reliability
C. It ensures consistent actuation force
D. It prevents accidental reset
Show the Answer
Question 32
A. The maximum voltage the switch can handle
B. The maximum current the switch can handle
C. The speed at which the switch operates
D. The additional actuator movement after activation
Show the Answer
Question 33
A. The position where the switch returns to its original state
B. The maximum load the switch can handle
C. The force required to reset the switch
D. The current needed to reset the switch
Show the Answer
Question 34
A. Gradual movement of contacts
B. Sudden movement of contacts
C. Continuous movement of contacts
D. No movement of contacts
Show the Answer
Question 35
A. Number of times a switch can operate per minute
B. The force needed for each activation
C. The duration of each switching cycle
D. The speed at which the switch activates
Show the Answer
Question 36
A. The temperature at which the switch is installed
B. The temperature required to activate the switch
C. The maximum temperature the contacts can handle
D. The range of temperatures the switch can operate within
Show the Answer
Question 37
A. The number of mechanical cycles the switch can perform
C. The duration the switch can remain active
D. The force the switch can withstand
Show the Answer
Question 38
A. It determines the switch’s mechanical strength
B. It influences the switch’s electrical performance
C. It affects the switch’s weight
D. It defines the switch’s physical size
Show the Answer
Question 39
A. The arrangement of the contacts (e.g., NO, NC)
B. The size of the contacts
C. The material of the contacts
D. The shape of the contacts
Show the Answer
Question 40
A. It influences the switch’s mechanical durability
B. It impacts the switch’s thermal stability
C. It determines the switch’s resistance to current leakage
D. It affects the switch’s physical dimensions
Show the Answer
Question 41
A. The voltage the switch can withstand without breaking down
B. The frequency at which the switch operates
C. The force needed to activate the switch
D. The switch’s resistance to wear and tear
Show the Answer
Question 42
A. It determines the switch’s cost
B. It influences the switch’s response time
C. It defines the switch’s contact material
D. It affects the switch’s size
Show the Answer
Question 43
A. The operating lifespan of the switch
B. The time taken to reset after activation
C. The time taken to activate after actuation
D. The duration of the activation signal
Show the Answer
Question 44
A. It determines the force needed to reset the switch
B. It affects the switch’s activation speed
C. It determines the current needed to reset the switch
D. It controls the switch’s electrical load
Show the Answer
Question 45
A. The installation orientation of the switch
B. The position at which the switch is actuated
C. The default state of the switch
D. The maximum movement allowed by the switch
Show the Answer
Question 46
A. The switch’s capacity to handle high loads
B. The switch’s performance under vibration
C. The switch’s ability to resist electrical surges
D. The switch’s resistance to sudden impacts
Show the Answer
Question 47
A. The size of the contacts
B. The switch’s mechanical strength
C. The voltage and current the contacts can handle
D. The material used for the contacts
Show the Answer
Question 48
A. The environmental protection of the switch
B. The electrical rating of the switch
C. The type of actuator used
D. The method of attaching the switch to equipment
Show the Answer
Question 49
A. Copper
B. Plastic
C. Wood
D. Rubber
Show the Answer
Copper
Question 50
A. Housing
B. Wiring
C. Actuator
D. Contacts
Show the Answer
Actuator
  • What is a Limit Switch?
  • Types of Limit Switches
  • PLC Limit Switch Example
  • Limit Switch Animation
  • How Does Limit Switch Work?
Electric Circuits Objective Questions – Set 3
Level Measurement Objective Questions
Inductive Impedance Questions
Standard Test Signals Objective Questions
Electrical Machines Loss Dissipation Quiz
Filtering and Dynamic Compensation Objective Questions
Power Systems MCQ Series 13
Electric Circuits Objective Questions – Set 4
Analytical Measurement Multiple Choice Questions
Test Questions on Safety Instrumented System
Capacitive Transducers Objective Questions
Process Control & Instrumentation Objective Questions – Set 7
Proximity Switch Questions and Sensors
62 Proximity Switch Questions and Answers
Vibration Sensor
Vibration Probes Questions and Answers
Power Systems MCQ Series 10
Oscillators and Signal Generators Objective Questions
Quiz on Electrical Drawings and Symbols
264 Quiz on Electrical Drawings and Symbols
Power Systems MCQ Series 16
Electromagnetism Objective Questions and Answers
200+ Electromagnetism Objective Questions and Answers
Power System Protection Quiz
Electrical Power System Protection Quiz
Air Pre-heater
What is an Air Pre-heater? – Types, Working, Advantages
Loop Diagram
reactor vessel
what is calibration
Important Terms in Calibration
Industrial Control Systems Security
PLC Program
PLC Program to Heat and Bend Glass Tubes
CNC Programming - Definition, Types, and Tips
CNC Programming – Definition, Types, and Tips
Digital Electronics Objective Questions – Set 5
