Reading: What is Electrical Busbar? Types, Advantages, Disadvantages
Inst Tools > Blog > Electrical Basics > What is Electrical Busbar? Types, Advantages, Disadvantages
A busbar is a metallic bar in a switchgear panel used to carry electrical power from incoming feeders and distributes to outgoing feeders.
Last updated: October 17, 2023 3:18 pm
R Jagan Mohan Rao
Electrical Basics
2 Comments
A busbar is a metallic bar in a switchgear panel used to carry electric power from incoming feeders and distributes to the outgoing feeders. In simple terms, busbar is a electrical junction where incoming and outgoing currents exchange.
Electrical BusbarPurpose of Bus-barTypes of bus barsSingle bus-bar SystemDouble Bus-bar SystemRing Bus-bar System
Electrical Busbar consists the number of lines electrically, which are operating at the same voltage and frequencies. Generally, copper or aluminum conducting material is used in the construction of bus bars.
They are used either in the form of pipe or thin-walled tubes.
Electrical Busbar
Types of busbars
Purpose of Bus-bar
Bus bars are arranged in a different configurations, any particular arrangement of bus-bar is to achieve adequate operating flexibility, sufficient reliability and minimum cost.
The circuit breakers are arranged to get the maximum availability to plant operations.
Types of bus bars
Important bus-bar arrangements are discussed in this article. Based on the construction of the bus bar, they are divided as follows.
  • Single bus-bar system.
  • Double bus-bar system.
  • Ring bus-bar system.
As the name itself indicates, that a single bus-bar is used in this system. To the same single bus-bar few incoming and outgoing line are connected.
As an example, two 11 KV incoming lines are connected through circuit breaker and isolator. Three phase, 440 V and single phase 230 V outgoing supply lines are connected by isolator, circuit breaker, and step down transformer as shown in the above figure.
Single bus-bar sectionalized arrangement can be made by adding circuit breakers wherever required.
Advantages of Single bus-bar System
  • The advantage of this system is that fault on one part of the bus-bar does not completely shut down the total system.
  • It has low maintenance cost.
Disadvantages of Single bus-bar System
  • In case of fault, the complete system will be switched off.
  • For any expansion, complete shutdown is to be carried out.
Double Bus-bar system
In case of double bus-bar system, low voltage and high voltage bus-bars are duplicated. Among the two, any one of the bus-bar sections can be used as desired.
There is an arrangement of a bus-bar coupling switch for transferring operation from one bus-bar to another.
Double bus-bar sectionalized arrangement can be made as per the requirement by the addition of circuit breakers.
Advantages of Double Bus-bar System
  • In the double bus-bar type of arrangement, it is possible to have one bus-bar “energized” and become convenient to carry out repairs on the other whenever required.
  • By keeping the main bus-bar un-touched, testing of feeder circuit breakers can be done by putting them on spare bus bar.
  • Whenever a fault occurs on the bus-bar, the undisrupted supply to the circuit can be maintained by transferring it to other bus-bar.
Disadvantages of Double Bus-bar System
  • Maintenance cost is high.
Ring Bus-bar System
Ring Bus-bar system
In this type of arrangement, two circuit breakers serve on one line. For example CB1 and CB2 on one line, where are CB3, CB4 on another line.
This ring bus-bar system has the advantage that there are always two parallel paths to the circuit and failure of one path does not interrupt the service completely.
Advantages of Ring Bus-bar System
  • This ring bus-bar system has redundant path to the circuit and failure of one section does not interrupt the service completely.
  • Maintenance of any circuit breaker is possible, without interruption of power.
Disadvantages of Ring Bus-bar System
  • It may be difficult in adding new circuit line.
References
  • Power System Engineering by R.K Rajput.
  • Transmission and distribution of power (WBSCTE)
  • Current Limiting Reactors in Power System
  • Substation Interview Questions Answers
  • Earthing Practices Used for PLC Panel
  • Comparison of Soft Starter and VFD
  • Download Electrical Enclosure Book
Dynamic Braking Resistor in VFD
Difference Between Electric Field and Magnetic Field
What is a Substation? Purpose of an Electrical Substation
Types of Stepper Motors
Top 100 Electrical Machines Projects for Electrical Engineers
Cells and Batteries – Types, Applications, Explanation
2 Comments
  • Umesh Chathuranga says:
    May 9, 2022 at 3:48 pm
    it is good for beginner who interest to electrical system.
  • Kally says:
    November 24, 2024 at 1:22 am
    Great stuff, am loving it..
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Polarization Index (PI) Test and DA Test
Why is Phase Failure Relay Required in LV Panels?
What is SMPS? – Types of SMPS
One Nation One Grid One Frequency – Electrical Engineering
What is an Instrument Transformer? – Types, Principle, Advantages
Differences between Watts and Volt Amps
Offline UPS
UPS Working Principle and Types – Offline and Online UPS Systems
Advantages of Star and Delta Systems
fundamentals of an AC motor
How does an Electric Motor Operate? – AC Motor Fundamentals
Current Transformer Operation
Current Transformer Selection, Operation & Maintenance
Rotary Encoder
Rotary Encoder Interview Questions and Answers
Why do we need to Control the Motion using VFD drives
Why do we need to Control the Motion using VFD drives?
Positive Displacement Pumps
What are Positive Displacement Pumps and their Types?
Automatic Box Filling System using PLC Programming
How to Select a Inductive Proximity Sensor
Delta PLC Simulator
How to Work with Delta PLC Simulator?
PLC PID tuning parameters
Seebeck Effect
Seebeck Effect Theory
Smart Drip Irrigation System Using PLC
Siemens PLC Course for Beginners
