Reading: Electrician Tools MCQ Questions
Inst Tools > Blog > Electrical MCQ > Electrician Tools MCQ Questions
We prepared MCQ questions on electrician tools for exam preparation to help you understand basic electrical concepts.
Last updated: August 27, 2024 12:53 pm
Electrical MCQ
9 Min Read
Electrician Tools MCQWhat is a multimeter primarily used for?Which tool is used to bend electrical conduit to required angles?What is the purpose of fish tape in electrical work?Which tool would an electrician use to remove insulation from electrical wires?What tool is essential for testing electrical outlets and circuits for live voltage?Which tool is used to secure electrical connectors onto wires?What does a cable puller assist with in electrical installations?What is the primary function of lineman pliers?Which tool helps an electrician to determine the short circuit of an electrical circuit?What is the primary use of a voltage tester?Which tool is commonly used to cut and strip large-diameter cables?Which tool is used to identify a specific wire in a bundle?What is the primary purpose of a torque screwdriver in electrical work?Which tool is essential for determining the presence of AC and DC voltage?What is the function of a wire nut?Which tool helps electricians to punch down wires into terminal blocks?What is the primary use of a knockout punch set?What tool would an electrician use to measure the length of wire in a spool?What is the purpose of a non-contact voltage tester?Which tool is designed to measure insulation resistance in wires and electrical components?What is the primary function of a clamp meter?Which tool is used to ensure that wires and cables are routed through walls without damage?What is the primary function of an electrical test lamp?What is the purpose of a continuity tester in electrical work?Which tool is essential for cutting precise shapes in drywall for electrical boxes?What is the primary use of a laser level in electrical work?Which tool is used to remove the outer jacket of non-metallic sheathed cable?What is the function of an electrician’s hammer?Which tool helps to identify the exact location of studs behind walls?What tool is used to make quick and precise cuts in metal conduit and other tubing?
This video explains the electrician tools questions with detailed explanations.
Electrician Tools - Electrical Engineering Test
Question 1
A. It helps to join the cables and test the healthiness
B. Provides voltage and current to run the motor
C. Perfectly measures the insulation resistance of the motor
D. Testing electrical voltage, current, and resistance
Show the Answer
Question 2
A. Fish tape
B. Conduit bender
C. Cable puller
D. Wire stripper
Show the Answer
Conduit bender
Question 3
A. Measuring wire length
B. Bending conduit
C. Pulling wires through conduit
D. Cutting wires
Show the Answer
Question 4
A. Conduit bender
B. Voltage tester
C. Wire stripper
D. Fish tape
Show the Answer
Wire stripper
Question 5
A. Fish tape
B. Conduit bender
C. Circuit tester
D. Wire stripper
Show the Answer
Circuit tester
Question 6
A. Multimeter
B. Crimping tool
C. Conduit bender
D. Fish tape
Show the Answer
Crimping tool
Question 7
A. Testing circuit continuity
B. Stripping wire insulation
C. Pulling heavy gauge wire through conduits
D. Measuring voltage
Show the Answer
Question 8
A. Measuring electrical current
B. Bending conduit
C. Cutting and gripping wires
D. Testing voltage
Show the Answer
Question 9
A. Wire stripper
B. Fish tape
C. Conduit bender
D. Continuity tester
Show the Answer
Continuity tester
Question 10
A. Checking for live voltage
B. Test the current in a loop
C. Bending conduits
D. Measuring the Capacitance
Show the Answer
Question 11
A. Voltage tester
B. Fish tape
C. Cable cutter
D. Lineman pliers
Show the Answer
Cable cutter
Question 12
A. Circuit tracer
B. Continuity tester
C. Cable puller
D. Wire stripper
Show the Answer
Circuit tracer
Question 13
A. Cutting wires
B. Ensuring connections are tightened to maximum torque
