Reading: Impeller Flow Sensor Working Principle and Animation
Inst Tools > Blog > Animation > Impeller Flow Sensor Working Principle and Animation
Impeller Flow Sensor have magnets which actuate Hall effect switches to detect impeller rotation and this is proportional to flow rate.
Last updated: October 31, 2023 11:13 am
Animation Flow Measurement How It Works
2 Comments
1 Min Read
Impeller Flow Sensor probes are equipped with lightweight helical impellers mounted on double sapphire bearings.
The impellers contain magnets that actuate Hall-effect switches within the probe to detect impeller rotation. The impeller rotation is proportional to the flow rate.
  • Microwave Flow Sensor
  • Flow Measurement Techniques
  • Vortex Flow Meter Animation
  • Different Types of Flow Sensors
  • Lobed Impeller Flow Meters
Digital Building Blocks – GATES
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Reasons to Calibrate Different Types of Flow Meters
Working Principle of Flow Switch with Animation
TOC Analyzer Working Principle
Equivalent Logic Gates using PLC Ladder Diagrams
2 Comments
  • Sesykamal says:
    September 7, 2015 at 1:25 pm
    Instrumentation tools created by BHARADWAJ GARU is very useful to us about subject and for future interviews. Thank you,BHARADWAJ GARU
  • Shaju says:
    September 8, 2015 at 7:58 am
    With impeller measuring element,flow can be quickly detected.
    Thank you sir , for the information.
Relay Working Animation
Hot Wire Anemometer Principle and Types
Flow Meter K-factor and Calculations
Logic Gates Animation
What is a Vortex Flow Meter?
Pressure and Temperature Compensation for Flow Transmitter
Flow meter Turndown Ratio
Importance of Flow Meter Turndown Ratio
Ultrasonic Flow Meters Working Principle
Classification of Flow Measurement Techniques
mass flowmeters
What is a Thermal Flow Meter?
multiphase-flowmeter-working-principle
What are Multiphase Flow Meters? – Working Principle, Advantages
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
LVDT-Operation-Principle-Animation
LVDT Working Principle Animation
Difference Between Earth and Neutral
Calculate Power in Parallel RC Circuit
Rotameter
What is a Variable Area Flow Meter?
Control Valves Flow Direction
Control Valve Flow Direction
Three-Phase Wye Wiring System
4-Wire, Three-Phase Wye Wiring System
MCQ on Measurement and Instrumentation
Axial Diaphragm Seal Connection
Difference between Axial and Radial Diaphragm Seal Connection?
Draw a Ladder Logic to control a bulb using push buttons in PLC
Concept of Latching in PLC
