Reading: Quiz: Identifying I/O Examples in PLC Systems
Inst Tools > Blog > Control Systems MCQ > Quiz: Identifying I/O Examples in PLC Systems
Test your knowledge of PLC systems with our quiz on identifying I/O examples prepared to understand input and output devices.
Last updated: August 31, 2024 8:12 pm
Control Systems MCQ Instrumentation MCQ PLC Tutorials
10 Min Read
Identifying I/O Examples in PLCWhich of the following is an example of a PLC digital input?Which device is typically connected to a PLC analog input?Identify the device that serves as a PLC digital output.Which of the following is an example of a PLC analog output?What type of device would be connected to a PLC as an input to monitor environmental conditions?Which device is often used as a digital output in PLC systems?What kind of input would a flow meter provide to a PLC?Which device is commonly connected as a PLC digital input for safety interlock?Identify an example of a PLC analog output device.Which of the following devices provides a digital input to a PLC?Which device typically serves as a PLC digital input for position detection?Identify the PLC input device used to measure liquid levels.Which of these is an example of a PLC analog output device used for control?What type of signal does a photoelectric sensor provide to a PLC?Which device is a common example of a PLC digital output used for alerting?Which of the following is used as an analog input device in a PLC system for temperature measurement?Identify the device that serves as a PLC output for mechanical motion.Which type of device is connected to a PLC to provide an analog input for fluid pressure?What is a typical example of a PLC digital output used for signaling?Which device is often used as a digital input for detecting metal objects?Which of the following devices is an example of a PLC digital output used for control?Identify the device commonly used as a PLC analog input for pH measurement.Which device serves as a digital output in a PLC system for actuating a mechanical device?Which device is commonly used as a digital input for presence detection in PLCs?Identify the device typically connected to a PLC as an output to control lighting.Which of these devices is used as an analog input in PLCs to monitor rotational speed?What is a typical example of a PLC digital input for machine safety?Which device is often used as an analog output to control valve position in PLC systems?Which of the following devices serves as a PLC input for measuring weight?Which device is commonly used as a PLC digital input to detect motion?Which type of device is connected to a PLC to measure light intensity?What is a typical example of a PLC digital output used to trigger alarms?Which device is often connected as a PLC input to measure distance?Identify the device used as an analog input for flow measurement in a PLC system.What type of device is a typical PLC analog output for heating control?Which device is often used as a digital input for detecting liquid presence?Identify the device that serves as a PLC analog output for visual display control.Which of these devices is commonly used as a PLC digital output to initiate mechanical movement?What is a typical example of a PLC analog input used for fluid flow measurement?Identify the device that serves as a PLC output for motion control.
This PLC video explains the detailed answers for these inputs and outputs examples.
Quiz: Identify I/O Examples in PLC Systems
Question 1
A. Motor
B. Proximity sensor
C. Solenoid valve
D. Light bulb
Show the Answer
Proximity sensor
Question 2
A. Relay
B. Alarm siren
C. Indicator light
D. Thermocouple
Show the Answer
Thermocouple
Question 3
A. Thermistor
B. Indicator light
C. Potentiometer
D. Pressure sensor
Show the Answer
Indicator light
Question 4
A. Variable frequency drive (VFD)
B. Push button
C. Photoelectric sensor
D. Limit switch
Show the Answer
Question 5
A. Contactor
B. Actuator
C. Humidity sensor
D. Pilot light
Show the Answer
Humidity sensor
Question 6
A. Solenoid valve
B. Pressure transducer
C. RTD sensor
D. Thermocouple
Show the Answer
Solenoid valve
Question 7
A. Digital output
B. Analog output
C. Analog input
D. Digital input
Show the Answer
Analog input
Question 8
A. Analog signal generator
B. Emergency stop button
C. Motor starter
D. Variable speed drive
Show the Answer
Question 9
A. Buzzer
B. Limit switch
C. Pneumatic actuator
D. Float switch
Show the Answer
Pneumatic actuator
Question 10
A. Analog transmitter
B. Push button
C. Temperature controller
D. Servo motor
Show the Answer
Push button
Question 11
A. Variable resistor
B. DC motor
C. Hydraulic pump
D. Limit switch
Show the Answer
Limit switch
Question 12
A. LED indicator
B. Heater element
C. AC motor
D. Float switch
