Reading: Internet of Things Communication Models (IoT)
Inst Tools > Blog > Common > Internet of Things Communication Models (IoT)
Learn the internet of things communication models (IoT) such as Client-Server, Publisher-Subscriber, Push-Pull, and Exclusive Pair.
Last updated: January 12, 2024 11:38 am
Common
6 Min Read
Learn the Internet of Things communication models (IoT) such as Client-Server, Publisher-Subscriber, Push-Pull, and Exclusive Pair.
Internet of Things Communication ModelsClient – Server (Request – Response)Publisher – SubscriberPush – PullExclusive Pair
When you are using the Internet of Things (IoT), the very first reason why we use it is communication speed for data transfer. This is because seamless data transfer at high speeds is essential for getting and passing data between every system.
Then only, the operator can control a plant sitting in any corner of the world. For this, it is required that the operator needs to know how communication rules work in IoT.
In the language of IoT, they are called as communication models. The user must understand how communication happens in IoT before using the actual system.
In this post, we will see the types of communication models used in IoT.
As the name defines, the two parties here are defined as client and server. In the Client-Server model, a client is the one who requests data from the server. Once the request is received by the server, it will process it and accordingly respond by sharing data with the client. The response from the server is then received by the client.
This is the most used type of communication model that exists in even basic automation levels like PLC. A PLC will be the client that requests data from a VFD for frequency data. The VFD will be the server in this case, as it has the data and just needs to pass it to anyone who requests it.
Once the VFD responds by sharing data with the PLC, the PLC will then process it and use its logic accordingly. In this mode, as we have understood, both parties know each other’s identities because they deal separately between them.
This is a more advanced type of model used in IoT. Consider a YouTube channel. The video publisher has published the video on YouTube but does not know which users have subscribed to the channel. The channel is just distributing video to YouTube and in return, YouTube allows the user to subscribe to the channel. This is a simple example of a publisher-subscriber model.
In this, the publisher distributes data and there is a broker in between which handles this data. The broker will provide data to the users who demand it. The users here are termed as subscribers. The publisher does not know who is the subscriber. It has just passed data and the broker has distributed it to subscribers.
It enables data exchange between various components of a system without the components being aware of each other’s identity. What matters to them is data. So, this model is widely used for distribution-type systems like sending notifications to users, working with multiple data sources, broadcasting, etc.
Push – Pull
This model is similar to the publisher-subscriber model. Let us see this model by extending the same discussed earlier. The publisher here is the pusher and the subscriber here is the puller. The publisher will push the data and the subscriber will pull the data. The main difference is that of the intermediate handling.
In the earlier case where the broker was the system, here a queue system is used in between. The queue will take pushed data and simply pass the data to consumers who are pulling it. It is a distributed one too, but limited in terms of distribution networks and speed.
The push-pull model works linearly and controls the rate of data transfer whenever the push or pull speed varies. This queue is that thing which is majorly responsible for handling data between pushers and pullers.
Exclusive Pair
This is an extension of the client-server model or response request model. As opposed to the previous one where the response was given based on request, the model here is fully open. It means the communication is full duplex.
Both the client and server open their connections and data exchange happens continuously. It ends when the client closes the connection and the server has to accept it.
This means that once the request has been sent initially and the response has been sent, the connection becomes open and then there is no need to send requests. The server keeps a record of what data has been exchanged.
  • Industrial Automation Mobile Apps
  • Real-time PLC Automation Projects
  • Discrete Manufacturing Automation
  • Automation Sales and Marketing Tools
  • Industrial Automation Wireless Technology
Hydraulic and Pneumatic P&ID Diagrams and Schematics
What is an Optical Line Terminal? – OLT Working Principle
What is a Legend? – Piping and Instrumentation Diagram
Top 3 Online Bachelor’s Programs in Electronics Engineering
5 Valve Manifold Operation
The Top Services a Great B2B Agency Offers
General Streams in Electronics Engineering for Students
Measurement Unit Conversions
How ANSI Class Relates to PSI ?
An Overview of Metrology Tools for CNC Machining
What is Chemical Vapor Deposition? – The Ultimate Guide
What is a Spare Part? Classification, Cost, Critical Inventory
Procedure for Crimping the Connector
Absorber in absorption chiller
What is an Absorption Chiller? – Working Principle
Belt Conveyor Weighing System
Belt Conveyor Weighing System – Weigh Bridge – Speed Sensor
Hard-Wired Control Logic for the Pressure Alarm
Difference Between Microcontroller and Microprocessor
Useful Trigonometry Website for Students Math Help
The Impact of Knowledge Management Platforms on Business Operations
AI Technology in Video Surveillance
Next-Generation Security Surveillance Systems – AI Technology
Why does SMPS Need isolation - Switch Mode Power Supply
Why does SMPS Need isolation? – Switch Mode Power Supply
Contact less Tachometer
Types of Tachometers – Mechanical and Electrical Tachometers
Fieldbus Pressure Transmitter Configuration
Foundation Fieldbus Pressure Transmitter Configuration
Power Systems MCQ Series 8
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
Electrical Machines MCQ Series 1
Fieldbus Control
Fieldbus Control
Top 100 Electrical Machines Projects for Electrical Engineers
4-wire pH Transmitter Problem
IR Radio Sensors Objective Questions
