Reading: Differential Pressure Level Transmitter Errors
Inst Tools > Blog > Level Measurement > Differential Pressure Level Transmitter Errors
Last updated: February 5, 2019 9:23 am
Level Measurement
2 Comments
2 Min Read
Every liquid in storage tank will have hydrostatic pressure equal to the height of the liquid. With an assumption that the liquid has constant density.
The DP level transmitter indication is a measure of the head pressure in the level of the tank whose level is to be detected.
Head Pressure, DP, is calculated as
DP = (Height).(Specific Gravity)
For example, let’s say  50% level is displayed in the control room, the specified SG = 0.8.
The DP transmitter is actually measure a differential pressure (50%)*(0.8) = 40 units of the differential pressure.
Now, what if the SG change. maybe because the liquid aerated, or the feed to the vessel has become lighter.
For some reason, the SG has dropped from 0.8 to 0.6. The real level will increase to 66.67% (40/0.6) but the indicated level in the control room is still 45% because the DP output is constant at 36 units of DP.
This is happened because DP level transmitter cannot discriminate between height and density.
This is something to worry about. The defective level transmitter can cause liquid overflow and vapour cloud explosion can be ignited if ignition source available in adjacent area
Author : Iqbal Matondang
Articles You May Like :
Level Measurement Terminology
Sounding Level Transmitter
Vibrating Fork Level Switch
RF Level Switch Principle
Servo Tank Gauges Principle
Nuclear Level Detectors Cascade or Master/Slave concept
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Radar Level Measurement
How to Measure Density using DP Transmitter?
How Tilt Level Switch Works ?
Weight-based Level Measurement Principle
2 Comments
  • ali raza khan says:
    August 31, 2019 at 7:58 pm
    dear sir,
    send me new updates.
  • shrikant chaudhari says:
    September 2, 2020 at 10:29 pm
    dear sir,
    send me new updates
Boiler Three Element Controller Philosophy
Hydrostatic Interface Level Measurement
DP Transmitter with Two Seals applications
Which Instrument is at Fault in this System?
Displacer Level Sensor Working Animation
RF Admittance Level Transmitter Working Principle
Inductively Coupled Wire Guided Float Detectors
Displacer Level Transmitter Calibration Procedure
Displacer Level Transmitter Calibration using Water & Process Liquid
Radar Level Transmitter in Briddle level Measurement
Radiation based Level Sensor Principle
Hydrostatic pressure Measurement
Basics of Hydrostatic Level Measurement
Float Level Measurement
Types of Level Measurement
Optical Level Switch Principle
Optical Level Switch Working Principle
Interface Level Measurement Selection Guide
capacitor-filter-ripples
Ripple Voltage in Rectifiers
Pressure Transmitter
Pressure Transmitter Animation
Frequency Response MCQ
Experimentation of Transfer Function
Flow Switch Symbol
Principle of Flow Switch
Accelerometer Vibration Probe
Accelerometer Vibration Probe Principle
Instrumentation Air System Design
Programmable Array Logic Objective Questions
Comparator used in Siemens S7-1200 PLC.
Siemens PLC Comparator Logic
