Reading: Factory Acceptance Test (FAT) of a PLC Panel
Inst Tools > Blog > PLC Tutorials > Factory Acceptance Test (FAT) of a PLC Panel
In this article, you will learn the general guidelines and how-to procedure of factory acceptance test (FAT) of a PLC Panel.
Last updated: April 18, 2023 12:24 pm
6 Min Read
PLC system always comes in a control panel. It is not possible to run the PLC system without a control panel.
Basically, it is the electrical panel where the PLC is mounted along with other electric devices like contactors, relays, terminal boards, fuses, circuit breakers, and bus bar. All of these components comprise an electrical panel.
Factory Acceptance Test of PLC Panel
Suppose you have designed a PLC system and made it ready for testing. But, you need to follow some general guidelines to see whether all the components and their wiring is proper or not. This has to be done in front of the customer before dispatching it to them. This process is called FAT (Factory Acceptance Test).
So the PLC panel will be tested at the factory and only accepted by the client if it is functioning properly as per the design documents.
Let’s study the step-by-step procedure for executing a proper FAT of the system.
You first of all created documents like the IO list, electrical drawing, GA (General Architecture) of the panel, and BOM (Bill of Materials) and sent them to the customer for approval.
So, before calling them for FAT at your factory, make sure you have two hard copies of the above-mentioned documents for verification; one for you and the other for the customer to check and approve.
Now that the client is with you and ready for inspection; first of all, let them verify all the components according to BOM (Bill of material) visually. It is to be done to ensure that all the materials that you have sold to them are present in the panel or not.
Let them verify the GA of the PLC panel and visually check whether it’s proper or not.
Let them inspect the panel outdoors, fabrication, and gland hole design approved by them. So, as you must have read, this step is the visual verification of all the documents and electrical panels before powering them up.
After the visual inspection has been done, connect the main power supply to the panel and power it up.
Check the incoming voltage with a multimeter on its terminal board. Check the voltage between earth to neutral and see if it is below 0.5V. If everything is proper, then turn on all the MCBs in the panel one by one.
Turning on the MCBs and other circuit breakers means the panel is fully charged now. So, the PLC is also powered up eventually.
Now that the PLC is powered up, you have to connect your laptop or PC to it and download the final backup in it.
After downloading, keep the PLC in run mode and see if it shows any error or not. If you have HMI or SCADA also in the panel, then download its final program too.
Now, you have to check the IOs of the PLC. According to the wiring that you have done, check digital inputs first.
On giving the input at the desired terminal point in the panel or somewhere else, the corresponding PLC input address in the program must be turned on.
Then, check the digital outputs. According to the PLC output address that you have turned on, the physical PLC output must also turn on.
When it is ON, check the output voltage across it. The output is connected to a relay board mostly. If the relay turns on, then check whether its output is given to a contactor or terminal board.
The final objective is to check the output voltage coming across the terminals. Then, check the analog inputs.
On giving the input, the corresponding PLC input address in the program must be shown analog counts accordingly.
Then, check the analog outputs. According to the PLC output address that you have given counts, the physical PLC output must also give the corresponding counts.
Check the current or voltage across the terminals where the wire is connected.
Now, sum up all the points tested and make a compliance report. Give the remarks accordingly if something is faulty or pending to be checked.
If the client gives approval after testing has been completed, then your PLC panel is ready to be dispatched and FAT has been completed.
In this way, we saw the general steps in conducting the FAT of a PLC system.
  • Types of Noise in Electronics
  • AS-interface Communication
  • PLC System Site Acceptance Test
  • Troubleshoot the Status of a PLC
  • Control Motion using VFD drives
Automatic Curtain Control – PLC Programming Solution
Micro PLC Hardware Configuration
Example of Flip-Flop PLC Program for Lamps Application
Function Blocks in PLC (FBs) – What You Need To Know?
Jump Instruction in Siemens Tia Portal
Applications of PLC Programming in Bottle Filling Process
PLC Count values higher than 999
LS Electric PLC Program Example: Clothes Washing System
Ladder Logic for Flow Meter Totalizer
Machine Tool and Coolant Control: PLC Ladder Logic Design
If Else Statement in SCL Language
Mitsubishi FX series programming basics
How to Write and Read a Program for Mitsubishi FX3U PLC?
PLC Timer Application in Security Camera Recording
PLC Program for Automatic Parameter initialization
PLC Program for Automatic Parameter Initialization When Power UP
RSlogix 500 to communicate with Excel
How to Communicate with Excel from RsLinx?
Midline output instruction
What is Midline Instruction in Siemens PLC?
SCADA Interview Questions
Simple PLC example Hardware configurations
Stability in Frequency Domain
The Design Problem
Confined Space
Fasteners and General Corrosion of Electrical Motors
PLC Memory Mapping
PLC Memory Mapping and I/O addressing
Free Download PLC Book
#10 PLC Best Practices – Assign Register Blocks by Function
PLC based drilling machine
Drilling Process using PLC Program
Dissolved oxygen measurement using Optical Fiber Communication
Fiber Optic Sensors
