Reading: Instrument Salesperson Question
Inst Tools > Blog > Practical Questions > Instrument Salesperson Question
An instrument salesperson says radar level transmitter is superior to hydrostatic and displacer level transmitters. Do You Accept?
Last updated: January 6, 2021 11:29 am
Practical Questions
1 Min Read
Suppose an instrument salesperson comes to your shop and tells you his company’s radar level transmitter product is superior to all hydrostatic and displacer level transmitters because those instruments’ accuracy depends on a fixed process liquid density, whereas radar transmitters do not.
Thus, he tells you, his radar transmitters will give accurate level measurements even when process pressures and temperatures change.
What do you think of this claim? Is the salesperson’s claim true, or not? Explain.
If a magnetostrictive level transmitter salesperson made a comparable claim – that the accuracy of a magnetostrictive instrument would not be affected by changes in process liquid density – would you believe it?
Answer:
Caveat emptor! (Latin for “buyer beware”)
Radar level transmitters are definitely affected by certain properties of the gas or vapor above the liquid surface.
I’ll let you identify what those properties are!
Share your answers and explanation with us through the below comments section.
  • Radar Tank Gauging
  • Guided Wave Radar Questions and Answers
  • Calibration of Displacer Level Transmitter
  • Non-Contacting Radar Level Transmitter Principle
  • Contact Type Guided Wave Radar Level Transmitter
Credits: Tony R. Kuphaldt
Programmable Logic Controller (PLC) Questions and Answers – 13
Programmable Logic Controller (PLC) Questions and Answers – 7
How to Decrease Span of Pressure Gauge?
Pneumatic Level Transmitter Value Struck?
Loop Powered Pressure Transmitter
Determine Effect of Each Fault for Pneumatic Force-balance System
Explain What these Spool Valve Symbols Represent?
Inspecting the Trends of PV and SP on a Process Chart Recorder
Air Pressure Inside the Tank
Programmable Logic Controller (PLC) Questions and Answers – 15
DP Transmitter Error Calculations
Hydrostatic Pressure of a vertical column of Acetic Acid
How Measurement Span of Pressure Gauge Could be Changed?
Determine the Pressure at Each Port of DP Transmitter
Question on Analytical Controller
Analytical Process Control Question
PLC program pushbutton switches
displacer level transmitter configuration
Displacer Level Transmitter Questions
Ladder Diagram circuit
PLC Practice Questions
Simple High Level Indicator Circuit
DP transmitter Errors
DP Transmitter Calibration Errors
Difference Between Static and Temp Memory in Siemens TIA Portal
Backwashing Precoat Filters
Construction of Megger
What is a Megger? Principle, Advantages, Disadvantages, Applications
Difference Between Modbus and Profibus
Machine Indicator Lights PLC Programming Solution
Cobot - Collaborative Robot
What is Cobot? – Collaborative Robot
DeviceNet
What is DeviceNet?
