Reading: Level Measurement Lab Exercise
Inst Tools > Blog > Practical Questions > Level Measurement Lab Exercise
In this guide you will find the operational procedure for the instrumentation level measurement lab exercise.
Last updated: January 13, 2021 8:48 pm
Practical Questions
After getting your prototype sketch approved by the instructor, you are cleared to begin building your system.
Transmitters attach to 2-inch pipes using special brackets and U-bolts. These brackets and U-bolts are located along with the transmitters in the instrument storage area.
Feel free to use 1/4 inch plastic tubing for all the pneumatic signal connections, and be sure not to exceed the rated supply pressure (as documented in the transmitter’s manual).
Finally, your level-measurement system needs to have a loop number, so all instruments may be properly labeled. This loop number needs to be unique, so that another team does not label their instruments and tubes the same as yours.
One way to make your loop number unique is to use the equivalent resistor color code value for your team’s color in the loop number. For example, if you are on the “Red” team, your loop number could be “2”.
It is recommended that you use a different electronic indicator or indicating controller as the display unit on this lab exercise, to give yourself wider exposure to the controller/indicator options in our lab facility.
For example, if in the previous lab exercise your team used a panel-mount electronic indicating controller, consider using a PLC or a DCS as the electronic indicator in this lab exercise.
Common Mistakes
Neglecting to consult the manufacturer’s documentation for field instruments (e.g. how to connect pneumatic signal lines, how to calibrate them).
Mounting the field instrument(s) in awkward positions, making it difficult to reach tube connectors or to remove covers when installed.
Mounting the transmitter above the LRV point, rather than below (to avoid loss of impulse line liquid fill when the vessel’s level is drained to the LRV point).
Improper pipe/tube fitting installation (e.g. trying to thread tube fittings into pipe fittings and vice-versa).
Applying Teflon tape to tube fitting threads; failing to apply Teflon tape to pipe fitting threads.
Over-tightening tube fittings (remember, no more than 1-1/4 turns when installing a new ferrule set, and no more than “snug” when re-making the connection!).
Students working on portions of the system in isolation, not sharing with their teammates what they did and how. It is important that the whole team learns all aspects of their system!
It is relatively easy to construct a “process vessel” for measuring water level in, by using inexpensive PVC plastic piping and fittings:
Process vessel for measuring water level
Water is poured in the top, through the open tee fitting, and is drained through a valve at the bottom (preferably a 1/4 turn ball valve).
Even with an instrument valve manifold on the ∆P transmitter, a shutoff valve is advisable between the process vessel connection and the transmitter to facilitate the removal of the transmitter and manifold without having to drain the vessel.
Note how the DP transmitter is mounted lower than the LRV mark on the sight-glass: this is intentional, as it maintains a liquid fill throughout the impulse line even when the vessel is at its lowest liquid level.
If the transmitter is mounted above this point, the possibility exists for that liquid fill to dribble out of the impulse line if ever the vessel’s level goes too low, and this loss of liquid fill will cause calibration errors!
Building a functioning system should take no more than one full lab session (3 hours) if all components are readily available and the team is working efficiently!
  • Loop diagram Lab Exercise
  • Remote Seal Pressure Transmitter
  • Tube and tube fittings
  • Instrument Tube Bending
Credits: Tony R. Kuphaldt
Calculate Density and Specific Gravity
Pitot Tube Flowmeter Calculations
Calculate the Voltage across Voltmeters of Thermocouple
Hydrostatic Pressure of a vertical column of Acetic Acid
Calculate LRV and URV for 4-20 mA Loop-powered DP Transmitter
How to Draw a Schematic Diagram ?
Questions on Pneumatic Control Loop
Find Thermocouple Ouput Voltage
Purpose of Stop in a Pressure Measuring Instrument
Draw the Symbols for Liquid Level Measuring Instruments
Calculate Amount of Weight Indicated by the Scale
Calculate the appropriate millivoltage values of a Thermocouple
Identify High Flow Alarm and Low Flow Alarm?
Is it Possible to Measure Liquid-Liquid Level Interface using Float?
Calculate the Thermocouple Output millivolts
Tank uses 3 Pressure Transmitters to Measure Level & Density
Programmable Logic Controller (PLC) Questions and Answers – 9
Calculate Total Hydrostatic Pressure at Bottom of Vessel
Pressure gauge mechanism
How Measurement Span of Pressure Gauge Could be Changed?
Stripping tower unit
Transmitter Calibration Range of a Vessel Level
solenoid valves trip
Identify Solenoid Valves Energized or de-energized?
Power Electronics Diode Circuits Questions and Answers
PLC Sequence Programming Ladder Logic
What is PID Controller
What is PID Controller?
Determine the Pressure at Each Port of DP Transmitter
Process Control & Instrumentation Objective Questions – Set 7
Level Loop Troubleshooting
Identify Faults in PID Control Loop
Beta ratio ( β )
Important Factors in Flow Measurement
Principle of Operation of PLC
