Reading: Electrical Standards
Inst Tools > Blog > Calibration > Electrical Standards
Last updated: December 22, 2018 12:38 am
Calibration
3 Min Read
Electrical calibration equipment – used to calibrate instruments measuring voltage, current, and resistance – must be periodically calibrated against higher-tier standards maintained by outside laboratories. In years past, instrument shops would often maintain their own standard cell batteries (often called Weston cells) as a primary voltage reference. These special-purpose batteries produced 1.0183 volts DC at room temperature with low uncertainty and drift, but were sensitive to vibration and non-trivial to actually use. Now, electronic voltage references have all but displaced standard cells in calibration shops and laboratories, but these references must be checked and adjusted for drift in order to maintain their NIST traceability.
One enormous benefit of electronic calibration references is that they are able to generate accurate currents and resistances in addition to voltage (and not just voltage at one fixed value, either!). Modern electronic references are digitally-controlled as well, which lends themselves well to automated testing in assembly-line environments, and/or programmed multi-point calibrations with automatic documentation of as-found and as-left calibration data.
A photograph of some electronic calibration references appears here:
If a shop cannot afford one of these versatile references for benchtop calibration use, an acceptable alternative in some cases is to purchase a high-accuracy multimeter and equip the calibration bench with adjustable voltage, current, and resistance sources. These sources will be simultaneously connected to the high-accuracy multimeter and the instrument under test, and adjusted until the high-accuracy meter registers the desired value. The measurement shown by the instrument under test is then compared against the reference meter and adjusted until matching (to within the required tolerance).
The following illustration shows how a high-accuracy voltmeter could be used to calibrate a handheld voltmeter in this fashion:
It should be noted that the variable voltage source shown in this test arrangement need not be sophisticated. It simply needs to be variable (to allow precise adjustment until the high-accuracy voltmeter registers the desired voltage value) and stable (so the adjustment will not drift appreciably over time). The accuracy of your calibration in the previous circuit originates not from the variable voltage source, but rather from the high-accuracy multimeter used as the calibration standard. It is the high-accuracy multimeter that serves as the calibration reference here, not the voltage source – it is the high-accuracy multimeter that functions as the standard.
Shunt Calibration of a Strain Gauge Load Cell
Current to Pressure (I/P) Converter Calibration Procedure
Portable Gas Detectors Calibration Procedure
History of Measurement
Pressure Gauge Calibration Procedure
Instrument Maintenance and Calibration System
What is Sensor Trim and Output Trim in Smart Transmitter?
Instruments Calibration Procedures
Multimeter – What Do Digits and Counts Mean?
How to Calibrate Oxygen Analyzer? – O2 Sensor Testing Procedure
Pressure Transmitter Calibration at the bench
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
Solenoid Valve Functional Testing
Motor Operated Valve Functional Testing
SMART Transmitters Block Diagram
Smart Transmitters LRV & URV
Calibration of Pyrometers using Black Body
Pressure Gauge Functional Testing
Pressure Gauge Calibration according to Standard DKD-R-6-1
Pig Signalling Switches Functional Testing
Single Position Calibration of Temperature Bath
What is FAT and SAT?
Closed Tank - Dry Reference Leg
Basics of Level Measurement
load cell in deflection
Load Cell Working Principle
ON OFF Control Principle
On/off Control Theory
Types of Inductors
What is an Inductor? – Types of Inductors
Negative Readings in Gas Detectors
Why Negative Readings in Gas Detectors ?
What is PLC
What is a PLC? – Programmable Logic Controller
Shutdown Maintenance
The 5 Phases of Conducting Shutdown Maintenance
