Reading: What is a Database Server? – Types, Comparison
Inst Tools > Blog > Common > What is a Database Server? – Types, Comparison
A database server is a powerful computer for storing, managing, and delivering organized data to authorized users.
Last updated: January 11, 2024 4:03 pm
Common
8 Min Read
When you are dealing with a large system, you always need data for storage and usage. As times have advanced, data storage systems too have advanced. These systems are called as database servers.
What is a Database Server?Types of Database ServersMySQLMariaDBOraclePostgreSQLMicrosoft SQL ServerMicrosoft AccessSQLiteMongoDBComparison of Servers
For IT programmers, it is a very essential tool for storing and retrieving data. Instead of consuming the memory of their in-built devices, they just have to dump data in these large storage memories. These database servers have many types for use. In this post, we will see the various types of database servers
As discussed earlier, a database server system is a software tool that is used to store data for retrieval or manipulation. It is used for large-scale systems and not small data requirements. Simply, suppose you have an application where you are required to dump data in memory every minute.
If this data was stored in local storage areas, then it would overflow within a few days. Local memory storage is not designed for such bulk data. So, these software tools are designed to store bulk data. It works in a background process and is not compulsorily required to open the software.
As it is a server, it works on a client-server model. It stores data and then whichever client requests for data, it will pass on to it. The server will take data from multiple clients and then manage which is required by whom. Besides all this, security is maintained and no one can access data easily. The visualization of the tools is good enough for programmers to use them efficiently. A computer system is required first of all for installing this software. Once done, you can integrate it with your various programs for dumping data in it and then use it for some other work.
Database servers are majorly of two types – relational and non-relational. Relational uses tables, rows, and columns where every data is related to real date and time. It is always on dependency with each other. Non-relational one uses different methods for storing like keying, documents, or graphs. In this, data is not structured or queues and is based on how they just come and how they go. There are no boundaries of time and date in it.
Some of the popular database servers are MySQL, MariaDB, Oracle, PostgreSQL, Microsoft SQL, SQLite, Microsoft Access, and MongoDB.
MySQL
MySQL is a relational database. MySQL is open license software and can be expanded only to a certain limit. MySQL is easy to learn. MySQL can work with multiple OS types like Windows, Linux, IRIS, etc. MySQL supports structured and semi-structured data.
MariaDB
MariaDB can be said as an extended version of MySQL. MariaDB possesses a higher memory storage than MySQL. Also, you can write additional queries in it. MariaDB is also more secure.
Oracle
Oracle is a highly advanced database software which is relational in nature, but also supports models like graphs, documents and keys. So, Oracle can be termed as a mixture of relation and non-relation, through it is on a relational higher side. Oracle is a proprietary license, meaning it is fully owned by Oracle company and not a public one. Oracle supports all structured, semi-structured, and unstructured data. But it is very hard to learn.
PostgreSQL
PostgreSQL is too a mixture of both relational and non-relational types. PostgreSQL is an open-source type and supports all types of data structures. PostgreSQL is also available in Android and iOS versions. One main advantage is that programmers can create their data types here.
This one is a relational database system. You can write queries in C++, C or assembly language. Though it is hard to learn, it has more features inside for supporting programmers. It is a proprietary license version and fully owned by Microsoft.
Microsoft Access
Microsoft SQL Server is similar in looks to MS Excel, which makes it easy for programmers to work upon. Microsoft SQL Server can collect all types of data formats and also easy for writing of queries and reports. In fact, it’s query writing is very powerful. As it similar to Excel, you can also create macros for doing automatic works easily. But it is not easy to learn; though it is very useful for large scale projects due to it’s size.
SQLite
SQLite is used for small-scale applications due to its size limitations. You can write queries in only C language. SQLite is the easiest to learn in all types. But it lacks advanced features and is not suitable for large-scale applications.
MongoDB
MongoDB is a non-relational type of database. Basically, MongoDB uses document type language and dumping style for the same. This means data is stored in form of documents. MongoDB uses horizontal scaling approach for programming.
CriteriaMySQLMariaDBOraclePostgreSQLMicrosoft SQL ServerSQLiteMicrosoft AccessMongoDB
TypeRelationalRelationalRelationalRelationalRelationalRelational (Embedded)Relational (Desktop)NoSQL (Document)
LicenseOpen Source (GPL)Open Source (GPL, LGPL)ProprietaryOpen Source (PostgreSQL License)ProprietaryPublic DomainProprietaryOpen Source (SSPL)
Primary UseWeb applications, e-commerce, online transactionsSimilar to MySQL, with additional featuresEnterprise solutions, large-scale applicationsGeneral purpose, advanced featuresEnterprise environments, business applicationsEmbedded systems, mobile apps, small to medium applicationsSmall-scale applications, desktop applicationsBig data, real-time analytics, content management
ACID ComplianceYesYesYesYesYesYesYesYes (with limitations)
ScalabilityHigh (with optimization)High (with optimization)Very highHighVery highLow (not designed for scalability)Low (not intended for large-scale applications)High (horizontal scaling)
Replication & ClusteringSupportedSupportedAdvanced featuresSupportedAdvanced featuresNot supportedNot supportedAdvanced features
Stored Procedures & TriggersSupportedSupportedSupportedSupportedSupportedLimited supportSupportedLimited (JavaScript functions)
Query LanguageSQLSQLPL/SQLSQL, PL/pgSQLT-SQLSQLSQL-likeBSON, JavaScript
Security FeaturesGoodGoodAdvancedGoodAdvancedBasicBasicGood
Community & SupportLarge community, extensive third-party toolsGrowing community, strong open-source supportExtensive enterprise support, large communityLarge community, strong open-source supportExtensive enterprise support, large communityLarge community, extensive documentationLimited, mostly community-drivenLarge community, commercial support available
  • Free Schneider PLC Training
  • Real-time PLC Automation Projects
  • How to Choose a PLC for a Project?
  • PLC-to-PLC Communication Project
  • Moving Data between Siemens PLCs
Step-by-Step Guide: How PCBs are Manufactured from Start to Finish
FPGA vs. CPLD – What are the differences between them
Difference between IP Address and MAC Address
What is a Laser Sensor? Principle
Car Lifts – Choosing the Right One for Your Mechanic Shop
What Type of Heating is Best for Your Home?
Difference Between Robotics and Automation
Logic Gates and Truth tables
Tips for Maintaining and Extending the Life of Your CNC Tools
Good and Bad Wiring Practices
Custom Metal Fabrication Techniques for Quality Machined Parts
Recommendations to HVAC Engineers
How are Data Centers Cooled
How are Data Centers Cooled?
Brix Measurement
Measurement of POL, pH, and BRIX in the Sugar Industry
Shutdown Maintenance
The 5 Phases of Conducting Shutdown Maintenance
The Role of CNC Machining in Electronics Manufacturing
Brass Cable Gland
How to Choose a Brass Cable Gland Manufacturer?
Introduction to Mechatronics
Simple Three Digital Electronic Project Ideas
Sample of a production Downtime
How to Use Production Line Failures for Your Gains?
Basic components of power electronics
What is Power Electronics? Evolution, Block Diagram, Advantages
AC Fundamentals Objective Questions and Answers
Tank Level Control Process in PLC
Tank Level Control in PLC
Siemens S7-200 PLC
Programmable Logic Controller (PLC) Questions and Answers – 13
Programmable Read Only Memory Objective Questions – Part 1
different flow measurement technologies
Different Flow Measurement Technologies
Rectifiers & Filters Interview Questions
Instrumentation Calculator
Instrumentation Calculator Android App
