Reading: How to use Simulator in Siemens PLC?
  • Control Systems
Inst Tools > Blog > PLC Tutorials > How to use Simulator in Siemens PLC?
Last updated: March 4, 2021 12:30 pm
3 Min Read
The simulator is used when you don’t have an actual PLC and you want to test the logic, It acts as a virtual PLC.
In the last article, I have explained a method to create a new project using a Siemens Simatic manager.
Here, in this article, I will explain how to use the simulator in siemens plc, works the same in both Simatic manager and TIA portal if you have selected CPU-300 or 400.
Also Read:
  1. Download Siemens PLC Software
  2. Create a New Project in Siemens PLC
  3. Example PLC Programs and Tutorials
Here, I will create a program for high and low-level detection and work with a simulator.
  1. Open the Siemens programming environment.
  2. write the program.
Here I0.0 is used for Low-level switch,
I0.1 is used for the high-level switch,
Q0.0 is used for the pump.
When the level is low then the low-level switch will energize and makes the pump run. Here, the pump is latched to provide continuous signal flow.
When the level reaches to a High level due to NC contact it Won’t allow the signal to pass and make pump OFF till it can’t get back to a low level.
  1. Let’s run this logic using the simulator. Follow the below step to run the simulator.
In Simatic manager go to “option” and hit click on “set PG/PC interface”
Siemens PLC simulation
  1. Following window will pop-up. Here, select PLCSIM.MPI to work in the simulator.
You can select another option if you have connected It with actual PLC as per the network you have used for your application.
Hit “ok” will load the selected option.
Siemens PLC SIM
  1. Select option simulation on/off as shown in the below window.
Siemens Offline Simulation
  1. From “insert” you can add input and output variable.
siemens plc simulator
  1. Now let’s download the program to the simulator. Select “Simatic 300” and click on “download icon”
Plc simulator siemens free download
Here, in the simulator, as shown in a red mark change it with PLC SIM (MPI) from TCP/IP otherwise it won’t work.
  1. After downloading In OB environment select icon with “spectacle”.
In the simulator choose ”Run” or “Run-P” mode and test the logic.
S7 PLC Simulator
  1. At low-level pump is on
Siemens PLC Simulator and Plant Simulation Software
  1. When the level reaches a high-level and it will turn OFF the pump.
Siemens Simatic PLC Step7 Simulation
Author: Suhel Patel
  • Troubleshoot PLC Program
  • Protect PLC using Password
  • PLC Maths Instructions
  • Siemens PLC Backup
  • Siemens S7 1200 PLC
Types of PLC Memory
PLC Pump Permissive Interlocks
PLC Programming Example with Pushbutton and Motor
Difference between DCS, PLC, and RTU ?
208kSubscribersSubscribe
PLC Analog Input Scaling
How to Download EcoStruxure Machine Expert? Schneider PLC Software
PLC Ladder Logic Example based on Set Coil and Reset Coil
Two Hand Control Logic using PLC
What is a Wet Contact? – Basics of PLC Wiring
Steps to Configure TCP/IP Communication in Siemens S7-1200 PLC
SCADA Interview Questions
Connecting Blocks in Functional Block Diagram
Connecting Blocks in Functional Block Diagram – Studio 5000
PLC Structured Text Program for Output Generation via Equations
Siemens PLC Course for Beginners
Examples of PLC Programming using Boolean Functions
IP Address Change in Simatic
PLC Configuration of Profinet I/O System
What is Electrical Panel Door Earth Bonding? Explained
Memory Devices Objective Questions – Part 1
Mechanical Torsion Meter Principle
Magnetic Float Level Sensor Principle
Magnetic Float Level Transmitter Working Principle
Induction Motors Faults and Protection
Measurements & Instrumentation Quiz – Set 4
PLC Program for Filling Operation
PLC Program for Continuous Filling Operation
