Reading: DC Machines Construction
Inst Tools > Blog > Electrical Theory > DC Machines Construction
Last updated: July 27, 2018 10:09 pm
Electrical Theory
3 Min Read
Direct current machines are energy transfer devices. These machines can function as either a motor or a generator. DC motors and generators have the same basic construction, differing primarily in the energy conversion. To better understand the operation and construction of DC machines, a few basic terms must be understood.
Components of a DC machine:
  1. Armature
  2. Rotor
  3. Stator
  4. Field
DC Machine
Figure 2 : Basic DC Machine
Armature
The purpose of the armature is to provide the energy conversion in a DC machine (refer to Figure 2).
In a DC generator, the armature is rotated by an external mechanical force, such as a steam turbine. This rotation induces a voltage and current flow in the armature. Thus, the armature converts mechanical energy to electrical energy.
In a DC motor, the armature receives voltage from an outside electrical source and converts electrical energy into mechanical energy in the form of torque.
Rotor
The purpose of the rotor is to provide the rotating element in a DC machine (refer to Figure 2). In a DC generator, the rotor is the component that is rotated by an external force. In a DC motor, the rotor is the component that turns a piece of equipment. In both types of DC machines, the rotor is the armature.
Stator
The stator is the part of a motor or generator that is stationary (refer to Figure 2). In DC machines, the purpose of the stator is to provide the magnetic field. The stator in Figure 2 is provided by a permanent magnet.
Field
The purpose of the field in a DC machine is to provide a magnetic field for producing either a voltage (generator) or a torque (motor) (refer to Figure 2). The field in a DC machine is produced by either a permanent magnet or an electromagnet. Normally, electromagnets are used because they have an increased magnetic strength, and the magnetic strength is more easily varied using external devices. In Figure 2, the field is provided by the stator.
Units of Electrical Measurement
Inductive Time Constant
Starting a Synchronous Motor
Moving Iron Vane Meter Movement
Low Voltage Air Circuit Breaker Principle
Transformer Current Ratio
D’Arsonval Meter Movement
Transformer Efficiency
DC Circuit Analysis Node Equations
3-Wire, Three-Phase Delta Wiring System
Transformer Mutual Induction
DC Machines Terminology
Ampere Hour Meter
Starting of DC Motors
Current in a Capacitor
Capacitance and Capacitive Reactance
Electric Open Circuit
Series Open Circuit Faults
Battery Hazard
Battery Hazards
Capacitor Principle
Capacitor
Inductor Principle
Inductance and Inductive Reactance
relationship between resistance, reactance, and impedance
Impedance
Power Factor Meter Principle
Thermocouples
Thermocouples
Heat Flow Balance Systems Objective Questions
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 7
Electrical & Electronics Measurements Objective Questions – Set 1
Power Plant Interview Questions & Answers
Basics of PID Controllers
PID Controllers in Closed Loop Control Systems – PLC Basics
3-15 psi to 4-20mA Conversion
Example of 3-15 psi to 4-20mA Conversion
What is a Thermostat
Thermostat – Types, Working Principle, Advantages, Applications
What is Swing Check Valve ?
