Reading: Basic Instrumentation Test
Inst Tools > Blog > Instrumentation Interview Questions > Basic Instrumentation Test
Last updated: October 17, 2023 4:03 pm
5 Comments
7 Min Read
Practice the instrumentation and control engineering matching questions, True or False questions, and multiple-choice basic test.
Instrumentation Multiple Choice QuestionsInstrumentation Matching QuestionsInstrumentation True or False Questions
1. In a pneumatic control system, the flapper is a type of
a. Variable orifice used to control an actuator
b. Vibration detector to shut down a system
c. Linkage adjustor to reduce error
d. Replacement for an air relay
2. Incorporated in PLC processors are _____.
a. Microprocessor functions, valve actuators, and electric motor functions
b. Microprocessor functions and distributed control systems
c. Human-machine interface, memory storage, and mathematical functions
d. Microprocessor functions, memory storage, and mathematical functions
3. Within the circuitry of a current transmitter are operational amplifiers (op-amps) which can perform ______.
a. Comparison and amplification
b. Addition and subtraction
c. Integration or summing and differentiation or rate
d. All the above
4. Once the process variable range is known, a transmitter is adjusted to allow accurate measurements over the operating process range by manually adjusting its______.
a. Zero, span, and current
b. Zero, span, and linearity
c. Voltage, span, and linearity
d. Voltage, current and variable resistor
5. Electronic devices can duplicate all pneumatic control effects and they can do it with ____.
a. Less expense, less time, and less manpower
b. Less maintenance, greater flexibility, and easier adjustments
c. Less time, less money, and less wear
6. A column of water exerts _________ psi for each vertical foot of height
a. 0.343
b. 0.433
c. 0.334
d. 0.444
7. Liquids vary in their _______________ with temperature as well as other factors.
a. Surface tension
b. Color
c. Rankin factor
d. Coefficient of expansion
8. The pressure that is below atmospheric pressure uses what pressure scale?
a. Absolute
b. Barometric
c. Rankin
d. Vacuum
9. The principle behind _________ thermometers is that two strips of metal with widely different coefficients of expansion – they expand at different rates at various temperatures – can be used to measure temperature.
a. digital
b. capillary
c. bimetal
d. elemental
10. One type of relief valve involved with temperature contains a ____________ plug that melts at a specific temperature.
a. plastic
b. spring-loaded
c. fusible
d. bimetal
11. Which of the following is not a way to measure the inferred temperature of molecular motion?
a. Differential pressure
b. Changes in volume and pressure of liquids and gases
c. Electrical resistance properties
d. Expansion and contraction of metals
12. The free end of a __________________ , within its elastic limits, experiences movement that is proportional to the fluid pressure applied.
a. Flapper
b. Bourdon Tube
c. Bimetallic strip
d. Diaphragm
13. Another name for a pressure relief valve is _____________ because it prevents damage to equipment and possible injury to personnel.
a. Safety valve
b. Isolation valve
c. Throttle valve
d. Gate valve
Questions are in serial with letters a, b, c, d, e, f, g, h, i, j, k, l, m, n, o.
Answers options are in serial numbers 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15.
Match the correct questions and answers from the below lists.
Matching Questions
a. Pressure regulators ________
b. Analog ________
c. Programmable Logic Controllers (PLC) ________
d. Distributed Control System _______
e. Ergonomics ________
f. Pressure ________
g. Back-pressure control _______
h. Thermoresistive elements _______
i. Temperature regulator _____
j. Gauge pressure _______
k. Thermoresistive metal oxides _______
l. Rankin ______
m. Differential pressure ________
n. Hydrostatic pressure ________
o. Head ________
Matching Answers
1. Communication between controllers and computers allowing data to be gathered, the control of adjustments, or the operation of master-slave devices.
