Reading: Field Instruments Selection Aid
Inst Tools > Blog > Instrumentation Design > Field Instruments Selection Aid
Last updated: December 22, 2018 1:05 am
2 Min Read
Operating Conditions and Requirements on the Measuring Point
When a New Field Transmitter installation is being planned, measuring point / tapping point to be selected and certain requirements must be satisfied in order for the desired measuring effect to be realized. Shall the meter provide information by itself (for example through local indication) or support another function (for example as an actual value generator for a controller). The planner begins his preparations for the meter selection by considering the operating conditions. He raises questions regarding the measuring medium, the local conditions and the measured value presentation requirements.
The following keyword summary is considered as a selection aid:
Properties of the Measuring Medium:
– Gas, steam: dry, wet
– Liquids: gas and solids content, crystallizing component deposits, dust in gas
– Density
– Temperature, temperature variations, time relationships
– Viscosity
– Electrical conductivity, of the deposits
– Chemical aggressiveness, material selection
– Abrasion danger
Operating Conditions:
– Pipe nominal diameter
– Design of a channel, slopes, damming
– Pressure rating
– Flow rate, smallest, largest value: type of flow changes (step changes)
– Flow conditions: linear, turbulent flow velocity distribution, swirl, pulsation
– Bidirectional (forward and reverse)
– Static pressure, pressure shock, pressure drop permissible
Ambient Conditions:
– Ambient temperature
– Humidity effects, degree of protection
– Dust entry, degree of protection
– Vibration
– Pipeline construction upstream and downstream of the measuring point
– Explosion protection
– Power supply, cabling
– Electromagnetic and radio frequency interference
– Mounting options
Measured Value Presentation:
– Measuring accuracy
– Fixed, adjustable, internal, external measuring range
– Internal, external monitoring capabilities
– Local indication
– Totalization, integration
– Alarm signalling unit
– Standardized analog output, what value?
– Pulse output for remote totalization
– Communication, which type?
– PROFIBUS, FOUNDATION Fieldbus
– HART Protocol
– Calibratability
Ferrules and Cross Ferruling
Electrical Signal and Control Wiring
Guided Wave Radar Level Sensor Pressure and Temperature Effects
Basics of Thermistors, Thermocouples and RTD’s
How to Prepare Pressure Gauge Datasheet ?
Selecting the Best Inductive or Capacitive Sensor
Zener Diode Voltage Regulators
Instrumentation Deliverables Generated from 3D Modeling
Single and Three Phase Immersion Electrical Heaters Wiring Circuits
Turbine-Compressor System Architecture
Instrumentation Air System Design
How Earth Resistance is Measured
Relay Latching Circuit using Push Button
Measuring Instruments
Flow Instruments – Selection, Principle & Application
Instrument Heat Trace
Electrical Heat Tracing
float-type level switch control a pump
How to Select a Inductive Proximity Sensor
Magnetic Flow Meters
Pull-up switch circuit.
Pull Up and Pull Down Switch Circuits
Instruments Tapping Points
O Ring Failure
How O-Ring Failure caused NASA’s shuttle to Blast ?
Advantages & Disadvantages of CNC Milling
What are the Advantages & Disadvantages of CNC Milling?
Thermocouple Extension Lead Minimizer Circuit
Thermocouple Wires and Extension Lead Issues
Elevated Span and Suppressed Span
DP Level Transmitter Elevation and Suppression Corrections
Analog Electronics Projects
Analog Electronic Projects for Final Year Engineering Students
Differential Pressure Transmitter Wet Leg Compensation
Differential Pressure Transmitters Compensated Leg Systems
Column Efficiency and Column Resolution Questions and Answers
RFID Based Projects for Engineering Students
RFID Projects for Engineering Students
Calibration and Troubleshooting of Oxygen Analyzer
