Reading: Difference Between Flame Resistant and Flame Retardant Cables
Inst Tools > Blog > Electrical Basics > Difference Between Flame Resistant and Flame Retardant Cables
In this post, we will learn the difference between flame-resistant and flame retardant cables used in industries.
Last updated: July 15, 2023 12:59 pm
Electrical Basics
In this post, we will see the difference between flame-resistant and flame retardant cables.
What is a Flame Resistant Cable?What is a Flame Retardant Cable?Difference Between Flame Resistant and Flame Retardant Cables
Fire protection is a very important factor when used in electrical cables. In today’s world of rapid construction and engineering, if there is no fire safety in the cables used, then it can be hazardous for human life as well as the nearby environment.
So, the fire resistance factor should also be taken into care when choosing an electrical cable. Majorly, two types of fire safety cables are used everywhere – flame resistant and flame retardant.
Flame Cables
As the name implies, a flame resistant cable is one that will continue to operate and not burn in case of fire. Without melting, it will resist high temperatures and prevent itself from burning.
Typically, it can survive temperatures of up to 300 deg C. So, it is designed to maintain circuit integrity and continue to work for a specified amount of time (means this cable cannot resist fire for long hours, but only till a specified amount of time).
These cables operate under IEC 60331 and BS 6387 standards. So, the material used in covering the cable is non-flammable.
As the name implies, a flame retardant cable is one that will continue to operate in case of fire; but it will burn slowly and prevent the fire from spreading by reducing the amount of heat released from a fire and the potential for a fire to spread. Thus, they inhibit or suppress the combustion process.
These cables either self-distinguish themselves or burn slowly; thus preventing the fire from spreading to other areas. These cables operate under IEC 60332, BS EN 60332, EN 50265, and BS 4066 standards.
Below are the key points which differentiate both of them.
  • The first and foremost major difference is that a flame resistant cable will not catch fire; whereas a flame retardant cable catches fire, but works slowly and does not allow the flame to spread quickly in the surrounding.
  • Flame-resistant cables do not prevent fire from spreading to other nearby areas; whereas flame retardant cables prevent fire from spreading to other nearby areas.
  • Generally, fire-resistant cable has a red outer sheath while flame retardant cables have a grey or black outer sheath.
  • Differentiating between which cable to use depends on the application. If you do not want that the cable be destroyed, then you can use flame-resistant cables; whereas if you do not want the fire to spread quickly to nearby areas, then you can use flame-retardant cables.
In this way, we saw the difference between flame-resistant and flame retardant cables.
  • Single Core and Multi-Core Cables
  • Difference Between HV and LV Cables
  • Types of Cables in Industrial Automation
  • Instrumentation Cables Testing Steps
  • Materials in Instrumentation Cables
What is Gas-Insulated Transmission Line? Principle Advantages
Electrical Contactor, Switch, Circuit Breaker
Dahlander Motors – Principle, Advantages, Disadvantages
What is a Current Transformer?
Why is Phase Failure Relay Required in LV Panels?
Bus Riser in Switchgear
Types of Electrical Wiring
Dahlander Motor Control Circuit and Power Circuit
Basics of Electricity Rates
Why do we need to Control the Motion using VFD drives?
Difference between Single-phase and Three-phase Power
Electrical Terminal Blocks
How to Protect Electrical Terminal Blocks From Tampering?
Electrical Conduit Seal
What are HP and LP Switches in HVAC
Control Methods in Servo Motor Drives
Various Control Methods in Servo Motor Drives
Benefits of SIMOCODE over Intelligent MCC
Download Electrical Enclosure Book
Current Earth Leakage Circuit Breaker
Types of Earth Leakage Circuit Breaker
Types of Industrial Storage Batteries
Network topologies
Different Types of Network Topologies
hydraulic module
Identify all Spool Valve Positions
DeviceNet
What is DeviceNet?
Questions and Answers on Motors and Generators
100+ Questions and Answers on Motors and Generators
circuit-breaker-interview-questions-answers
Circuit Breaker Interview Questions & Answers
Capacitive Level Switch Principle
Online PLC Ladder Logic
Mis-conceptions of PLC Ladder Logic
Pressure Drop Calculator
