Take Digital Electronics Quiz To test your Knowledge. Digital Electronics MCQ online quiz checks your basic knowledge.
Digital Electronics MCQ Quiz & Online Test
1. A demultiplexer is a
A) 1-to-1 device
B) N-to-1 device
C) 1-to-N device
D) N-to-N device
2. 8421 code is
A) weighted code
B) self-complementing code
C) non-weighted code
D) alphanumeric code
3. A device which converts a decimal number into BCD form is called
A) encoder
B) decoder
C) multiplexer
D) code converter
4. ASCII and EBCDIC codes are
A) alphanumeric codes
B) BCD codes
C) numeric codes
D) error correcting codes
5. Which of the following codes is known as the 8421 code?
A) Gray code
B) BCD code
C) ASCII code
D) XS-3 code
6. A 15-bit Hamming code requires
A) 4 parity bits
B) 5 parity bits
C) 15 parity bits
D) none of the answers
7. A multiplexer is a
A) N-to-1 device
B) N-to-N device
C) 1-to-N device
D) 1-to-1 device
8. The XS-3 code is a
A) weighted code
B) cyclic code
C) self-complementing code
D) error-correcting code
9. ASCII code is a
A) 10-bit code
B) 8-bit code
C) 7-bit code
D) 5-bit code
10. A device which converts BCD into octal is called
A) code converter
B) encoder
C) decoder
D) demultiplexer
All 30 questions and answers are available in the Quiz.
Take All Tests :
- Digital Electronics Quiz – Set 1
- Digital Electronics Quiz – Set 2
- Digital Electronics Quiz – Set 3
- Digital Electronics Quiz – Set 4
- Digital Electronics Quiz – Set 5
- Digital Electronics Quiz – Set 6
- Digital Electronics Quiz – Set 7
- Digital Electronics Quiz – Set 8
- Digital Electronics Quiz – Set 9
- Digital Electronics Quiz – Set 10
- Digital Electronics Quiz – Set 11
Toughest question