C. Ensuring connections are tightened to specified torque
D. Ensuring connections are tightened to minimum torque
Show the Answer
Question 14
A. Multimeter
B. Crimping tool
C. Fish tape
D. Conduit bender
Show the Answer
Multimeter
Question 15
A. Pulling wire through conduit
C. Securing wire connections
D. Testing voltage
Show the Answer
Question 16
A. Voltage tester
B. Cable cutter
C. Wire stripper
D. Punch down tool
Show the Answer
Punch down tool
Question 17
A. Bending conduit
B. Testing circuit continuity
C. Creating holes in electrical boxes
D. Stripping wire insulation
Show the Answer
Question 18
A. Multimeter
B. Fish tape
C. Circuit tester
D. Measuring tape
Show the Answer
Measuring tape
Question 19
B. Detecting voltage without direct contact
C. Stripping insulation
D. Detecting voltage with direct contact
Show the Answer
Question 20
A. Wire stripper
B. Multimeter
C. Continuity tester
D. Insulation resistance tester
Show the Answer
Question 21
A. Measuring electrical parameters by clamping around a conductor
B. Measuring electrical parameters by direct contact with the cable
C. Measures R, L, and C
D. Cutting wires and measures resistance
Show the Answer
Question 22
A. Cable puller
B. Fish tape
C. Circuit tester
D. Wire stripper
Show the Answer
Fish tape
Question 23
A. Indicating the presence of voltage
B. To test the electrical short or open circuits
C. Measuring the live voltage values
D. To test the electrical lamps working or not
Show the Answer
Question 24
A. Measuring the capacitance value
B. Checking if a circuit can carry current
C. To test the electrical load impedance
D. Measuring voltage value in a circuit
Show the Answer
Question 25
A. Cable ripper
B. Drywall saw
C. Fish tape
D. Hotwall saw
Show the Answer
Drywall saw
Question 26
A. Stripping insulation
B. Aligning electrical boxes and conduits
C. Measuring voltage of the electrical cables
D. Cutting wires in steps
Show the Answer
Question 27
A. Multimeter
B. Conduit bender
C. Cable ripper
D. Voltage tester
Show the Answer
Cable ripper
Question 28
A. Cutting heavyduty cables
B. Removing the cables shied
C. Installing and removing nails, staples, and other fasteners
D. Bending conduit as per the required shape
Show the Answer
Question 29
A. Stud finder
B. Multimeter
C. Fish tape
D. Wire stripper
Show the Answer
Stud finder
Question 30
A. Voltage tester
B. Hacksaw
C. Wire stripper
D. Conduit bender
Show the Answer
Hacksaw
  • Identify Phase, Earth, and Neutral Wires
  • Troubleshooting Pump Control Circuit
  • Assembling an Electrical Conduit Seal
  • Electrical Conduit Types and Advantages
  • Why Are Neutral and Earth Separated?
Types of Relays – Questions and Answers
Electrical Machines Torque Production Quiz
Electric Circuits Objective Questions – Set 13
Electrical Machines MCQ Series 16
Three Phase Induction Motor Power Factor Control
Single Excited Electric Field Systems Quiz
Electromagnetic Subject Quiz
Electrical Machines MCQ Series 15
Electrical Machines MCQ Series 18
Induction Motor Phasor Diagram
DC Generators Characteristics Quiz
Electric Circuits Objective Questions – Set 15
HVAC Multiple Choice Questions
Synchronous Machines EMF Polygon Questions
Electric Circuits Objective Questions – Set 5
Network Theorems Objective Questions and Answers
Electrical Machines Loss Dissipation Quiz
Power Systems MCQ Series 6
Salient Pole Machines Quiz
Electrical Machines MCQ Series 2
Induction Machines Circle Diagrams
Classification of HVAC chillers
Classification of HVAC Chillers
Two Electrode Conductivity Probes
Two Electrode Conductivity Probes Principle
High-pressure Service Level Transmitters Misunderstood Zero Drifts
3 Phase Balanced Loads
Power in Balanced 3 Phase Loads
Hydraulic Systems
Minimum Oil Circuit Breaker (MOCB) Spares & Service
Minimum Oil Circuit Breaker (MOCB) No Vendor Spares & Service
Control Valve Recommended Practices
Control Valve Recommended Practices for Harsh Process Conditions
Instrumentation Calculator
Instrumentation Calculator Android App
