Reading: Jog Function in Motor Start Stop Logic using PLC
Inst Tools > Blog > PLC Tutorials > Jog Function in Motor Start Stop Logic using PLC
Last updated: March 4, 2021 3:44 pm
3 Min Read
The common usage of the word ‘Jogging’ in our daily life is for slow running. ‘Jogging’ or ‘inching’ of a motor also implies the same i.e ., to have small movements of the driven machine . In jogging, starting and stopping of a motor is under the direct control of the operator .
Jogging is also defined as the brief closure of a motor circuit to energize a motor for a short period of time and perform a small movement of driven machine. Motor Start/Stop Circuit with Jog switch Designed to turn an output on and off that can in turn be wired to a motor starter to start/stop a motor
Sometimes in motor logic we need to bypass start button and latching logic for testing purpose or to run the motor momentarily. A motor is jogged for the following reasons: to align and space machine parts; to position a tool accurately; to thread cloth, paper, or sheet steel; and to provide small controlled movement.
Generally in motor logic there are two push buttons are used start push button and stop push button (START PB and STOP PB). As per electrical wiring we need to insert START PB after STOP PB and jog button is also inserted in series with STOP button. Generally two contacts are used in this button (NO and NC contacts).
List of Inputs
  • Start PB :- I1
  • Stop PB :- I2
  • Jog PB :- I3
List of Outputs
  • Motor :- Q1
PLC Ladder Logic for Motor Jog Function
  • In this logic we have used START/STOP logic of motor and jog function.
  • In this network we have connected START PB in series with STOP PB.
  • Also we have connected NC contact of jog PB in series with latching contact of motor, so it will allow logic to pass in normal condition.
Jog function in Motor Start Stop Logic using PLC
Author : Bhavesh
Relay Latching Circuit using Button
Grinding Machine PLC Program
PLC Project for a School
Elevator Ladder Logic Porject
Types of Limit Switches – Principle, Advantages, Disadvantages
PLC Timer Programming Examples – TON, TOF, TP and TONR
Tia Portal – Optimized and Standard Data Block Access
Cybersecurity in PLC
How to Work with Delta PLC Simulator?
How to Program a Star-Delta System using 1 Button in PLC?
PLC vs PAC – Understanding the Key Differences and Similarities
PLC Digital Signals Wiring Techniques
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
What is an RTU? – Remote Terminal Unit
If Else Statement in SCL Language
How to Update the Firmware Version of your PLC
How to Update the Firmware Version of your PLC? – TIA Portal
PLC Program
Example PLC Program
PLC Program to Energize & De-energize the Outputs based on Events
PLC Energize or De-energize the Outputs based on Events
Structured Text Automatic Gate Logic
Structured Text PLC Programming for Automatic Gate Control
Configure Analog Inputs and Outputs in Delta PLC
What is a Tag in SCADA
What is a Tag? Types of Tags in SCADA
Simatic Prosave HMI
How to Backup and Restore from Simatic Prosave HMI?
V1000 Family Programming Simulator Tool
Electrical Machines MCQ Series 17
Field Instruments
Is Vacuum affects Field Instruments in Industries?
Communication between Intouch Scada and Allen Bradley PLC
Communication between InTouch Scada and Allen Bradley PLC
Calibration Sheet
Calibration : Up-tests and Down-tests
CIPP Lining Procedure
What is CIPP Lining? Procedure and Advantages
Drum Level Compensation of DP Transmitter
Drum Level Compensation and Range Calculation of DP Transmitter
Proportional Control Theory
Proportional-only Offset
Difference between PLC and Computers
