Reading: Functions of SCADA
Inst Tools > Blog > PLC Tutorials > Functions of SCADA
Functions of SCADA
Last updated: March 4, 2021 3:38 pm
2 Comments
8 Min Read
A SCADA system performs four functions:
1. Data acquisition
2. Networked data communication
3. Data presentation
4. Control
Data AcquisitionData CommunicationData PresentationControl
These functions are performed by four kinds of SCADA components:
1. Sensors (either digital or analog) with control relays that directly interface with the managed system.
2. Remote telemetry units (RTUs). These are small computerized units deployed in the field at specific sites and locations. RTUs serve as local collection points for gathering reports from sensors and delivering commands to control relays.
3. SCADA master units. These are larger computer consoles that serve as the central processor for the SCADA system. Master units provide a human interface to the system and automatically regulate the managed system in response to sensor inputs.
4. Communications network that connects the SCADA master unit to the RTUs in the field.
SCADA communication
Data Acquisition
First, the systems you need to monitor are much more complex than just one machine with one output. So a real-life SCADA system needs to monitor hundreds or thousands of sensors. Some sensors measure inputs into the system (for example, water flowing into a reservoir), and some sensors measure outputs (like valve pressure as water is released from the reservoir). Some of those sensors measure simple events that can be detected by a straightforward on/off switch, called a discrete input (or digital input).
For example, in our simple model of the widget fabricator, the switch that turns on the light would be a discrete input. In real life, discrete inputs are used to measure simple states, like whether equipment is on or off, or tripwire alarms, like a power failure at a critical facility. Some sensors measure more complex situations where exact measurement is important.
These are analog sensors, which can detect continuous changes in a voltage or current input. Analog sensors are used to track fluid levels in tanks, voltage levels in batteries, temperature and other factors that can be measured in a continuous range of input. For most analog factors, there is a normal range defined by a bottom and top level.
For example, you may want the temperature in a server room to stay between 60 and 85 degrees Fahrenheit. If the temperature goes above or below this range, it will trigger a threshold alarm. In more advanced systems, there are four threshold alarms for analog sensors, defining Major Under, Minor Under, Minor Over and Major Over alarms.
Data Communication
In our simple model of the widget fabricator, the “network” is just the wire leading from the switch to the panel light. In real life, you want to be able to monitor multiple systems from a central location, so you need a communications network to transport all the data collected from your sensors.
Early SCADA networks communicated over radio, modem or dedicated serial lines. Today the trend is to put SCADA data on Ethernet and IP over SONET. For security reasons, SCADA data should be kept on closed LAN/WANs without exposing sensitive data to the open Internet. Real SCADA systems don’t communicate with just simple electrical signals, either.
SCADA data is encoded in protocol format. Older SCADA systems depended on closed proprietary protocols, but today the trend is to open, standard protocols and protocol mediation. Sensors and control relays are very simple electric devices that can’t generate or interpret protocol communication on their own.
Therefore the remote telemetry unit (RTU) is needed to provide an interface between the sensors and the SCADA network. The RTU encodes sensor inputs into protocol format and forwards them to the SCADA master; in turn, the RTU receives control commands in protocol format from the master and transmits electrical signals to the appropriate control relays.
scada hmi
Image courtesy : nelson electric service
Data Presentation
The only display element in our model SCADA system is the light that comes on when the switch is activated. This obviously won’t do on a large scale — you can’t track a lightboard of a thousand separate lights, and you don’t want to pay someone simply to watch a lightboard, either.
A real SCADA system reports to human operators over a specialized computer that is variously called a master station, an HMI (Human-Machine Interface) or an HCI (Human-Computer Interface). The SCADA master station has several different functions. The master continuously monitors all sensors and alerts the operator when there is an “alarm” — that is, when a control factor is operating outside what is defined as its normal operation.
The master presents a comprehensive view of the entire managed system, and presents more detail in response to user requests. The master also performs data processing on information gathered from sensors — it maintains report logs and summarizes historical trends.An advanced SCADA master can add a great deal of intelligence and automation to your systems management, making your job much easier.
Control
Unfortunately, our miniature SCADA system monitoring the widget fabricator doesn’t include any control elements. So let’s add one. Let’s say the human operator also has a button on his control panel. When he presses the button, it activates a switch on the widget fabricator that brings more widget parts into the fabricator.
Now let’s add the full computerized control of a SCADA master unit that controls the entire factory. You now have a control system that responds to inputs elsewhere in the system. If the machines that make widget parts break down, you can slow down or stop the widget fabricator. If the part fabricators are running efficiently, you can speed up the widget fabricator. If you have a sufficiently sophisticated master unit, these controls can run completely automatically, without the need for human intervention.
Of course, you can still manually override the automatic controls from the master station. In real life, SCADA systems automatically regulate all kinds of industrial processes.
For example, if too much pressure is building up in a gas pipeline, the SCADA system can automatically open a release valve. Electricity production can be adjusted to meet demands on the power grid. Even these real-world examples are simplified; a full-scale SCADA system can adjust the managed system in response to multiple inputs.
Introduction to SCADA
Applications of SCADA
Process Automation Quiz
SCADA Questions & Answers
Compare DCS and PLC systems
PLC, DCS, and ESD Marshalling Cabinet Checks
Principle of Operation of PLC
PLC Example on Manufacturing Line Assembly
Making Multi Way Switches using PLC
How to import GSD files into the TIA Portal? – Siemens PLC
2 Comments
  • Dharmendra Parashar says:
    June 16, 2019 at 2:48 pm
    Nice
  • Eric Harrelson says:
    July 3, 2019 at 7:34 pm
    Great summary. Inst Tools has been useful resource, I use it frequently.
Siemens Tia Portal PLC Training Course
How to Install GSD File in Step 7 PLC using Simatic Manager?
PID with Practical Example
Move, Move Bit, Move Digit – Examples of Omron PLC Programs
How to Work with Allen Bradley RsLogix Emulator?
Mixing Process with Valve Control
PLC Mixing Process with Adjustable Timer and Valve Control
PLC Ladder Logic Simulator Mobile Apps For Android
Control Algorithms in PLC Programming
Transistor Output Wiring
PLC Output Types
Sorting PLC Program Simulation
Sorting & Distribution Line PLC Programming – Advanced Logic
Factory IO PLC Course
Factory I/O PLC Automation Training Course (Free)
Difference between Signal Cables and Control Cables
Using Clock Memory Bits in TIA Portal - Siemens PLC
4-20mA Image
4-20mA Graphical Calculations
Level-Measuring-Instruments-Velocities-of-Propagation
Level Measuring Instruments Velocities of Propagation
Types of Can Open network topologies
CANOpen Network Topology
Types of Electrical Loads
Diodes Voltage Tripler
displacer level transmitter cylindrical weighs
Displacer Level Transmitter 5-point Calibration
DP Transmitter Located 10 feet Beneath the Vessel
pi filter Operation
pi filter Operation
