Reading: How to calculate the tolerance of a RTD sensor
Inst Tools > Blog > Temperature Measurement > How to calculate the tolerance of a RTD sensor
Last updated: December 22, 2018 10:25 pm
4 Comments
3 Min Read
The European standard, also known as the DIN or IEC standard, is considered the world-wide standard for Pt100. This standard, DIN/IEC 60751 (or simply IEC751), requires the RTD to have an electrical resistance of 100.00 Ω at 0°C and a temperature coefficient of resistance (alpha) of 0.00385 Ω/Ω/°C between 0 and 100°C.
RTD-standards
There are actually four resistance tolerances specified in DIN/IEC751:2008
Class AA = ± ( 0.10 + 0.0017 * | t | ) °C
Class A = ± ( 0.15 + 0.0020 * | t | ) °C
Class B = ± ( 0.30 + 0.0050 * | t | ) °C
Class C = ± ( 0.60 + 0.0100 * | t | ) °C
The combination of resistance tolerance and temperature coefficient define the resistance vs. temperature characteristics for the RTD sensor. The larger the element tolerance, the more the sensor will deviate from a generalized curve, and the more variation there will be from sensor to sensor (interchangeability). This is important for users who need to change or replace sensors and want to minimize interchangeability errors.
Tolerance Testing Method
RTD calibrations involving tolerance testing are reserved for low accuracy applications. The values are defined by one of the common models such as the ASTM 1137 or IEC 60751 curve. RTDs calibrated in this way are generally used in industrial style applications
The two common accuracy classes are class A and class B:
rtd-standards-for-class-a-and-class-b
These include errors arising from deviations in R0 and from errors in slope. Frequently, we will see probes rated at a fraction of Class A.
For example, 0.1 ASTM Class A. Fractional accuracy is achievable in sensors alone, but are very difficult to achieve in probes. The calculations are straightforward.
RTD Equations for IEC60751 and ASTM 1137
Example: Calculate the accuracy of a 0.1 ASTM Class A probe at 100 °C
For ASTM standard:
Class A = ± [0.13 + (0.0017 · t)] °C
= (0.13 + (0.0017 · t)) · 0.1
= (0.13 + (0.0017 · 100)) · 0.1
= (0.13 + 0.17) · 0.1
= 0.03
Measure the reference probe temperature = 100.0 °C
Measure the indicated temperature = 100.5 °C
Calculate the error (Difference of Indicated & Reference) = 0.05 °C
Calculate the tolerance at 100.00 °C using ASTM standard = 0.03 °C
Determine tolerance status = Fail (0.05 °C > 0.03 °C)
The above example calculates the RTD tolerance at reference and indicated temperatures and determines the tolerance status of an RTD.
Types of Thermocouple Measuring Junction
Thermocouple Temperature Measurement Errors
Mechanical Temperature Measuring Sensors
Thermocouples Sources of Error
Temperature Coefficient of Resistance (α)
Thermocouple Calculations
4 Comments
  • Giri says:
    May 13, 2015 at 4:06 am
    Hi,
    This is a nice explanation. Can you make a tool for RTD tolerance calculation.
    Regards,
    Giri
    • S Bharadwaj Reddy says:
      May 14, 2015 at 6:55 am
      Hi Giri,
      Thanks for the suggestion. Soon i will post a tool on RTD tolerance.
      Thanks,
      S Bharadwaj reddy
  • Rahul Patel says:
    January 14, 2016 at 10:12 am
    Hi Guys…!
    Its very good information we all appreciate to Mr Reddy to serve and share with us..
  • Farakh hamayun says:
    May 14, 2024 at 10:31 pm
    Its informative thanks for sharing
Thermostat – Types, Working Principle, Advantages, Applications
RTD Calibration Procedure
Important Factors for Thermocouple Selection
Thermocouple Cold Junction Compensation
Thermowell Insertion and Immersion Length
Temperature Calibration Bath Principle
Problems of Reference Junction Compensation : Thermocouples
Difference between PT100, PT1000, Nickel RTD and Balco RTD
Temperature Sensors Interview Questions
Thermistors and Resistance Temperature Detectors (RTDs)
Thermocouple Calibration
Temperature Switch Working
Basics of Temperature Switch
Use of Temperature Transmitters instead of Direct Wiring
Thermowell Wake Frequency Calculation
Difference Between RTD, Thermocuples and Thermistors
Difference Between RTD, Thermocouple and Thermistor
Skin Type Thermocouple
Move function block
Move Instruction in Tia Portal
Infrared Gas Analyzers Questions & Answers
Difference between Absolute, Gauge and Differential Pressure Transmitters
PID Controller
Proportional Integral Derivative Controllers – PID MCQ
Induction Motor Rotor Frequency
Power Systems MCQ Series 1
Selecting A Pneumatic Manifold
How to Select a Pneumatic Manifold
NPT Connections
Difference Between NPT, BSPP and BSPT Seals
