Reading: Heat Transfer Loops in HVAC System
Inst Tools > Blog > Common > Heat Transfer Loops in HVAC System
In this post, we will learn the heat transfer loops in the HVAC system such as air, chilled water, refrigerant, condenser, cooling tower.
Last updated: February 1, 2023 4:00 pm
Common
In this post, we will learn the heat transfer loops in the HVAC system.
What is Heat Exchange?Heat Transfer Loops in an HVAC system
HVAC system works on heat transfer theory. Basically, there are various processes in HVAC where the heat exchange takes place to cool the medium (water or air).
Without this heat exchange, it is not possible to attain the required temperature. In this post, we will see the various heat transfer loops in the HVAC system.
According to the second law of thermodynamics, heat transfer takes place from a body at high temperature to a body at low temperature.
So, if you are making contact with a hotter body with a relatively cooler body, then the cooler body will get the heat from the hotter body. Thus, the temperature of the hotter body will start to decrease gradually and the temperature of the cooler body will start to increase gradually.
Simply put, what happens when you touch a hot pan in cold water? The hot pan relatively becomes cooler as it has transferred its heat to the cold water. This is heat exchange.
We need to know the temperature and flow rate of the medium in which we will implement heat exchange. Heat exchange works with air, water, oil, or water glycol.
You need to consider the maximum temperature crossover or a point at which heat exchange will stop working. This will define the efficiency of heat transfer, and thus the overall system.
In an HVAC system, there are five general types of heat transfer loops. If any issue occurs in any of the loops, then the whole system will be affected. So, it is important to maintain all these 5 loops. Let us have a look at each of these loops step by step.
Refer to the below image for understanding:
HVAC System Heat Transfer Loops
Indoor Air Loop
If you want to cool air, then the warm air will be passed through evaporator cooling coils. In these coils, the refrigerant gas is flowing.
The air will be given by a supply blower, due to which heat exchange will take place between warm air and cooler refrigerant gas.
The temperature of the air will decrease and this relatively cooler air will be taken out of the evaporator coil to the area where it is required.
Chiller Water Loop
If you want to cool water, then the warm water will be passed through evaporator cooling coils. In these coils, the refrigerant gas is flowing.
The water will be given by a chiller pump, due to which heat exchange will take place between warm water and cooler refrigerant gas.
The temperature of the water will decrease and this relatively cooler water will be taken out of the evaporator coil to the area where it is required.
Refrigerant Loop
The warm refrigerant thrown by the evaporator cooling coils is given to the compressor.
The compressor compresses this gas which makes it of a very high temperature and pressure. The output is then given to condenser coils.
Condenser Water Loop
The hot refrigerant gas passes through coils in the condenser, where it makes contact with the cooling water given by the cooling tower.
This decreases the temperature of the gas and the heat is transferred to the cooling water which becomes warmer now.
The warmer water is then pulled by cooling water pumps back to the cooling tower.
Cooling Tower Loop
The warm water from the condenser makes contact with the air drawn by cooling tower fans. This decreases the temperature of the water and the heat is transferred to the surrounding air which becomes warmer now. The cooler water is again given back to the condenser.
These are the five general heat transfer exchange loops in the HVAC system. In this way, we saw the various heat transfer loops in the HVAC system.
  • Types of HVAC Chillers
  • Automation used in HVAC
  • HVAC Objective Questions
  • Valves in HVAC System
What is a Vent Filter? – Water Treatment Plant
Streams After Electrical Engineering Graduation
Top 100 Microcontrollers Project Ideas
What’s the Best GPS Fleet Tracking Software and Systems?
Introduction to Mechatronics
Wet Dust Suppression System
Vacuum Technology is Enabling New Era of Ultra-Powerful Computers: Quantum Computing
What is Transparent Solar Panel? – Working Principle and Theory
What is Circular Chart Recorder?
Field Instrumentation Tips
Difference between Force and Power
Power Tool Maintenance – When And How To Replace Carbon Brushes
Pneumatic Sensing Elements
Automotive Rail Rapid Transit
Roller Conveyor
Difference Between Belt Conveyor and Roller Conveyor
Career Opportunities and Scope in Industrial Automation
Top 20 Service Business Opportunities in the Instrumentation Industry
Top 20 Instrumentation Service Business Opportunities in the Industry
Load Cell Assembly
Urea Bagging Plant – Process Flow
Sensors Used in Automotive Vehicles
Different Types of Sensors used in Automotive Vehicles
Robot and Robotics
Robot and Robotics – Laws, Components, Types, Advantages
Working Principle of Water Chillers
HVAC Water Chillers Principle
Jet Pump
What is a Jet Pump? – Principle, Types, Comparison
Inductive Impedance Questions
Valve-Kv-Sizing-Calculator
Valve Kv Sizing Calculator
Bus Riser in Switchgear
calibrating-and-testing-rtd-sensors
RTD Calibration Procedure
Advanced Skills Required for a PLC Programmer to Get a Job
Piston Flow Meters Working Animation
Piston Flow Meters Working Principle with Animation
thin-layer chromatography
Thin-Layer Chromatography : Manual Method
Instrument Calibration Record
How to Create Calibration Records?
