Reading: InTouch SCADA Login Password Security
Inst Tools > Blog > PLC Tutorials > InTouch SCADA Login Password Security
Last updated: March 4, 2021 12:03 pm
Learn how to create login security for InTouch SCADA programs using multi-level users with a specific username and password.
InTouch SCADA Security
Security is an essential parameter in every industry. Who can have access to the data and how much a person can see data, everything you can control within SCADA software.
Let’s learn how to activate the security feature in InTouch SCADA.
Step 1:
Open InTouch. Create a new project and enter an animation environment.
Intouch Scada Security
Step 2:
Now I will take an example in which I have a three-persons, one is a manager, the second one is an engineer and the last one is an operator.
I will take three buttons to represent each person and will use three lamps in which I define who can have access to activate the lamp.
To add a button, click on the last icon as shown in the below window.
Do right click on each text button to give a name.
Intouch Windows Security
Step 3:
I have added text to the buttons.
Step 4:
Now add three lamps.
Insert Lamps in InTouch SCADA
Step 5:
To activate security go to “special” then “select security type” and select “InTouch”.
InTouch SCADA Password Protection
Step 6:
Then go to “special” and in security click on “log in”.
InTouch Security Log On
Step 7:
The following window will pop up. Give a name and password to add user access.
The default user name is “administrator” and the password is “Wonderware”.
Scada Username and Password
Step 8:
Then go to “special” and click on “configure user”.
Configure Users in InTouch SCADA
Step 9:
The following pop up will open.
Add user name, password, and access name for a user that we want to configure.
Click on “Add” to add a user.
InTouch Username
Step 10:
Now Double click on “manager” and select “disable” option.
InTouch Adminiistrator
Step 11:
In the below pop-up, give an access level “1” (as per we gave into the security window). Hit “ok” to proceed.
Do the same to the other two buttons.
Also, give a tag name to the lamp.
SCADA Expression
Step 12:
To test the animation, go to the runtime window. As you can see all three buttons are disabled.
InTouch SCADA Runtime Window
Step 13:
Now login to access the first lamp which relates to the manager. Login and do follow as shown in the below window.
Log In SCADA
Step 14:
Give the user name and password which you have created earlier, Hit ok to enable the manager button.
Step 15:
As you can see now the button is active. You can turn ON the lamp now.
To active engineer and operator, the button does follow the same procedure as above and give a password and user name and test the animation.
SCADA Password
Author: Suhel Patel
  • Security of SCADA System
  • Components of PLC
  • Siemens PLC using Password
  • OPC Communication
  • Control a Bulb using PLC Logic
What is Thin Client in SCADA? – Purpose, Advantages
PLC Program for Counting Moving Objects on Conveyor
Can a PLC Function Without an HMI or SCADA?
Allen Bradley PLC Interview Questions and Answers
Increment & Decrement Instructions in CX-Programmer (OMRON)
Product Painting PLC Program using Omron CX-Programmer
What is Live Zero in 4-20 mA Current Loop?
Positive and Negative Edges using Statement List Language
Schneider PLC Programming Example for Beginners
Example of PLC Programming based on Logic Circuit
How to Configure PID in Siemens PLC?
PLC Programming Best Practices and Tips
How to Choose HMI
How to Choose a Suitable HMI for Your Application?
running two single-phase induction motors sequentially
Control Two Motors in Sequence after Time Delay – Circuit, Operation
Pneumatic valve operation in sequence mode
Sequential PLC Programming for the Pneumatic Valves
CODESYS HMI Interface
Wiring-Connection-from-PLC-to-Solenoid-Valves
How to Connect a Solenoid Valve with PLC?
PLC Program Upload
How to Upload Siemens PLC Programs?
Electrical Terminal Blocks
How to Protect Electrical Terminal Blocks From Tampering?
Float-type Level Switch for Sensing Low Oil Level
How to Blink Lights in Ladder Logic
How to Blink Lights in Ladder Logic?
Infrared Gas Analyzers Questions & Answers
Communicate with Excel from Intouch SCADA
How to Communicate with Excel from Intouch SCADA?
Configure the Instruments in Flow Control Loop
Analyzer chopper wheel
NDIR Analyzer Filter Cells
Basic AC Generator
AC Generator Parts
