Reading: Electrical Energy Management System and SCADA in Power System
Inst Tools > Blog > Electrical Basics > Electrical Energy Management System and SCADA in Power System
Today we will discuss electrical Energy Management systems (EMS) and Supervisory Control & Data Acquisition (SCADA) in Power System
Last updated: July 28, 2022 10:04 am
Electrical Basics
In this article, we will discuss the electrical Energy Management System (EMS) and Supervisory Control & Data Acquisition (SCADA) in Power System
What is an Energy Management System (EMS)?Advantages of EMSWhat is Supervisory Control & Data Acquisition (SCADA)?Objectives of SCADAAdvantages of SCADA
You might have often come across terms like EMS and SCADA. Do you know what they stand for and their importance in the power system??
EMS is a system for efficient management of energy in the power system. It is used for optimizing the performance of the generation and transmission systems by monitoring and controlling them through computerized tools.
EMS is an important system for the reliable and efficient operation of power systems and is related to its real-time monitoring, operation, and control.
EMS encompasses a variety of software applications for energy management which may provide a variety of services to the operator as well as the end user and thus enhance the performance of the whole power system.
Advantages of EMS
  1. Efficient monitoring of system parameters, enabling the operator to make informed decisions.
  2. Automatic control and automation of a power system and efficient, economic & optimal generation control.
  3. Optimal allocation of resources and network utilization.
  4. Better resource management.
  5. Improved quality of energy supply and system reliability.
  6. Provision of all historical data and immediate overview of the complete system for analysis.
  7. Reducing the time for troubleshooting, switching errors, and maintenance cost.
  8. Centralized power analysis, better utilization of manpower, and cost reduction
As the name itself suggests, SCADA is used for the control and monitoring of any system. SCADA is a collection of equipment that will provide an operator at a remote location with enough information to determine the status of particular equipment or entire station and cause actions to take place regarding the equipment or network.
It achieves this requirement by collecting reliable field data through remote terminal units (RTUs), Intelligent Electric Devices (IEDs) and presenting them to user requirements.
It includes the collecting of the information, transferring it back to the central site, carrying out any necessary analysis and control, and then displaying that information on a number of operator screens or displays. The required control actions are then conveyed back to the process.
Objectives of SCADA
The important objectives of SCADA are listed below:
  1. Monitoring: Continuous monitoring of the parameters of voltage, current, etc.
  2. Measurement: Measurement of variables for processing.
  3. Data Acquisition: Frequent acquisition of data from RTUs and Data Loggers.
  4. Data Communication: Transmission and receiving of large amounts of data from the field to control centers.
  5. Control: Online real-time control for closed loop and open loop processes.
  6. Automation: Automatic tasks of switching of transmission lines, CBs, etc.
Advantages of SCADA
  1. Improved operation of the plant or process resulting in savings due to optimization of the system
  2. Increased productivity of the personnel
  3. Improved safety of the system due to better information and improved control
  4. Protection of the plant equipment
  5. Safeguarding the environment from a failure of the system
  6. Improved energy savings due to optimization of the plant
  7. Improved and quicker receipt of data so that clients can be invoiced more quickly and accurately
  8. Compliance with Government regulations for safety and metering
We can see that the flow of information takes place from process/equipment to SCADA and further to EMS where the data is analyzed through certain software and the required action is conveyed from EMS to the process/equipment through SCADA.
Thus, these systems help in the automation of the power system and fulfilling the biggest requirement of a high-reliability and high-energy efficiency power system.
A Typical SCADA Screen of a Generating Station
Author: Nitin Chaudhary
What is Gas-Insulated Transmission Line? Principle Advantages
What are DOL and RDOL starters? Advantages, Disadvantages
What is an Electrical Conduit? – Types – How to Choose?
Difference between Soft Starter and VFD
Advantages of Three Phase System Compared to Single Phase System
Difference Between Overcurrent and Overload
What is ELCB? Principle, Advantages, Disadvantages, Applications
Difference Between Alternator and Generator?
DOL Starter – Working, Circuit, Advantages, Disadvantages, Applications
What is a Wave Trap? – Power Line Carrier Communication
Why V/f Ratio is kept Constant in VFD?
Difference Between MPCB and MCCB
How to Protect Electrical Terminal Blocks From Tampering?
Motors Inrush Currents
Motor Inrush Current Measurements
Electrical Power Grid Automation
Instrument Cable
Difference Between Power Cable and Instrument Cable
Difference between Power Cables and Signal Cables
Electrical Conduit
What is Electrical Conduit? Types, Advantages, Disadvantages
Polarization Index (PI) Test
Polarization Index (PI) Test and DA Test
Top 10 Common Mistakes on Electrical Systems
What is Electrical Busbar
What is Electrical Busbar? Types, Advantages, Disadvantages
Turbine Flow Meter
All About Turbine Meters
Comparison of Control Loops - Open, Closed, Cascade, Feedforward, Ratio
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
PLC Best Practices
#1 PLC Best Practices – Split PLC Code into Modules
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Wet-leg
Density Measurement using DP Transmitter for closed tank with wet leg
Difference between RTJ and T&G Flanges
Difference between RTJ and T&G Flange Facings
The Principle of Dead Weight Pressure Tester
Siemens PLC Interview Questions & Answers
Siemens PLC Interview Questions and Answers
Playground Swing Logic Exercise Program in PLC
