Reading: Fiber Optic Cable vs Coaxial Cable
Inst Tools > Blog > Common > Fiber Optic Cable vs Coaxial Cable
In this article, you will learn the fiber optic cable vs coaxial cable. Lets discuss them with detailed comparison and their features.
Last updated: January 20, 2023 9:10 pm
Common
3 Min Read
Fiber optic cables and coaxial cables are used in various applications. But many of us are still not having proper knowledge about fiber optic cable and coaxial cable. So, today in this article we will discuss the difference between fiber optic cable and coaxial cable.
Comparison of Fiber Optic and Coaxial CablesPhysical ConstructionMaterial of ConstructionTransmission MethodBandwidthTransmission SpeedEfficiencyDiameterWeightInstallation ComplexityCostUses
The following are the main comparison between fiber optic and coaxial cables.
  • Physical Construction
  • Material of Construction
  • Transmission Method
  • Bandwidth
  • Transmission Speed
  • Efficiency
  • Diameter
  • Weight
  • Installation Complexity
  • Cost
  • Uses
Fiber optic cable is made of the core which is a fiber core. Outside the fiber core, a cladding is present. Cladding is protected by a coating and a strength membrane. This whole assembly is protected by an outer jacket.
Fiber Optic
Coaxial Cable is made up of conductors which are protected by insulators and sheath/shield and outer cover.
Coaxial
Fiber optic cable is made up of plastics and glass. While coaxial cable is made up of plastics and copper wire.
Transmission Method
Fiber optic cable transfers data or signal in the form of light. While coaxial cable transfers the data or signals in the form of an electrical signal.
Bandwidth
Fiber optic cable has a very high bandwidth when compared to coaxial cable.
Transmission Speed
Fiber optic cable has a very high transmission speed of up to 10 Gbps and the transmission speed of coaxial cable is only up to 10 Mbps.
Efficiency
Fiber optic cable has very high efficiency when compared to coaxial cable. Fiber optic cable has the highest noise immunity whereas coaxial cable also has good noise immunity.
Diameter
Fiber optic cable’s diameter is less when compared to coaxial cable. Hence, coaxial cable occupies more space while installation. But this space merely makes any difference.
Weight
Fiber optic cable is very light in weight when compared to coaxial cables.
Fiber optic cable installation requires special skill sets and the job is also a bit complex. While coaxial cable installation is a bit easy.
Cost
Fiber optic cable is more costly when compared to coaxial cable
Uses
Fiber optic cable is used for data transfers in process plants, modern high-speed internet connections, and the medical field. Coaxial cable is used for cable TVs and telephone communications also.
  • Motor Feedback PLC Logic
  • Steps in PLC System Design
  • SCADA System Vulnerabilities
  • Delta PLC and VFD with Modbus
  • Industrial Automation Documents
Difference between Anode and Cathode
Seismic Displacement Sensing Accelerometer
Lag time
How is Electricity Generated From Wind Energy?
What is a Flange Gasket ?
What is HVAC System?
Custom CNC Machining – A Complete Guide You Cannot Miss
Difference between Force and Power
What is C Programming Language? Fundamentals, Pros & Cons
How Technology is Shaping the Future of Education?
How Not to Install an Instrument and Wrong Practices
Range Finders – Ultrasonic, Light, & Global Positioning Systems
What is a Thin Film Deposition System? How do they work?
Difference between HVAC Absorption Chillers and Electric Chillers
Pilot Operated Back Pressure Regulator Valve
Industrial IoT Job Roles and Responsibilities
IoT Engineer Job Roles and Responsibilities
Creating CNC Program
Steps Followed Before Creating CNC Program
Modbus Code
Modbus Relative Addressing
Production Planning Software
Hydraulic Systems
What is a Photoelectric Sensor
What is a Photoelectric Sensor?
Heavy Equipment Transport
4 Tips For Shipping Large Construction Equipment
Introduction to MEMS (Microelectromechanical Systems)
Instrumentation Engineering Standards Interview Questions & Answers
Electrical Machines Objective Questions & Answers
Flow Meters Troubleshooting
Turbine Flow Meters Troubleshooting
VFD Engineer Roles - Installation and Commissioning
VFD Engineer Roles – Installation and Commissioning
Adaptive Controller Overview
What is Adaptive Control?
Burning Oven PLC Program
PLC Program for Ceramic Burning Oven Conveyor System
Allen Bradley Powerflex VFD
Pneumatic Relay
Pneumatic Relay Questions
