Reading: Increment & Decrement Instructions in CX-Programmer (OMRON)
Inst Tools > Blog > PLC Tutorials > Increment & Decrement Instructions in CX-Programmer (OMRON)
Learn the concept of Increment & Decrement Instructions and examples in Omron PLC using CX-Programmer software.
Last updated: May 20, 2024 11:30 am
7 Min Read
Increment & Decrement InstructionsTypes of OMRON InstructionsIncrement & Decrement Binary Instruction TypeAddressing Memory Increment & Decrement in CX-ProgrammerCX-Programmer ProgramSimulation Results
Increment and Decrement Instructions are widely used in industrial automation PLC programs because of their ease of data processing.
Increment and Decrement Instructions have the same function as the Counter function, namely as “Counters”. Increment Instructions function to increase the amount of data while Decrement Instructions function to decrease the amount of data stored in Word Memory allocation.
Unlike the Counter Instruction, the Increment and Decrement Instructions do not require SV (Set Value) parameters because the purpose of the Increment and Decrement Instructions is to hold data, raise data, and lower data.
Generally, these two instructions are used in conjunction with “Comparison Data” Instructions such as (=, <,>, >=, <=, <>).
Increment and Decrement instructions on CX-Programmer have several types, as follows:
  1. ++(590) Binary Increment
  2. ++L(591) Double Increment Binary
  3. –(592) Decrement Binary
  4. –L(593) Double Decrement Binary
  5. ++B(594) Increment BCD
  6. ++B(595) Double Increment BCD
  7. –B(596) Decrement BCD
  8. –BL(597) Double Decrement BCD
In this article, we will only discuss the increment & Decrement instructions of Binary types.
Binary type increment & Decrement instructions use Binary numbers in increasing and decreasing the data, but the data presented/displayed can be in other units, Hexadecimal for example.
There are 2 types of Binary increments, namely “++(590)” and “@++(590)”. Both types have the same function to increase the amount of data in increments per +1 BIN. The difference are explained in the following 2 figures.
Increment Instruction in CX-Programmer
In the picture above is an Increment Instruction type “++(590)”, when the Input contact (0.00) is activated for a long time the value in the data allocation “D100” will increase continuously, with changes in the addition of data values per program cycle.
PLC Increment Instruction
The second picture is an Increment Instruction of type “@++(590)“, the difference is that the increase in value in memory allocation “D100” only occurs once when the contact changes (0.00) from the “OFF” to “ON” condition, even if the contact is activated for a long time, the value will not increase, because this Instruction uses the concept of Differentiate Up in adding its value.
The Decrement Binary instruction also has 2 types, namely “–(592)” and “@–(592)”. Both types have the same function to reduce the amount of data with a decrease in data by -1 BIN. The differences between the two types are explained in the following next 2 figures.
Decrement Instruction in CX-Programmer
In the picture above, it is the Decrement Instruction type “–(592)”, when the Input contact (0.00) is activated for a long time the value on the data allocation “D100” will decrease continuously, with changes in data values decreasing per program cycle.
PLC Decrement Instruction
The second picture is an Increment Instruction of type “@–(592)”, a decrease in the value of data on the memory allocation “D100” occurs only once when the contact changes (0.00) from the “OFF” to “ON” condition, even if the contact is activated for a long time the value will not decrease because this Instruction uses the concept of Differentiate Up in decreasing its value.
The table below contains the memory allocation areas that can be used by Increment and Decrement instructions.
AreaWd
CIO AreaCIO 0 to CIO 6143
Work AreaW0 to W511
Holding Bit AreaH0 to H511
Auxiliary Bit AreaA448 to A959
Timer AreaT0000 to T4095
Counter AreaC0000 to C4095
DM AreaD0 to D32767
Indirect DM addresses in binary@ D0 to @ D32767
Indirect DM addresses in BCD*D0 to *D32767
Constants—
Data RegistersDR0 to DR15
Index Registers—
Indirect addressing using Index Registers,IR0 to ,IR15 –2048 to +2047, IR0 to –2048 to +2047, IR15 DR0 to DR15, IR0 to IR15 ,IR0+(++) to ,IR15+(++) ,–(– –)IR0 to, –(– –)IR15
In this program, 2 experiments were carried out using 2 types of Binary Increment & Decrement Instructions to find out the difference between them.
In the image, the program consisting of 2 Rungs, Rung 0 contains 2 types of increment Instructions “++(590)” with memory allocation (D0) and another instruction “@++(590)” with memory allocation (D1).
Rung 1 using Decrement “–(592)” instruction using memory allocation (D0) and another instruction “@–(592)” using memory allocation (D1).
Simulation Results
When simulated, the difference can be seen, when the UP contact (0.00) is activated and the value of (D0) rises very high while the value of (D1) only increases by 1 data.
Binary Increment and Decrement Instructions
This is because the Cyclic program process has occurred many times so that the value at (D0) is very high and the value at (D1) only increases by 1 data because the increase in data value only occurs when the UP contact condition changes (0.00) from “OFF” to “ON”.
Omron PLC increment and decrement
When the Down contact (0.01) is activated the value of (D0) will drop quite a lot, while the value of (D1) will drop by 1 data only.
  • What are High-Speed Inputs in PLC?
  • PLC Exercise on Door Lock with Delay
  • Difference between Timer and Counter
  • How to use Real-Time Clock in Omron PLC?
  • Pumping and Draining PLC Program System
PLC Program – Controls Conveyors ON and OFF Sequence
PLC Program for Daily Production Record
How to Use an SQL Server with Indusoft Web Studio?
How CPU Execute Program in Siemens PLC?
How to use Sub Routines with Allen Bradley PLC
Safety Door Interlock PLC Program
Tank Filling and Emptying using Intouch Scada Script
Automatic Paper Cutting Machine Using CX-Programmer
How to Work with Delta PLC Simulator?
Programmable Logic Controller Maintenance Check Points
Allen Bradley RSLogix 500 PLC Programming
#20 PLC Best Practices – Identify Critical Alerts
Push button Motor PLC Logic
Communicating Delta PLC Software to Simulator
Classification of Fuses
Step-by-Step Guide to Choose Right Fuse for a Panel
PROFIBUS is also a Master Slave protocol
Omron PLC Instructions - Move, Move Bit, Move Digit
Move, Move Bit, Move Digit – Examples of Omron PLC Programs
PLC program for bread oven
Bread Oven Control in Auto and Manual Modes PLC Program
PLC Pump Control
PLC Pump Control: 10 seconds ON & 20 seconds OFF
Single-Acting Cylinder Control Operation using Proximity Sensor
Single-Acting Cylinder Control using Proximity Sensor
memory types in siemens plc
Memory Structure of Siemens PLC
RJ45 Connector Pins
How to make RJ45 cable
Zero Interface Level Calculation
How to do Interface Level Calculation using DP Transmitter ?
HART
List of Tools used by Instrument Technician or Engineer
Difference Between Static and Temp Memory in Siemens TIA Portal
Programmable Logic Array Objective Questions
Caliper Calibration
Special Control Valves
Power Systems MCQ Series 16