Show the Answer
Float switch
Question 13
A. Magnetic reed switch
B. Emergency siren
C. Motor speed controller
D. Pressure switch
Show the Answer
Question 14
A. Analog input
B. Analog output
C. Digital input
D. Digital output
Show the Answer
Digital input
Question 15
A. Buzzer
B. RTD sensor
C. Thermocouple
D. Flow transmitter
Show the Answer
Buzzer
Question 16
A. Solenoid coil
B. Contact relay
C. RTD (Resistance Temperature Detector)
D. Strobe light
Show the Answer
Question 17
A. Limit switch
B. Servo motor
C. Pressure sensor
D. Digital counter
Show the Answer
Servo motor
Question 18
A. Contactor
B. LED indicator
C. Pressure transducer
D. Push button
Show the Answer
Pressure transducer
Question 19
A. Analog voltmeter
B. Thermistor
C. Proximity sensor
D. Strobe light
Show the Answer
Strobe light
Question 20
A. Inductive proximity sensor
B. Variable resistor
C. Capacitive sensor
D. Flow meter
Show the Answer
Question 21
A. Temperature probe
B. Ultrasonic sensor
C. Relay
D. Thermocouple
Show the Answer
Relay
Question 22
A. Light curtain
B. pH sensor
C. Contactor
D. Proximity switch
Show the Answer
pH sensor
Question 23
A. Humidity sensor
B. Flow sensor
C. Strain gauge
D. Solenoid actuator
Show the Answer
Solenoid actuator
Question 24
A. Thermal couple
C. Actuator
D. Photoelectric sensor
Show the Answer
Question 25
A. Pressure gauge
B. Limit switch
C. LED light
D. RTD sensor
Show the Answer
LED light
Question 26
A. Relay switch
B. Solenoid coil
C. Push button
D. Tachometer
Show the Answer
Tachometer
Question 27
A. Variable speed drive
B. Flow valve
C. Safety light curtain
D. Heater element
Show the Answer
Question 28
A. LED indicator
B. Magnetic switch
C. Electro-pneumatic valve positioner
D. Limit switch
Show the Answer
Question 29
A. Solenoid valve
B. Load cell
C. Contact relay
D. Flashing beacon
Show the Answer
Load cell
Question 30
A. Thermistor
B. Motion detector
C. Pressure gauge
D. Analog voltmeter
Show the Answer
Motion detector
Question 31
A. Photovoltaic cell
B. Contactor
C. Solenoid valve
D. Heater coil
Show the Answer
Photovoltaic cell
Question 32
B. RTD sensor
C. Siren
D. Thermocouple
Show the Answer
Siren
Question 33
A. Ultrasonic sensor
B. Pilot light
C. Relay switch
D. Buzzer
Show the Answer
Ultrasonic sensor
Question 34
A. Flow transmitter
B. Flashing light
C. Contactor
D. Push button
Show the Answer
Flow transmitter
Question 35
A. LED display
B. Proximity switch
C. Contact relay
D. Heating element
Show the Answer
Heating element
Question 36
A. Liquid level switch
B. Thermistor
D. AC motor
Show the Answer
Liquid level switch
Question 37
A. Contactor
B. Solenoid valve
C. Analog voltmeter
D. Proximity sensor
Show the Answer
Analog voltmeter
Question 38
A. RTD sensor
B. Analog voltmeter
C. Pressure sensor
D. Actuator
Show the Answer
Actuator
Question 39
A. Proximity switch
B. Flow meter
C. Strobe light
D. Contactor
Show the Answer
Flow meter
Question 40
A. Stepper motor
B. Pressure sensor
C. Limit switch
D. Digital counter
Show the Answer
Stepper motor
  • Control Loop Multiple Choice Questions
  • 80+ PLC MCQ Questions and Answers
  • IoT Interview Questions and Answers
  • Most Asked Questions on Servo Motor
  • Rotary Encoder Interview Questions Answers
Level Sensors MCQ – Industrial Instrumentation
Electrical Measurements and Instrumentation Objective Questions & Answers
PLC Program for Water filling and Discharging Process
Factory I/O PLC Automation Training Course (Free)
Siemens Tia Portal PLC Training Course
#13 PLC Best Practices – Disable Unused Communication Ports
Solenoid Valve Terminology Questions and Answers
Compare Online and Offline PLC Programs
Difference Between Industrial Computer (IPC) and Normal Computer (PC)
D Flip Flop PLC Ladder Logic
Components of SCADA
PLC Program for Continuous Filling Operation
Micro Memory Card (MMC) in Siemens PLC
PLC Program to Operate Stamping of Parts
PLC Application for Stamping Operation – Example Programming
PLC Ladder Logic Questions and Answers
Instrumentation Engineering Documents
Instrumentation Engineering Documents Questions Answers
Steps in PLC System Design
Function Module in Siemens PLC
What is Function Module in Siemens PLC?
PLC Conversion Program
How to use Converters in PLC
Difference Between Microcontroller and PLC
Interview Questions on Transmission & Distribution
Biosensors Questions & Answers
Surge Impedance Loading of Transmission Line
Ladder Logic Example with Timers
Difference Between Normal Counters and Fast Counters - PLC Basics
Difference Between Normal Counters and Fast Counters – Learn PLC
Difference between Power Cables and Signal Cables
multiphase-flowmeter-working-principle
What are Multiphase Flow Meters? – Working Principle, Advantages
Track PLC Operating Modes
#2 PLC Best Practices – Track Operating Modes