2. Hold supply air pressure to a steady required value.
3. The science that deals with the methods, procedures, and environment involved between humans and machines
4. Is a signal that is continuous and has an infinite number of points between its beginning and ending values.
5. Electronic control devices that perform many logic functions.
6. The difference between low pressure and high pressure at some point in a system.
7. Their resistance decreases with increasing temperature.
8. Control the flow of a fluid such as steam, hot water, or natural, through a system
9. The pressure scale that ignores atmospheric pressure and begins the pressure measurement at zero.
10. Converts Fahrenheit temperatures to absolute temperatures
11. Force per unit area
12. Elements that change their resistance value with temperature
13. Controls upstream pressure and involves maintaining a fixed pressure in a vessel such as a fractionation tower or an oil and gas separator.
14. Exerted by a fluid that is at rest in a container
15. The pressure that results from the gravitational forces on liquids.
1. ______ Ergonomics works to assure that operators perform their assignments efficiently, with ease, and with a minimum of error.
2. ______ Current transmitters are best to use when control signals travel long distances.
3. ______ Programmable logic controllers can accept a variety of input signals.
4. ______ Weight loaded regulators are more popular the spring-loaded regulators.
5. ______ Atmospheric pressure increases with increasing altitude.
6. ______ Non-metallic or slack diaphragms are often used to measure very low pressure.
7. ______ Smart transmitters contain electronic microprocessors that process information from a digital communicator or interface unit, store this information, and allow re-ranging without the need for a separate pressure source.
8. ______ Control of pressure generally involves the flow of liquids or gases in a process.
9. ______ Temperature is the most important variable encountered in automatic control.
10. ______ Temperature can be readily determined by direct means.
  • Loop Diagram Questions
  • Instrument Questions and Answers
  • Pressure Measurement MCQ
  • EPC Interview Questions
  • Power Supply Questions
This work by ShaleNET U.S. is licensed under a Creative Commons Attribution 4.0 International License.
Dissolved Oxygen Analyzer Interview Questions & Answers
Valves Pressure Loss – Questions and Answers
Interview Questions on Flow Measurement
Allen Bradley PLC Interview Questions and Answers
5 Comments
  • Rakesh parmar says:
    October 21, 2020 at 11:42 am
    1-C
  • Pradeep kumar says:
    November 28, 2020 at 6:03 pm
    What is the answer link?
  • Velly says:
    December 6, 2020 at 12:16 am
    Could you please add answers also
  • ali says:
    July 23, 2021 at 10:30 am
    1-A
  • Haba Gadey says:
    March 5, 2023 at 5:59 am
    Hello
    I’m so happy discovering this site.
Oil and Gas Interview Questions Answers
Temperature Measurement Interview Questions
Temperature Sensors Interview Questions
Instrumentation Inspection and Quality Control Questions
How to Apply on Online JOB Portal Website?
OPC Communication Interview Questions and Answers
EPC Questions and Answers
Gas Turbine Interview Questions and Answers
Top 100 Instrumentation Engineering Questions & Answers
Flow Transmitters Questions and Answers
Flow Transmitters Questions and Answers – Instruments Test
List of 100 Industrial Instrumentation Questions
List of 300 Industrial Instrumentation Questions
ProfiBus Questions and Answers
Latest ProfiBus Questions and Answers
Functional Safety Exam Questions & Answers
Functional Safety Questions & Answers
Gas Analyzers Interview Questions
Gas Analyzers Interview Questions and Answers
PLC Engineers Interview Questions
PLC SCADA Engineers Interview Questions and Answers
Most Asked Questions on SCADA
Most Asked Questions on SCADA with Answers
Calculate Resistance from Temperature for RTD
RTD Calculator : Calculate Resistance from Temperature
Micro 870 Rockwell PLC
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
Float Level Switch Principle
Float Level Switch Working Principle Animation
Transformer Protection using fire water spray system
Fire Water Spray Systems Principle
control-valve-actuators
Control Valve Selection Tips
Watchdog Timer in PLC
What is a Watchdog Timer in PLC?
Process Override Switch
What is Process Override Switch (POS)?
corroded tank
Cathodic Protection – Sacrificial Anodic and Impressed Current
