Reading: Laws of Boolean Algebra using Ladder Logic
Inst Tools > Blog > PLC Tutorials > Laws of Boolean Algebra using Ladder Logic
Last updated: March 4, 2021 3:47 pm
3 Min Read
Laws of Boolean algebra are used in digital electronics. Explain the Boolean algebra law using ladder language.
Laws of Boolean Algebra using Ladder LogicPLC Ladder programming explanation
There are three basic laws of Boolean algebra.
  • Commutative law,
  • associate laws and
  • distributive laws.
The commutative laws and associate laws are used for addition and multiplications and distributive laws are used for gate logic implementation.
Here take tree variable for this explanation for these laws. A, B and C are the variables for the explanation.
The commutative law of addition of two variables is AB=BA.
The associate law of addition for three variables is written as A+ (B+C) = (A+B) +C.
The distributive law is written for three variables as A (B+C) =AB+AC.
List of Inputs/Outputs
List of Inputs
  • I1 :- A
  • I2 :- B
  • I3 : -C
List of Outputs
  • Q1 :- Output 1
  • Q2 :- Output 2
  • Q3 :- Output 3
  • Q4 :- Output 4
Memory coil
  • M2 :- for Commutative laws
  • M3 :- for associate law
  • M4 :- for distributive law
NETWORK 1 :-
Here OR gate is used for inputs A and B. Result will be stored in M2 memory.
OR Gate using Ladder Logic
NETWORK 2 :-
Here combinational logic is used for commutative laws. Final result will be Q1.
commutative Law Ladder Logic
NETWORK 3 :-
Here AND gate is used for inputs A and B. Result will be stored in M1 coil.
AND Gate Ladder Diagram
NETWORK 4 :-
Combinational logic is used for associate law. Final result will be Q2
Associate Law Ladder Logic
NETWORK 5 :-
Ladder Logic AND Gate Function
AND gate of two inputs (A&B) for distributive law. Result will be stored in M3.
NETWORK 6 :-
AND gate of two inputs (A&C) for distributive law. Result will be stored in M4.
Distributive Law Ladder Logic
NETWORK 7 :-
OR gate of M3 and M4. Result will be stored in Q3.
OR gate function ladder diagram
NETWORK 8 :-
Other combination of distributive law.
Boolean Algebra Ladder Diagram
Note:-Above application may be different from actual application. This example is only for explanation and educational purpose only. We can implement this logic in other PLC also. This is the simple concept for Laws of Boolean algebra using ladder logic, we can use this concept in other examples also.
All parameters and graphical representations considered in this example are for explanation purpose only, parameters or representation may be different in actual applications. Also all interlocks are not considered in the application.
Author : Bhavesh
Boolean Algebraic Identities
Ladder Diagram Programming
PLC Input Output Modules
Introduction to Karnaugh Mapping
What is Kirchhoff’s Current Law
Site Commissioning Steps for PLC Programmers
What is Marshalling Cabinet?
Siemens TIA Portal Elevator System with Safety Features
What is Thin Client in SCADA? – Purpose, Advantages
XG5000 PLC Programming for Automatic Exhaust Fan
How to Select the Right Encoder for Your Machine?
Exhaust Fan Control: Example of PLC Timer Programming
What is Alarm Prioritization? – Types of Alarms
Test and Process Modes in Siemens PLC
Free Allen Bradley PLC Ladder Logic Training Course
VFD Commissioning and Testing Procedure
Loop Diagram
Proper Earthing Practices Used for PLC Control Panel
Configuration of Siemens VFD Using TIA Portal
Configuration of Siemens VFD Using TIA Portal Start drive
Omron PLC paper cutting machine automation
Automatic Paper Cutting Machine Using CX-Programmer
sinking-and-sourcing-digital-output-modules
PLC Digital Signals Wiring Techniques
SFC Language in PLC Programming
OpenPLC - PLC Training for Students - Free Tutorials & Courses
Power Transistor Objective Questions
Probe Thermometer
What is a Probe Thermometer? How to Calibrate and Use it?
Basic Electronics Questions and Answers
Troubleshooting Fluid Systems Pressure Changes
Liquid Level Control using Flow Loop
Formula for 4-20mA from 3-15PSI
Formula to Calculate 3-15psi from 4-20mA Current
Communicating Delta PLC Software to Simulator
Magnetically coupled float indicates liquid level
What are Mechanical Level Indicators? – Classification & Principle
