Reading: HVAC Refrigeration Cycle
Inst Tools > Blog > Common > HVAC Refrigeration Cycle
In this article, we will learn the working principle of the HVAC refrigeration cycle.
Last updated: February 1, 2023 3:59 pm
Common
6 Min Read
In this post, we will see the working of the refrigeration cycle.
HVAC Refrigeration CycleCompressionCondensationExpansion ValveEvaporator
We all use refrigerants in our homes for keeping food items cool. Refrigeration is a very important part of our life, as it is used to achieve cooling purposes. It is an important theory of the HVAC domain and the cooling cycle in HVAC works basically on refrigeration only. If this cycle is not working properly, then the cooling purpose will not be attained.
Basically, this cycle keeps its goal through refrigerant gas. This is the most important part of the refrigeration cycle. The most commonly used ones are R12, R22, R134, and R410A. It easily absorbs heat from the environment and facilitates a proper heat transfer mechanism.
Because, without proper heat transfer, cooling cannot be achieved. So, in a refrigeration cycle, apart from this gas, there are four main working pillars that attain this cooling objective.
Refer to the below figure; which shows that the four primary components are compressor, condenser, expansion valve, and evaporator.
Let us have look at each one of them.
Compression
The process starts with compression. It is the heart of the refrigeration cycle. The role of the compressor, as the name implies, is to compress the low pressure and warm temperature gas entering it. If you compress a gas, its pressure, and temperature increase.
So, at the output of a compressor, you get a highly pressurized and hot gas that is ready to pump fast in the whole cycle. This is also one of the main reasons why the compressor is important because it is responsible for maintaining the flow of the vapor throughout the cycle.
A low-pressure gas will not move swiftly in the pipeline and will eventually not achieve a cooling cycle. The most common types of compressors used are reciprocating and screw.
Condensation
The next step is condensation. It is a network of spiral pipelines across which warm water or air passes.
Remember that in heat transfer, the transfer of temperature takes from hot to cold. In this case, as hot gas from the compressor passes through condenser coils, the temperature of the gas is transferred to the relatively cooler water or air that flows across the coils.
This increases the temperature of the water or air and decreases the temperature of the gas. Because the gas is now converted to liquid due to a dip in temperature, it is called condensation.
Expansion Valve
The low-temperature liquid then enters the expansion valve. As the pressure has still not decreased, the role of the expansion valve is to expand the pressure of the gas.
This expansion lowers the pressure and its output will be low pressure and low-temperature form of liquid and vapor.
Evaporator
The last stage is evaporation. When a liquid is evaporated, it vaporizes, and its temperature increases. Evaporators are nothing but heat exchangers. It is through this stage that the required cooling media of water or air passes.
In contrast to the condenser, the relatively warmer medium here is this water or air; compared to the gas media flowing from the expansion valve output.
So, as per the heat transfer mechanism, heat is transferred from the water or air to the refrigerant gas flowing through evaporator coils. This decreases the temperature of water or air and increases the temperature of the gas. The cycle then continues to the compression stage and it repeats.
Two terms are important to note with compressor – suction and discharge. The suction pressure and temperature of the compressor goes on decreasing as the cycle advances, and the discharge pressure and temperature goes on increasing as the cycle advances.
At a certain stage, the suction and discharge parameters will be maintained; when the water or air temperature is maintaining its set point at the evaporation stage. So, suppose you have started the cycle at 35 deg.C of water in the evaporator.
According to the design, for example, the required setpoint is 22 deg C. The refrigeration cycle will then work to maintain the temperature at around 22 deg C.
Abnormal conditions like very low suction parameters and very high discharge parameters will abort the cycle and indicate to the user that something is wrong in the stage.
In this way, the refrigeration cycle works in achieving cooling purposes.
  • Types of HVAC Chillers
  • HVAC Heat Transfer Loops
  • Automation used in HVAC
  • HVAC Objective Questions
  • Valves in HVAC System
Difference Between Emergency STOP and Emergency Power OFF
Physic Homework Help – Tips to Find Professional Assistance
How To Choose A Surge Protector?
How to Use a Paint Thickness Gauge?
Look Listen Feel of Instruments – Instrumentation Engineer Maintenance
Top 3 Online Bachelor’s Programs in Electronics Engineering
IoT Engineer Job Roles and Responsibilities
How are Data Centers Cooled?
Pneumatic Counter for Counting the Strokes of a Cylinder
Wireless Electric Vehicle Charging
Streams After Electrical Engineering Graduation
Combustion Control – Series and Parallel Air-Fuel Ratio Control
How to Protect Electrical Terminal Blocks From Tampering?
Best YouTube Channels to Learn Cyber Security
What is OTDR Testing
Understanding the Difference between HOP Test and OTDR
What is a Tachometer
What is a Tachometer? – Types, Working Principle
water treatment station
What is a Vent Filter? – Water Treatment Plant
Business Skills Every Engineer Needs
D’Arsonval Movement
D’Arsonval Movement
Hazard Identification and Risk Assessment
Career Opportunities and Scope in Industrial Automation
Why Industrial Safety Automation Matters Today?
Instrument Calibration Multiple Choice Questions
Determine Level of Liquid in the Vessel and its Specific Gravity
Safety Instrumented Systems are different from Basic Process Control Systems
Difference between Intrinsically Safe and Flameproof Equipment ?
Thermocouple cold junction compensation
Why Thermocouple Reference Junction Compensation Required ?
Wiring Diagram
Wiring Diagram
Communicate with Excel from Intouch SCADA
How to Communicate with Excel from Intouch SCADA?
calibration potentiometer for simulating the millivoltage output
Temperature Standards
