Reading: Siemens S7-300 CPU Suffix Explanation
Inst Tools > Blog > PLC Tutorials > Siemens S7-300 CPU Suffix Explanation
Last updated: March 4, 2021 12:14 pm
3 Min Read
Siemens S7-300 CPUs suffix explanation
Siemens S7-300 CPUCPU XXXY-Z
If you are in a new project and want to use Siemens S7-300 CPUs you are going to see a wide variety of CPUs under the name of CPU s7-300.
The first step is to open the SIMATIC manager software and choose a new project and go to Hardware configuration you will see the following table:
Siemens S7-300 CPU
  • In the previous table, there is a fixed pattern of CPU title
CPU XXXY-Z
Where
1. XXX is the number of CPU.
The greater the number the more capability the CPU is. Like the CPU scan cycle, memory size and number of IOs can be connected in the PLC.
2. Y is defining the type of CPU and it can be:
  • None: in this case the CPU is an ordinary modular PLC.
  • C: which stands for Compact, i.e. the CPU has a built in number of input output modules in addition to the modules that can be added to the CPU if we need to.
  • IFM: which stands for Integrated Function Module, it’s like the compact CPU but it has internal function module of high speed counters.
  • F: which stands for Fail Safe module, fail safe is a specific module that is used in cases where we need the maximum security of process controlling.
3. Z is defining the communication ports in the CPU and it can be:
  • None: In this case the CPU has only one port for MPI communication.
  • 2 or 2 DP: in this case the CPU ports are
Siemens CPU ports
1 MPI port and 1 DP port for Profibus communication.
C. 2 PTP: this CPU has 2 ports, first port for MPI and a second port for PTP (Point To Point) port
The PTP port can be used to communicate with printers and barcode readers.
D. 2PN/DP: This CPU has 2 ports first port for MPI or DP and 1 or 2 ports for Profinet connection.
Siemens CPU
E. 3PN/DP: This CPU had 1 port for MPI, 1 port for Profibus, and 1 or 2 ports for Profinet.
Siemens CPU MP Port
Author: Karim Ali Anwar
  • Memory Structure of Siemens PLC
  • Connect to the Siemens S7 PLC
  • Upload Siemens PLC Programs
  • InTouch Scada Scripting
  • Programmable Logic Controller
Comparator in PLC Programming
What is Recipe Management in SCADA?
How to Select a SCADA for New PLC Project?
How to Code a FIFO Queue in STL Language in Siemens PLC?
DeMorgan’s Theorems using Ladder Diagram
Repeat Until Statement in SCL Language
System and Local Time in PLC
Sequential PLC Programming for the Pneumatic Valves
How to Create Templates in FactoryTalk View Studio?
What is Hot Standby in PLC?
Single Loop Controller Questions
PLC Program for Food Processing
PLC Program for Food Processing Industry
Open Platform Communication (OPC)
What is RS Linx - Types of Softwares in Rockwell Automation
What is RS Linx? Types of Software in Rockwell Automation
Free Download PLC Book
#10 PLC Best Practices – Assign Register Blocks by Function
Difference between PLC and Computers
PLC Retrofitting Project
What is a PLC Retrofitting Project? – Importance, Procedure
HMI book
HMI Handbook
5 Tips to Pass CFSE Exam
P&ID Guidelines for Storage Tanks
Types of Batteries
Cells and Batteries – Types, Applications, Explanation
Cables Sheath Material
Instrument Cables Sheath Material
Power Triangle
Power Triangle
Calculate Hydrostatic Pressure of a vertical column of Acetic Acid
Temperature Sensor Failure
